[GRASS-SVN] r74428 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Fri Apr 26 01:07:44 PDT 2019
Author: neteler
Date: 2019-04-26 01:07:44 -0700 (Fri, 26 Apr 2019)
New Revision: 74428
grass/trunk/scripts/g.extension/g.extension.py
g.extension: fixed incomplete updating addon metadata file (https://github.com/GRASS-GIS/grass-ci/pull/13; contributed by AnikaBettge)
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2019-04-26 02:16:00 UTC (rev 74427)
+++ grass/trunk/scripts/g.extension/g.extension.py 2019-04-26 08:07:44 UTC (rev 74428)
@@ -8,14 +8,15 @@
# Vaclav Petras <wenzeslaus gmail com> (support for general sources)
# PURPOSE: Tool to download and install extensions into local installation
-# COPYRIGHT: (C) 2009-2016 by Markus Neteler, and the GRASS Development Team
+# COPYRIGHT: (C) 2009-2019 by Markus Neteler, and the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
# comes with GRASS for details.
-# TODO: add sudo support where needed (i.e. check first permission to write into
-# $GISBASE directory)
+# TODO: - add sudo support where needed (i.e. check first permission to write into
+# $GISBASE directory)
+# - fix toolbox support in install_private_extension_xml()
#%module
@@ -152,6 +153,7 @@
import grass.script as gscript
from grass.script.utils import try_rmdir
from grass.script import core as grass
+from grass.script import task as gtask
# temp dir
REMOVE_TMPDIR = True
@@ -671,8 +673,9 @@
if sys.platform == "win32":
ret += install_extension_win(module)
else:
- ret += install_extension_std_platforms(module,
+ ret1, installed_modules, tmp_dir = install_extension_std_platforms(module,
source=source, url=url)
+ ret += ret1
if len(mlist) > 1:
print('-' * 60)
@@ -685,9 +688,19 @@
else:
# for now it is reasonable to assume that only official source
# will provide the metadata file
- if source == 'official':
+ if source == 'official' and len(installed_modules) <= len(mlist):
grass.message(_("Updating addons metadata file..."))
blist = install_extension_xml(xmlurl, mlist)
+ if source == 'official' and len(installed_modules) > len(mlist):
+ grass.message(_("Updating addons metadata file..."))
+ blist = install_private_extension_xml(tmp_dir, installed_modules)
+ else:
+ grass.message(_("Updating private addons metadata file..."))
+ if len(installed_modules) > 1:
+ else:
+ blist = install_private_extension_xml(tmp_dir, mlist)
# the blist was used here, but it seems that it is the same as mlist
for module in mlist:
update_manual_page(module)
@@ -912,6 +925,87 @@
return bin_list
+def install_private_extension_xml(url, mlist):
+ """Update XML files with metadata about installed modules and toolbox
+ of an private addon
+ # TODO toolbox
+ # if len(mlist) > 1:
+ # # read metadata from remote server (toolboxes)
+ # install_toolbox_xml(url, options['extension'])
+ xml_file = os.path.join(options['prefix'], 'modules.xml')
+ # create an empty file if not exists
+ if not os.path.exists(xml_file):
+ write_xml_modules(xml_file)
+ # read XML file
+ tree = etree_fromfile(xml_file)
+ # update tree
+ for name in mlist:
+ try:
+ desc = gtask.parse_interface(name).description
+ # mname = gtask.parse_interface(name).name
+ keywords = gtask.parse_interface(name).keywords
+ except Exception as e:
+ grass.warning(_("No addons metadata available."
+ " Addons metadata file not updated."))
