[GRASS-SVN] r74053 - grass-addons/grass7/raster/r.accumulate
svn_grass at osgeo.org
Fri Feb 1 14:46:32 PST 2019
Author: hcho
Date: 2019-02-01 14:46:32 -0800 (Fri, 01 Feb 2019)
New Revision: 74053
grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
r.accumulate: Less recursion by skipping upstream cells with shorter longest lfp
Modified: grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
--- grass-addons/grass7/raster/r.accumulate/calculate_lfp.c 2019-02-01 03:31:51 UTC (rev 74052)
+++ grass-addons/grass7/raster/r.accumulate/calculate_lfp.c 2019-02-01 22:46:32 UTC (rev 74053)
@@ -162,6 +162,7 @@
struct point_list *pl, struct line_list *ll)
static struct line_pnts *Points = NULL;
+ static double diag_length;
int rows = dir_buf->rows, cols = dir_buf->cols;
double x, y;
int i, j, nup;
@@ -209,37 +210,42 @@
qsort(up_accum, nup, sizeof(struct neighbor_accum),
compare_neighbor_accum);
- if (!Points)
+ if (!Points) {
Points = Vect_new_line_struct();
+ diag_length =
+ sqrt(pow(window->ew_res, 2.0) + pow(window->ns_res, 2.0));
/* trace up upstream cells */
for (i = 0; i < nup; i++) {
- static double diag_length;
/* store pl->n to come back later */
int split_pl_n = pl->n;
- /* try to avoid unnecessary tracing */
+ /* theoretically, the longest longest flow path is when all accumulated
+ * upstream cells are diagonally flowing */
+ double max_length = up_accum[i].accum * diag_length;
+ /* skip the current cell if its theoretical longest upstream length is
+ * shorter than the first cell's theoretical shortest upstream length
+ if (i > 0 && max_length < up_accum[0].accum)
+ continue;
+ /* if the current cell's theoretical longest lfp < all existing, skip
+ * tracing because it's impossible to obtain a longer lfp */
if (ll->n) {
- double max_length;
- /* theoretically, the longest longest flow path is when all
- * accumulated upstream cells are diagonally flowing */
Vect_reset_line(Points);
Vect_copy_xyz_to_pnts(Points, pl->x, pl->y, NULL, pl->n);
- max_length =
- Vect_line_length(Points) + up_accum[i].accum * diag_length;
+ /* the current cell's downstream length + theoretical longest
+ * upstream length */
+ max_length += Vect_line_length(Points);
for (j = 0; j < ll->n && max_length < ll->lines[j]->length; j++) ;
- /* if the theoretical longest lfp < all existing, skip tracing
- * because it's impossible to obtain a longer lfp */
if (j == ll->n)
continue;
- else
- diag_length =
- sqrt(pow(window->ew_res, 2.0) + pow(window->ns_res, 2.0));
/* if tracing is successful, store the line and its length */
if (trace_up
