[GRASS-git] [OSGeo/grass] be0e59: change Python shebang to python3 (#75)
Markus Neteler
noreply at github.com
Tue Aug 6 11:49:30 PDT 2019
Branch: refs/heads/releasebranch_7_8
Home: https://github.com/OSGeo/grass
Commit: be0e59081095e20bc4531752747df960b4e90cce
https://github.com/OSGeo/grass/commit/be0e59081095e20bc4531752747df960b4e90cce
Author: Markus Neteler <neteler at gmail.com>
Date: 2019-08-06 (Tue, 06 Aug 2019)
Changed paths:
M db/db.describe/testsuite/test_dbdescribe.py
M display/d.mon/render_cmd.py
M doc/gui/wxpython/example/g.gui.example.py
M doc/python/m.distance.py
M doc/python/raster_example_ctypes.py
M doc/python/script/r.example.py
M general/g.parser/test.py
M gui/scripts/d.rast3d.py
M gui/scripts/d.wms.py
M gui/wxpython/animation/g.gui.animation.py
M gui/wxpython/datacatalog/g.gui.datacatalog.py
M gui/wxpython/dbmgr/g.gui.dbmgr.py
M gui/wxpython/gcp/g.gui.gcp.py
M gui/wxpython/gmodeler/g.gui.gmodeler.py
M gui/wxpython/gmodeler/model.py
M gui/wxpython/gui_core/pyedit.py
M gui/wxpython/iclass/g.gui.iclass.py
M gui/wxpython/image2target/g.gui.image2target.py
M gui/wxpython/mapdisp/test_mapdisp.py
M gui/wxpython/mapswipe/g.gui.mapswipe.py
M gui/wxpython/modules/mapsets_picker.py
M gui/wxpython/photo2image/g.gui.photo2image.py
M gui/wxpython/psmap/g.gui.psmap.py
M gui/wxpython/rlisetup/g.gui.rlisetup.py
M gui/wxpython/timeline/g.gui.timeline.py
M gui/wxpython/tplot/frame.py
M gui/wxpython/tplot/g.gui.tplot.py
M gui/wxpython/vdigit/g.gui.vdigit.py
M imagery/i.atcorr/create_iwave.py
M include/Make/Platform.make.in
M lib/init/grass.py
M lib/python/ctypes/ctypesgen.py
M lib/python/ctypes/ctypesgencore/__init__.py
M lib/python/ctypes/ctypesgencore/ctypedescs.py
M lib/python/ctypes/ctypesgencore/descriptions.py
M lib/python/ctypes/ctypesgencore/expressions.py
M lib/python/ctypes/ctypesgencore/messages.py
M lib/python/ctypes/ctypesgencore/options.py
M lib/python/ctypes/ctypesgencore/parser/__init__.py
M lib/python/ctypes/ctypesgencore/parser/cdeclarations.py
M lib/python/ctypes/ctypesgencore/parser/cgrammar.py
M lib/python/ctypes/ctypesgencore/parser/cparser.py
M lib/python/ctypes/ctypesgencore/parser/ctypesparser.py
M lib/python/ctypes/ctypesgencore/parser/datacollectingparser.py
M lib/python/ctypes/ctypesgencore/parser/pplexer.py
M lib/python/ctypes/ctypesgencore/parser/preprocessor.py
M lib/python/ctypes/ctypesgencore/printer/__init__.py
M lib/python/ctypes/ctypesgencore/printer/printer.py
M lib/python/ctypes/ctypesgencore/processor/__init__.py
M lib/python/ctypes/ctypesgencore/processor/dependencies.py
M lib/python/ctypes/ctypesgencore/processor/operations.py
M lib/python/ctypes/ctypesgencore/processor/pipeline.py
M lib/python/pygrass/gis/__init__.py
M locale/grass_po_stats.py
M man/build_check.py
M man/build_check_rest.py
M man/build_class.py
M man/build_class_graphical.py
M man/build_class_rest.py
M man/build_full_index.py
