[GRASS-SVN] r74116 - grass/trunk/scripts/g.extension
svn_grass at osgeo.org
Wed Feb 20 15:23:25 PST 2019
Author: neteler
Date: 2019-02-20 15:23:25 -0800 (Wed, 20 Feb 2019)
New Revision: 74116
grass/trunk/scripts/g.extension/g.extension.html
grass/trunk/scripts/g.extension/g.extension.py
g.extension: fix proxy support for downloading zip from url (contributed by Anika Bettge)
Modified: grass/trunk/scripts/g.extension/g.extension.html
--- grass/trunk/scripts/g.extension/g.extension.html 2019-02-20 20:43:01 UTC (rev 74115)
+++ grass/trunk/scripts/g.extension/g.extension.html 2019-02-20 23:23:25 UTC (rev 74116)
@@ -149,7 +149,7 @@
Example for an open http proxy:
<div class="code"><pre>
# syntax: http://proxyurl:proxyport
-g.extension extension=r.stream.distance proxy="http://proxy.example.com:8080"
+g.extension extension=r.stream.distance proxy="http=http://proxy.example.com:8080"
</pre></div>
<p>
@@ -156,7 +156,7 @@
Example for a proxy with proxy authentication:
# syntax: http://username:password@proxyurl:proxyport
-g.extension extension=r.stream.distance proxy="http://username:password@proxy.example.com:8080"
+g.extension extension=r.stream.distance proxy="http=http://username:password@proxy.example.com:8080"
</pre></div>
<h3>Managing the extensions</h3>
Modified: grass/trunk/scripts/g.extension/g.extension.py
--- grass/trunk/scripts/g.extension/g.extension.py 2019-02-20 20:43:01 UTC (rev 74115)
+++ grass/trunk/scripts/g.extension/g.extension.py 2019-02-20 23:23:25 UTC (rev 74116)
@@ -138,6 +138,7 @@
from distutils.dir_util import copy_tree
try:
+ import requests, zipfile
from urllib2 import HTTPError, URLError, ProxyHandler, build_opener
from urllib import urlopen, urlretrieve
except ImportError:
@@ -1113,10 +1114,15 @@
elif source in ['remote_zip', 'official']:
# we expect that the module.zip file is not by chance in the archive
zip_name = os.path.join(tmpdir, 'extension.zip')
- f, h = urlretrieve(url, zip_name)
- if h.get('content-type', '') != 'application/zip':
+ ses = requests.Session()
+ if 'PROXIES' in globals():
+ ses.proxies = PROXIES
+ res = ses.get(url, stream=True)
+ if str(res.status_code) != '200':
grass.fatal(_("Extension <%s> not found") % name)
+ zipcontent = res.content
+ with open(zip_name, "wb") as f:
+ f.write(zipcontent)
extract_zip(name=zip_name, directory=directory, tmpdir=tmpdir)
fix_newlines(directory)
elif source.startswith('remote_') and \
