[GRASS-SVN] r74056 - grass/trunk/gui/wxpython/gmodeler
svn_grass at osgeo.org
Tue Feb 5 03:39:32 PST 2019
Author: pesekon2
Date: 2019-02-05 03:39:32 -0800 (Tue, 05 Feb 2019)
New Revision: 74056
grass/trunk/gui/wxpython/gmodeler/frame.py
grass/trunk/gui/wxpython/gmodeler/model.py
export UI definitions into Python script from modeler, see #3669
Modified: grass/trunk/gui/wxpython/gmodeler/frame.py
--- grass/trunk/gui/wxpython/gmodeler/frame.py 2019-02-04 22:17:51 UTC (rev 74055)
+++ grass/trunk/gui/wxpython/gmodeler/frame.py 2019-02-05 11:39:32 UTC (rev 74056)
@@ -17,6 +17,7 @@
(>=v2). Read the file COPYING that comes with GRASS for details.
@author Martin Landa <landa.martin gmail.com>
+ at author Python parameterization Ondrej Pesek <pesej.ondrek gmail.com>
import os
@@ -88,6 +89,7 @@
self.searchDialog = None # module search dialog
self.baseTitle = title
self.modelFile = None # loaded model
+ self.start_time = None
self.modelChanged = False
self.randomness = 40 # random layout
@@ -319,7 +321,7 @@
action = self.GetModel().GetItems()[event.pid]
if hasattr(action, "task"):
action.Update(running=True)
- if event.pid == self._gconsole.cmdThread.GetId() - 1:
+ if event.pid == self._gconsole.cmdThread.GetId() - 1 and self.start_time:
self.goutput.WriteCmdLog('({}) {} ({})'.format(
str(time.ctime()), _("Model computation finished"), time_elapsed(self.start_time)),
notification=event.notification)
@@ -2034,9 +2036,17 @@
mode = stat.S_IMODE(os.lstat(self.filename)[stat.ST_MODE])
os.chmod(self.filename, mode | stat.S_IXUSR)
- self.parent._gconsole.RunCmd(
- [fd.name],
- skipInterface=True, onDone=self.OnDone)
+ for item in self.parent.GetModel().GetItems():
+ if len(item.GetParameterizedParams()['params']) + len(
+ item.GetParameterizedParams()['flags']) > 0:
+ self.parent._gconsole.RunCmd(
+ [fd.name, '--ui'],
+ skipInterface=False, onDone=self.OnDone)
+ break
+ else:
+ [fd.name],
+ skipInterface=True, onDone=self.OnDone)
event.Skip()
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2019-02-04 22:17:51 UTC (rev 74055)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2019-02-05 11:39:32 UTC (rev 74056)
@@ -24,6 +24,7 @@
import os
@@ -2544,53 +2545,81 @@
self.fd.write(
r"""#!/usr/bin/env python
-#%s
+#{header_begin}
-# MODULE: %s
+# MODULE: {module_name}
-# AUTHOR(S): %s
+# AUTHOR(S): {author}
-# PURPOSE: %s
+# PURPOSE: {purpose}
-# DATE: %s
+# DATE: {date}
-#%s
- 77,
- EncodeString(
- properties['name']),
- EncodeString(
- properties['author']),
- EncodeString(
- '\n# '.join(
- properties['description'].splitlines())),
- time.asctime(),
- 77))
+#{header_end}
+""".format(header_begin='#' * 77,
+ module_name=EncodeString(properties['name']),
+ author=EncodeString(properties['author']),
+ purpose=EncodeString(
+ '\n# '.join(properties['description'].splitlines())),
+ date=time.asctime(),
+ header_end='#' * 77))
# UI
self.fd.write(
r"""
-#%%module
-#%% description: %s
-#%%end
-""" % (EncodeString(' '.join(properties['description'].splitlines()))))
+#%module
+#% description: {description}
+#%end
+""".format(description=EncodeString(
+ ' '.join(properties['description'].splitlines()))))
- variables = self.model.GetVariables()
- for key, data in six.iteritems(variables):
- otype = self._getStandardizedOption(data['type'])
- self.fd.write(
- r"""
-#%%option %s
-#%% key: %s
-#%% required: yes
-""" % (otype, key, data['description']))
- if 'value' in data:
- self.fd.write("#%% answer: %s\n" % data['value'])
- self.fd.write("#% end\n")
+ modelItems = self.model.GetItems()
+ for item in modelItems:
+ for flag in item.GetParameterizedParams()['flags']:
+ if flag['label']:
+ desc = flag['label']
+ else:
+ desc = flag['description']
+ self.fd.write(
+ r"""#%option
+#% key: {flag_name}
+#% required: yes
+#% type: string
+#% options: True, False
+#% guisection: Flags
+""".format(flag_name=self._getParamName(flag['name'], item),
+ description=desc))
+ if flag['value']:
+ self.fd.write("#% answer: {}\n".format(flag['value']))
+ else:
+ self.fd.write("#% answer: False\n")
+ self.fd.write("#%end\n")
+ for param in item.GetParameterizedParams()['params']:
+ if param['label']:
+ desc = param['label']
+ else:
+ desc = param['description']
+ self.fd.write(
+ r"""#%option
+#% key: {param_name}
+#% required: yes
