[GRASS-SVN] r74441 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Tue Apr 30 11:14:24 PDT 2019
Author: mmetz
Date: 2019-04-30 11:14:24 -0700 (Tue, 30 Apr 2019)
New Revision: 74441
grass/trunk/raster/r.to.vect/areas_io.c
grass/trunk/raster/r.to.vect/lines.c
grass/trunk/raster/r.to.vect/lines_io.c
r.to.vect: reduce compiler warnings, fix typo
Modified: grass/trunk/raster/r.to.vect/areas_io.c
--- grass/trunk/raster/r.to.vect/areas_io.c 2019-04-30 13:02:51 UTC (rev 74440)
+++ grass/trunk/raster/r.to.vect/areas_io.c 2019-04-30 18:14:24 UTC (rev 74441)
@@ -152,9 +152,9 @@
/* this should NEVER happen */
if ((p = move(p)) == NULPTR)
G_fatal_error(_("write_bnd: line terminated unexpectedly\n"
- "previous (%d) point %p (%d,%d,%d) %p %p"),
- direction, last, last->row, last->col, last->node,
- last->fptr, last->bptr);
+ "previous (%d) point %d (%d,%d,%d) %p %p"),
+ direction, i, last->row, last->col, last->node,
+ (void *)last->fptr, (void *)last->bptr);
y = cell_head.north - p->row * cell_head.ns_res;
x = cell_head.west + p->col * cell_head.ew_res;
@@ -203,9 +203,9 @@
last = p;
if ((p = move(p)) == NULPTR) { /* this should NEVER happen */
G_debug(3, "write_smooth_bnd: line terminated unexpectedly\n");
- G_debug(3, " previous (%d) point %p (%d,%d,%d) %p %p\n",
+ G_debug(3, " previous (%d) point %d (%d,%d,%d) %p %p\n",
exit(EXIT_FAILURE);
Modified: grass/trunk/raster/r.to.vect/lines.c
--- grass/trunk/raster/r.to.vect/lines.c 2019-04-30 13:02:51 UTC (rev 74440)
+++ grass/trunk/raster/r.to.vect/lines.c 2019-04-30 18:14:24 UTC (rev 74441)
@@ -16,7 +16,7 @@
* Algorithm was modified by Olga Waupotitsch
* USA CERL on nov, 1993
- * because the previous implementation was incosistent
+ * because the previous implementation was inconsistent
* stopped in the middle of map, because it tried to continue
* a line which was presumed to have been started earlier
* but in fact was not started.
Modified: grass/trunk/raster/r.to.vect/lines_io.c
--- grass/trunk/raster/r.to.vect/lines_io.c 2019-04-30 13:02:51 UTC (rev 74440)
+++ grass/trunk/raster/r.to.vect/lines_io.c 2019-04-30 18:14:24 UTC (rev 74441)
@@ -175,9 +175,9 @@
if ((p = move(p)) == NULL)
G_fatal_error(_("write_line: line terminated unexpectedly\n"
- " previous (%d) point %p (%d,%d,%d) %p %p"),
+ " previous (%d) point %d (%d,%d,%d) %p %p"),
y = cell_head.north - ((double)p->row + 0.5) * cell_head.ns_res;
x = cell_head.west + ((double)p->col + 0.5) * cell_head.ew_res;