M man/build_full_index_rest.py
M man/build_graphical_index.py
M man/build_html.py
M man/build_index.py
M man/build_index_rest.py
M man/build_keywords.py
M man/build_manual_gallery.py
M man/build_rest.py
M man/build_topics.py
M raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py
M raster/r.mapcalc/testsuite/test_row_above_below_bug.py
M raster/r.solute.transport/example.py
M raster/r.solute.transport/seguin_verify.py
M raster/r.solute.transport/seguin_verify_well.py
M raster3d/r3.to.rast/testsuite/test_a_b_coeff.py
M raster3d/r3.to.rast/testsuite/test_integer_rounding.py
M raster3d/r3.to.rast/testsuite/test_nulls.py
M raster3d/r3.to.rast/testsuite/test_small_data.py
M scripts/d.correlate/d.correlate.py
M scripts/d.frame/d.frame.py
M scripts/d.out.file/d.out.file.py
M scripts/d.polar/d.polar.py
M scripts/d.rast.edit/d.rast.edit.py
M scripts/d.rast.leg/d.rast.leg.py
M scripts/d.redraw/d.redraw.py
M scripts/d.shade/d.shade.py
M scripts/d.to.rast/d.to.rast.py
M scripts/d.what.rast/d.what.rast.py
M scripts/d.what.vect/d.what.vect.py
M scripts/db.dropcolumn/db.dropcolumn.py
M scripts/db.droptable/db.droptable.py
M scripts/db.in.ogr/db.in.ogr.py
M scripts/db.out.ogr/db.out.ogr.py
M scripts/db.test/db.test.py
M scripts/db.univar/db.univar.py
M scripts/g.extension.all/g.extension.all.py
M scripts/g.extension/g.extension.py
M scripts/g.extension/testsuite/data/sample_modules/r.plus.example/r.plus.example.py
M scripts/g.manual/g.manual.py
M scripts/g.search.modules/g.search.modules.py
M scripts/i.colors.enhance/i.colors.enhance.py
M scripts/i.image.mosaic/i.image.mosaic.py
M scripts/i.in.spotvgt/i.in.spotvgt.py
M scripts/i.oif/i.oif.py
M scripts/i.pansharpen/i.pansharpen.py
M scripts/i.spectral/i.spectral.py
M scripts/i.tasscap/i.tasscap.py
M scripts/m.proj/m.proj.py
M scripts/r.blend/r.blend.py
M scripts/r.buffer.lowmem/r.buffer.lowmem.py
M scripts/r.colors.stddev/r.colors.stddev.py
M scripts/r.drain/r.drain.py
M scripts/r.fillnulls/r.fillnulls.py
M scripts/r.grow/r.grow.py
M scripts/r.import/r.import.py
M scripts/r.in.aster/r.in.aster.py
M scripts/r.in.srtm/r.in.srtm.py
M scripts/r.in.wms/r.in.wms.py
M scripts/r.mapcalc.simple/r.mapcalc.simple.py
M scripts/r.mask/r.mask.py
M scripts/r.out.xyz/r.out.xyz.py
M scripts/r.pack/r.pack.py
M scripts/r.plane/r.plane.py
M scripts/r.reclass.area/r.reclass.area.py
M scripts/r.rgb/r.rgb.py
M scripts/r.shade/r.shade.py
M scripts/r.tileset/r.tileset.py
M scripts/r.unpack/r.unpack.py
M scripts/r3.in.xyz/r3.in.xyz.py
M scripts/v.build.all/v.build.all.py
M scripts/v.centroids/v.centroids.py
M scripts/v.clip/v.clip.py
M scripts/v.db.addcolumn/v.db.addcolumn.py
M scripts/v.db.addtable/v.db.addtable.py
M scripts/v.db.dropcolumn/v.db.dropcolumn.py
M scripts/v.db.droprow/v.db.droprow.py
M scripts/v.db.droptable/v.db.droptable.py
M scripts/v.db.join/v.db.join.py
M scripts/v.db.reconnect.all/v.db.reconnect.all.py