+""".format(param_name=self._getParamName(param['name'], item),
+ if param['type'] != 'float':
+ self.fd.write('#% type: {}\n'.format(param['type']))
+ else:
+ self.fd.write('#% type: double\n')
+ if param['key_desc']:
+ self.fd.write("#% key_desc: ")
+ self.fd.write(', '.join(param['key_desc']))
+ self.fd.write("\n")
+ if param['value']:
+ self.fd.write("#% answer: {}\n".format(param['value']))
# import modules
self.fd.write(
r"""
@@ -2625,24 +2654,41 @@
if not rast and not vect and not rast3d:
self.fd.write(' pass\n')
- self.fd.write("\ndef main():\n")
+ self.fd.write("\ndef main(options, flags):\n")
for item in self.model.GetItems():
- self._writePythonItem(item, variables=self.model.GetVariables())
+ self._writePythonItem(item,
+ variables=item.GetParameterizedParams())
- self.fd.write("\n return 0\n")
+ self.fd.write(" return 0\n")
+ if item.GetParameterizedParams()['flags']:
+ self.fd.write(r"""
+def getParameterizedFlags(paramFlags, itemFlags):
+ fl = ''
+ self.fd.write(""" for i in [key for key, value in paramFlags.iteritems() if value == 'True']:
+ if i in itemFlags:
+ fl += i[-1]
+ return fl
+ break
self.fd.write(
r"""
if __name__ == "__main__":
options, flags = parser()
atexit.register(cleanup)
- sys.exit(main())
+ sys.exit(main(options, flags))
def _writePythonItem(self, item, ignoreBlock=True, variables={}):
"""Write model object to Python file"""
if isinstance(item, ModelAction):
- if ignoreBlock and item.GetBlockId(): # ignore items in loops of conditions
+ if ignoreBlock and item.GetBlockId():
+ # ignore items in loops of conditions
return
self._writePythonAction(item, variables=variables)
elif isinstance(item, ModelLoop) or isinstance(item, ModelCondition):
@@ -2668,9 +2714,8 @@
1:-
1]))
cond += "grass.read_command("
- cond += self._getPythonActionCmd(task,
- len(cond),
- variables=[condVar]) + ".splitlines()"
+ cond += self._getPythonActionCmd(
+ task, len(cond), variables=[condVar]) + ".splitlines()"
else:
cond += condText
self.fd.write('%s:\n' % cond)
@@ -2706,19 +2751,26 @@
self.fd.write(
strcmd +
+ item,
task,
len(strcmd),
variables) +
'\n')
- def _getPythonActionCmd(self, task, cmdIndent, variables={}):
+ def _getPythonActionCmd(self, item, task, cmdIndent, variables={}):
opts = task.get_options()
ret = ''
flags = ''
params = list()
+ itemParameterizedFlags = list()
+ parameterizedParams = [v['name'] for v in variables['params']]
+ parameterizedFlags = [v['name'] for v in variables['flags']]
for f in opts['flags']:
+ if f.get('name') in parameterizedFlags and len(f.get('name')) == 1:
+ itemParameterizedFlags.append(
+ '"{}"'.format(self._getParamName(f.get('name'), item)))
if f.get('value', False):
name = f.get('name', '')
if len(name) > 1:
@@ -2726,27 +2778,38 @@
else:
flags += name
+ itemParameterizedFlags = ', '.join(itemParameterizedFlags)
for p in opts['params']:
name = p.get('name', None)
value = p.get('value', None)
- if name and value:
+ if (name and value) or (name in parameterizedParams):
ptype = p.get('type', 'string')
foundVar = False
- for var in sorted(variables, key=len, reverse=True):
- data = variables[var]
- if '%' + var in value:
- value = self._substituteVariable(value, var, data)
- foundVar = True
+ if name in parameterizedParams:
+ foundVar = True
+ value = 'options["{}"]'.format(self._getParamName(name,
+ item))
if foundVar or ptype != 'string':
- params.append("%s = %s" % (name, value))
+ params.append("{}={}".format(name, value))
else:
- params.append('%s = "%s"' % (name, value))
+ params.append('{}="{}"'.format(name, value))
ret += '"%s"' % task.get_name()
if flags:
- ret += ",\n%sflags = '%s'" % (' ' * cmdIndent, flags)
+ ret += ",\n{indent}flags='{fl}'".format(indent=' ' * cmdIndent,
+ fl=flags)
+ if itemParameterizedFlags:
+ ret += ' + getParameterizedFlags(options, [{}])'.format(
+ itemParameterizedFlags)
+ elif itemParameterizedFlags:
+ ret += ',\n{}flags=getParameterizedFlags(options, [{}])'.format(
+ ' ' * cmdIndent,
if len(params) > 0:
ret += ",\n"
for opt in params[:-1]:
@@ -2796,6 +2859,11 @@
return result.strip('+')
+ def _getParamName(self, parameter_name, item):
+ return '{module_name}{module_id}_{param_name}'.format(
+ module_name=re.sub('[^a-zA-Z]+', '', item.GetLabel()),
+ module_id=item.GetId(),
+ param_name=parameter_name)
class ModelParamDialog(wx.Dialog):