+ return []
+ tnode = None
+ for node in tree.findall('task'):
+ if node.get('name') == name:
+ tnode = node
+ break
+ # create new node for task
+ tnode = etree.Element('task', attrib={'name': name})
+ dnode = etree.Element('description')
+ dnode.text = desc
+ tnode.append(dnode)
+ knode = etree.Element('keywords')
+ knode.text = (',').join(keywords)
+ tnode.append(knode)
+ # create binary
+ bnode = etree.Element('binary')
+ list_of_binary_files = []
+ for file_name in os.listdir(url):
+ file_type = os.path.splitext(file_name)[-1]
+ file_n = os.path.splitext(file_name)[0]
+ html_path = os.path.join(options['prefix'], 'docs', 'html')
+ c_path = os.path.join(options['prefix'], 'bin')
+ py_path = os.path.join(options['prefix'], 'scripts')
+ # html or image file
+ if file_type in ['.html', '.jpg', '.png'] \
+ and file_n in os.listdir(html_path):
+ list_of_binary_files.append(os.path.join(html_path, file_name))
+ # c file
+ elif file_type in ['.c'] and file_name in os.listdir(c_path):
+ list_of_binary_files.append(os.path.join(c_path, file_n))
+ # python file
+ elif file_type in ['.py'] and file_name in os.listdir(py_path):
+ list_of_binary_files.append(os.path.join(py_path, file_n))
+ # man file
+ man_path = os.path.join(options['prefix'], 'docs', 'man', 'man1')
+ if name + '.1' in os.listdir(man_path):
+ list_of_binary_files.append(os.path.join(man_path, name + '.1'))
+ # add binaries to xml file
+ for binary_file_name in list_of_binary_files:
+ fnode = etree.Element('file')
+ fnode.text = binary_file_name
+ bnode.append(fnode)
+ tnode.append(bnode)
+ tree.append(tnode)
+ write_xml_modules(xml_file, tree)
+ return mlist
def install_extension_win(name):
"""Install extension on MS Windows"""
grass.message(_("Downloading precompiled GRASS Addons <%s>...") %
@@ -1207,10 +1301,31 @@
grass.message(_("Installing..."))
- return grass.call(install_cmd,
- stdout=outdev)
+ with open(os.path.join(TMPDIR, name, 'Makefile')) as f:
+ datafile = f.readlines()
+ makefile_part = ""
+ next_line = False
+ for line in datafile:
+ if 'SUBDIRS' in line or next_line:
+ makefile_part += line
+ if (line.strip()).endswith('\\'):
+ next_line = True
+ else:
+ next_line = False
+ modules = makefile_part.replace('SUBDIRS', '').replace('=', '').replace('\\', '').strip().split('\n')
+ all_modules = os.listdir(c_path)
+ all_modules.extend(os.listdir(py_path))
+ module_list = [x.strip() for x in modules if x.strip() in all_modules]
+ return grass.call(install_cmd, stdout=outdev), module_list, os.path.join(TMPDIR, name)
def remove_extension(force=False):
"""Remove existing extension (module or toolbox if -t is given)"""
if flags['t']:
@@ -1489,15 +1604,15 @@
It ensures that there is a single slash at the end of URL, so we can attach
file name easily:
- >>> resolve_xmlurl_prefix('http://grass.osgeo.org/addons')
- 'http://grass.osgeo.org/addons/'
- >>> resolve_xmlurl_prefix('http://grass.osgeo.org/addons/')
+ >>> resolve_xmlurl_prefix('https://grass.osgeo.org/addons')
+ 'https://grass.osgeo.org/addons/'
+ >>> resolve_xmlurl_prefix('https://grass.osgeo.org/addons/')
gscript.debug("resolve_xmlurl_prefix(url={0}, source={1})".format(url, source))
# use pregenerated modules XML file
- url = 'http://grass.osgeo.org/addons/grass%s/' % version[0]
+ url = 'https://grass.osgeo.org/addons/grass%s/' % version[0]
# else try to get modules XMl from SVN repository (provided URL)
# the exact action depends on subsequent code (somewhere)
@@ -1599,8 +1714,8 @@
Subversion:
- >>> resolve_source_code('http://svn.osgeo.org/grass/grass-addons/grass7')
- ('svn', 'http://svn.osgeo.org/grass/grass-addons/grass7')
+ >>> resolve_source_code('https://svn.osgeo.org/grass/grass-addons/grass7')
+ ('svn', 'https://svn.osgeo.org/grass/grass-addons/grass7')
ZIP files online:
