[GRASS-SVN] r74410 - grass/trunk/vector/v.generalize
Sun Apr 21 15:29:43 PDT 2019
Author: mmetz
Date: 2019-04-21 15:29:42 -0700 (Sun, 21 Apr 2019)
New Revision: 74410
   grass/trunk/vector/v.generalize/v.generalize.html
v.generalize: clarify cats and where options with regard to layer
Modified: grass/trunk/vector/v.generalize/v.generalize.html
--- grass/trunk/vector/v.generalize/v.generalize.html	2019-04-20 21:40:25 UTC (rev 74409)
+++ grass/trunk/vector/v.generalize/v.generalize.html	2019-04-21 22:29:42 UTC (rev 74410)
@@ -1,9 +1,16 @@
 <h2>DESCRIPTION</h2>
-<em>v.generalize</em>
-is a module for the generalization of GRASS vector maps. This module
-consists of algorithms for line simplification, line smoothing,
-network generalization and displacement (new methods may be added later).
+<em>v.generalize</em> is a module for the generalization of GRASS
+vector maps. This module consists of algorithms for line
+simplification, line smoothing, network generalization and displacement
+(new methods may be added later).
+<p>
+The <b>cats</b> and <b>where</b> options are used only if a <b>layer</b>
+> 0 is specified, otherwise, those options are ignored. Be aware
+that the default is <em>layer=-1</em>, meaning that all layers are
+processed, ignoring the <b>cats</b> and <b>where</b> options.
 <p>If <b>type=area</b> is selected, boundaries of selected areas will be
 generalized, and the options <b>cats</b>, <b>where</b>, and
 <b>layer</b> will be used to select areas.
