[GRASS-SVN] r74443 - grass/branches/releasebranch_7_6/raster/r.thin
svn_grass at osgeo.org
Tue Apr 30 11:28:34 PDT 2019
Author: mmetz
Date: 2019-04-30 11:28:34 -0700 (Tue, 30 Apr 2019)
New Revision: 74443
grass/branches/releasebranch_7_6/raster/r.thin/thin_lines.c
r.thin: avoid integer overflow, remove unused variable (backport trunk r74442)
Modified: grass/branches/releasebranch_7_6/raster/r.thin/thin_lines.c
--- grass/branches/releasebranch_7_6/raster/r.thin/thin_lines.c 2019-04-30 18:26:10 UTC (rev 74442)
+++ grass/branches/releasebranch_7_6/raster/r.thin/thin_lines.c 2019-04-30 18:28:34 UTC (rev 74443)
@@ -26,7 +26,6 @@
#define false 0
#define DELETED_PIX 9999
-static char *work_file_name;
static int n_rows, n_cols, pad_size;
static int box_right, box_left, box_top, box_bottom;
@@ -37,7 +36,8 @@
int j, i, col, deleted, row;
CELL *row_buf, *new_med, *med, *bottom, *top, *get_a_row();
- char W, N_W, Templ[8], N_Templ[8];
+ char W, N_W;
+ unsigned char Templ[8], N_Templ[8];
map_size(&n_rows, &n_cols, &pad_size);
box_right = box_bottom = 0;
@@ -63,7 +63,6 @@
put_a_row(row, bottom);
} /* row-loop */
if (box_right < box_left || box_bottom < box_top) {
- unlink(work_file_name);
G_fatal_error(_("Unable to find bounding box for lines"));
G_message(_("Bounding box: l = %d, r = %d, t = %d, b = %d"),
@@ -178,6 +177,12 @@
/* encode_neighbours- return neighborhood information for pixel at (middle,col) */
+/* bit position
+ * 1 8 7
+ * 2 x 6
+ * 3 4 5
char
encode_neighbours(CELL * top, CELL * middle, CELL * bottom, int col, int neg)
