[GRASS-SVN] r74432 - grass-addons/grass7/raster/r.lake.series
svn_grass at osgeo.org
Sun Apr 28 04:47:08 PDT 2019
Author: nikosa
Date: 2019-04-28 04:47:08 -0700 (Sun, 28 Apr 2019)
New Revision: 74432
grass-addons/grass7/raster/r.lake.series/r.lake.series.py
r.lake.series: add actual fix for 3788#comment:3
Modified: grass-addons/grass7/raster/r.lake.series/r.lake.series.py
--- grass-addons/grass7/raster/r.lake.series/r.lake.series.py 2019-04-28 11:14:38 UTC (rev 74431)
+++ grass-addons/grass7/raster/r.lake.series/r.lake.series.py 2019-04-28 11:47:08 UTC (rev 74432)
@@ -190,12 +190,19 @@
elif coordinates:
kwargs['coordinates'] = coordinates
+ if flags['n']:
+ pass_flags='n'
+ else:
+ pass_flags=None
for i, water_level in enumerate(water_levels):
try:
- gcore.run_command('r.lake', elevation=elevation,
- lake=outputs[i],
- water_level=water_level,
- overwrite=gcore.overwrite(), # TODO: really works? Its seems that hardcoding here False does not prevent overwriting.
+ gcore.run_command('r.lake',
+ flags=pass_flags,
+ elevation=elevation,
+ lake=outputs[i],
+ water_level=water_level,
+ overwrite=gcore.overwrite(), # TODO: really works? Its seems that hardcoding here False does not prevent overwriting.
**kwargs)
except CalledModuleError:
# remove maps created so far, try to remove also i-th map
