[GRASS-SVN] r74419 - grass/trunk/scripts/v.rast.stats/testsuite
svn_grass at osgeo.org
Wed Apr 24 13:25:54 PDT 2019
Author: sbl
Date: 2019-04-24 13:25:54 -0700 (Wed, 24 Apr 2019)
New Revision: 74419
grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
make test_v_rast_stats.py pass with Python 2 and 3
Modified: grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
--- grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py 2019-04-24 20:24:50 UTC (rev 74418)
+++ grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py 2019-04-24 20:25:54 UTC (rev 74419)
@@ -61,7 +61,7 @@
v_db_select = SimpleModule("v.db.select", map="zone_map")
self.runModule(v_db_select)
- self.assertLooksLike(univar_string, v_db_select.outputs.stdout.encode('utf-8'))
+ self.assertLooksLike(univar_string, str(v_db_select.outputs.stdout))
def test_line_d(self):
@@ -75,7 +75,7 @@
v_db_select = SimpleModule("v.db.select", map="test_line")
- self.assertLooksLike(output_str, v_db_select.outputs.stdout.encode('utf-8'))
+ self.assertLooksLike(output_str, str(v_db_select.outputs.stdout))
def test_line(self):
@@ -90,7 +90,7 @@
class TestRastStatsFails(TestCase):