M scripts/v.db.renamecolumn/v.db.renamecolumn.py
M scripts/v.db.univar/v.db.univar.py
M scripts/v.db.update/v.db.update.py
M scripts/v.dissolve/v.dissolve.py
M scripts/v.import/v.import.py
M scripts/v.in.e00/v.in.e00.py
M scripts/v.in.geonames/v.in.geonames.py
M scripts/v.in.lines/v.in.lines.py
M scripts/v.in.mapgen/v.in.mapgen.py
M scripts/v.in.wfs/v.in.wfs.py
M scripts/v.pack/v.pack.py
M scripts/v.rast.stats/v.rast.stats.py
M scripts/v.report/v.report.py
M scripts/v.to.lines/v.to.lines.py
M scripts/v.unpack/v.unpack.py
M scripts/v.what.strds/v.what.strds.py
M scripts/v.what.vect/v.what.vect.py
M scripts/wxpyimgview/wxpyimgview.py
M scripts/wxpyimgview/wxpyimgview_gui.py
M temporal/t.create/t.create.py
M temporal/t.info/t.info.py
M temporal/t.list/t.list.py
M temporal/t.merge/t.merge.py
M temporal/t.rast.accdetect/t.rast.accdetect.py
M temporal/t.rast.accumulate/t.rast.accumulate.py
M temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
M temporal/t.rast.aggregate/t.rast.aggregate.py
M temporal/t.rast.algebra/t.rast.algebra.py
M temporal/t.rast.colors/t.rast.colors.py
M temporal/t.rast.contour/t.rast.contour.py
M temporal/t.rast.export/t.rast.export.py
M temporal/t.rast.extract/t.rast.extract.py
M temporal/t.rast.gapfill/t.rast.gapfill.py
M temporal/t.rast.import/t.rast.import.py
M temporal/t.rast.list/t.rast.list.py
M temporal/t.rast.mapcalc/t.rast.mapcalc.py
M temporal/t.rast.neighbors/t.rast.neighbors.py
M temporal/t.rast.out.vtk/t.rast.out.vtk.py
M temporal/t.rast.series/t.rast.series.py
M temporal/t.rast.to.rast3/t.rast.to.rast3.py
M temporal/t.rast.to.vect/t.rast.to.vect.py
M temporal/t.rast.univar/t.rast.univar.py
M temporal/t.rast.what/t.rast.what.py
M temporal/t.rast3d.algebra/t.rast3d.algebra.py
M temporal/t.rast3d.extract/t.rast3d.extract.py
M temporal/t.rast3d.list/t.rast3d.list.py
M temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
M temporal/t.rast3d.univar/t.rast3d.univar.py
M temporal/t.register/t.register.py
M temporal/t.remove/t.remove.py
M temporal/t.rename/t.rename.py
M temporal/t.sample/t.sample.py
M temporal/t.select/t.select.py
M temporal/t.shift/t.shift.py
M temporal/t.snap/t.snap.py
M temporal/t.support/t.support.py
M temporal/t.topology/t.topology.py
M temporal/t.unregister/t.unregister.py
M temporal/t.vect.algebra/t.vect.algebra.py
M temporal/t.vect.db.select/t.vect.db.select.py
M temporal/t.vect.export/t.vect.export.py
M temporal/t.vect.extract/t.vect.extract.py
M temporal/t.vect.import/t.vect.import.py
M temporal/t.vect.list/t.vect.list.py
M temporal/t.vect.observe.strds/t.vect.observe.strds.py
M temporal/t.vect.univar/t.vect.univar.py
M temporal/t.vect.what.strds/t.vect.what.strds.py
M tools/create_python_init_file.py
M tools/g.html2man/g.html2man.py
M tools/gitlog2changelog.py
M tools/mkhtml.py
M tools/mkrest.py
M tools/ppmrotate.py
M tools/thumbnails.py
Log Message:
