[GRASS-SVN] r74416 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Wed Apr 24 04:34:05 PDT 2019
Author: sbl
Date: 2019-04-24 04:34:05 -0700 (Wed, 24 Apr 2019)
New Revision: 74416
grass/trunk/lib/python/gunittest/case.py
grass/trunk/lib/python/gunittest/checkers.py
grass/trunk/lib/python/gunittest/gmodules.py
grass/trunk/lib/python/gunittest/invoker.py
make multirunner pass with Py 2 and 3
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2019-04-22 15:58:00 UTC (rev 74415)
+++ grass/trunk/lib/python/gunittest/case.py 2019-04-24 11:34:05 UTC (rev 74416)
@@ -1105,7 +1105,7 @@
# here exception raised by run() with finish_=True would be
# almost enough but we want some additional info to be included
# in the test report
- errors = module.outputs.stderr
+ errors = decode(module.outputs.stderr)
# provide diagnostic at least in English locale
# TODO: standardized error code would be handy here
import re
Modified: grass/trunk/lib/python/gunittest/checkers.py
--- grass/trunk/lib/python/gunittest/checkers.py 2019-04-22 15:58:00 UTC (rev 74415)
+++ grass/trunk/lib/python/gunittest/checkers.py 2019-04-24 11:34:05 UTC (rev 74416)
@@ -14,6 +14,8 @@
import re
import doctest
+from grass.script.utils import decode, encode, _get_encoding
try:
from grass.script.core import KeyValue
except (ImportError, AttributeError):
@@ -593,7 +595,7 @@
regexp = re.compile(exclude_re)
if prepend_lines:
for line in prepend_lines:
- hasher.update(line)
+ hasher.update(line if sys.version_info[0] == 2 else encode(line))
with open(filename, 'r') as f:
for line in f:
# replace platform newlines by standard newline
@@ -603,10 +605,10 @@
continue
if exclude_re and regexp.match(line):
continue
- hasher.update(line.encode("utf-8"))
if append_lines:
for line in append_lines:
return hasher.hexdigest()
Modified: grass/trunk/lib/python/gunittest/gmodules.py
--- grass/trunk/lib/python/gunittest/gmodules.py 2019-04-22 15:58:00 UTC (rev 74415)
+++ grass/trunk/lib/python/gunittest/gmodules.py 2019-04-24 11:34:05 UTC (rev 74416)
@@ -11,7 +11,7 @@
import subprocess
from grass.script.core import start_command
-from grass.script.utils import decode
+from grass.script.utils import encode, decode
from grass.exceptions import CalledModuleError
from grass.pygrass.modules import Module
@@ -126,8 +126,8 @@
# for no stdout, output is None which is out interface
# for stderr=STDOUT or no stderr, errors is None
# which is fine for CalledModuleError
- output, errors = process.communicate(input=stdin)
+ output, errors = process.communicate(input=encode(decode(stdin)) if stdin else None)
returncode = process.poll()
if returncode:
raise CalledModuleError(returncode, module, kwargs, errors)
- return output
+ return decode(output) if output else None
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2019-04-22 15:58:00 UTC (rev 74415)
+++ grass/trunk/lib/python/gunittest/invoker.py 2019-04-24 11:34:05 UTC (rev 74416)
@@ -212,11 +212,17 @@
except:
idx += 1
pass
with open(stdout_path, 'w') as stdout_file:
stdout_file.write(stdout)
with open(stderr_path, 'w') as stderr_file:
- stderr_file.write(stderr)
+ if type(stderr) == 'bytes':
+ stderr_file.write(decode(stderr))
+ else:
+ if isinstance(stderr, str):
+ stderr_file.write(stderr)
+ else:
+ stderr_file.write(stderr.encode('utf8'))
self._file_anonymizer.anonymize([stdout_path, stderr_path])
test_summary = update_keyval_file(
