[GRASS-SVN] r74074 - grass/trunk/general/g.proj
svn_grass at osgeo.org
Sun Feb 10 06:29:20 PST 2019
Author: mmetz
Date: 2019-02-10 06:29:20 -0800 (Sun, 10 Feb 2019)
New Revision: 74074
grass/trunk/general/g.proj/input.c
g.proj: special case if georef is a .proj file, as in gdalsrsinfo
Modified: grass/trunk/general/g.proj/input.c
--- grass/trunk/general/g.proj/input.c 2019-02-09 21:45:58 UTC (rev 74073)
+++ grass/trunk/general/g.proj/input.c 2019-02-10 14:29:20 UTC (rev 74074)
@@ -281,10 +281,19 @@
hSRS = OSRNewSpatialReference(wktstring);
else {
- G_warning(_("Unable to read georeferenced file <%s> using "
- "GDAL library, trying to open it as ESRI WKT"), geofile);
+ int namelen;
- return input_wkt(geofile);
+ namelen = strlen(geofile);
+ if (namelen > 4 && G_strcasecmp(geofile + (namelen - 4), ".prj") == 0) {
+ G_warning(_("<%s> is not a GDAL dataset, trying to open it as ESRI WKT"),
+ geofile);
+ return input_wkt(geofile);
+ else {
+ G_fatal_error(_("Unable to read georeferenced file <%s> using "
+ "GDAL library"), geofile);
