[GRASS-SVN] r74123 - in grass/trunk/temporal/t.rast.series: . testsuite
Thu Feb 21 02:14:32 PST 2019
Author: sbl
Date: 2019-02-21 02:14:32 -0800 (Thu, 21 Feb 2019)
New Revision: 74123
   grass/trunk/temporal/t.rast.series/t.rast.series.py
   grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
   grass/trunk/temporal/t.rast.series/testsuite/test_series.py
multi method support for t.rast.series; fix #3741
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py	2019-02-21 09:48:50 UTC (rev 74122)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py	2019-02-21 10:14:32 UTC (rev 74123)
@@ -2,12 +2,12 @@
 # -*- coding: utf-8 -*-
-# MODULE:	t.rast.series
-# AUTHOR(S):	Soeren Gebbert
+# MODULE:    t.rast.series
+# AUTHOR(S):    Soeren Gebbert
-# PURPOSE:	Perform different aggregation algorithms from r.series on all or a
+# PURPOSE:    Perform different aggregation algorithms from r.series on all or a
 #           selected subset of raster maps in a space time raster dataset
-# COPYRIGHT:	(C) 2011-2017 by the GRASS Development Team
+# COPYRIGHT:    (C) 2011-2017 by the GRASS Development Team
 #  This program is free software; you can redistribute it and/or modify
 #  it under the terms of the GNU General Public License as published by
@@ -38,7 +38,7 @@
 #% type: string
 #% description: Aggregate operation to be performed on the raster maps
 #% required: yes
-#% multiple: no
+#% multiple: yes
 #% options: average,count,median,mode,minimum,min_raster,maximum,max_raster,stddev,range,sum,variance,diversity,slope,offset,detcoeff,quart1,quart3,perc90,quantile,skewness,kurtosis
 #% answer: average
 #%end
@@ -48,7 +48,7 @@
 #% type: double
 #% description: Quantile to calculate for method=quantile
 #% required: no
-#% multiple: no
+#% multiple: yes
 #% options: 0.0-1.0
 #%end
@@ -65,7 +65,7 @@
 #%option G_OPT_T_WHERE
 #%end
-#%option G_OPT_R_OUTPUT
+#%option G_OPT_R_OUTPUTS
 #%end
 #%flag
@@ -99,6 +99,15 @@
     add_time = flags["t"]
     nulls = flags["n"]
+    # Check if number of methods and output maps matches
+    print((method.split(',')))
+    print(len(list(filter(None, quantile.split(',')))))
+    print((output.split(',')))
+    if (len(list(filter(None, quantile.split(',')))) +
+        len(method.split(','))) != len(output.split(',')):
+        grass.fatal(_('Number requested methods and output maps do not match.'))
     # Make sure the temporal database exists
     tgis.init()
@@ -133,16 +142,6 @@
         if not add_time:
-            # Create the time range for the output map
-            if output.find("@") >= 0:
-                id = output
-            else:
-                mapset = grass.gisenv()["MAPSET"]
-                id = output + "@" + mapset
-            map = sp.get_new_map_instance(id)
-            map.load()
             # We need to set the temporal extent from the subset of selected maps
             maps = sp.get_registered_maps_as_objects(where=where, order=order, dbif=None)
             first_map = maps[0]
@@ -159,14 +158,26 @@
                 extent = tgis.RelativeTemporalExtent(start_time=start_a, end_time=end_b,
                                                      unit=first_map.get_relative_time_unit())
-            map.set_temporal_extent(extent=extent)
+            for out_map in output.split(','):
-            # Register the map in the temporal database
-            if map.is_in_db():
-                map.update_all()
-            else:
-                map.insert()
+                # Create the time range for the output map
+                if out_map.find("@") >= 0:
+                    id = out_map
+                else:
+                    mapset = grass.gisenv()["MAPSET"]
+                    id = out_map + "@" + mapset
+                map = sp.get_new_map_instance(id)
+                map.load()
+                map.set_temporal_extent(extent=extent)
+                # Register the map in the temporal database
+                if map.is_in_db():
+                    map.update_all()
+                else:
+                    map.insert()
 if __name__ == "__main__":
     options, flags = grass.parser()
     main()
Modified: grass/trunk/temporal/t.rast.series/test.t.rast.series.sh
--- grass/trunk/temporal/t.rast.series/test.t.rast.series.sh	2019-02-21 09:48:50 UTC (rev 74122)
+++ grass/trunk/temporal/t.rast.series/test.t.rast.series.sh	2019-02-21 10:14:32 UTC (rev 74123)
@@ -18,6 +18,7 @@
 t.register type=raster input=precip_abs maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 months"
 t.rast.list precip_abs
+t.rast.series --o -t input=precip_abs method=average,range output=prec_average,prec_range where="start_time > '2001-03-01'"
 t.rast.series --o -t input=precip_abs method=average output=prec_average where="start_time > '2001-03-01'"
 t.rast.series --o    input=precip_abs method=maximum output=prec_max order=start_time
 t.rast.series        input=precip_abs method=sum output=prec_sum
@@ -32,4 +33,4 @@
 t.unregister type=raster maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6,prec_sum,prec_max
 t.remove type=strds input=precip_abs
-g.remove -f type=raster name=prec_sum,prec_max,prec_average
+g.remove -f type=raster name=prec_sum,prec_max,prec_average,prec_range
Modified: grass/trunk/temporal/t.rast.series/testsuite/test_series.py
--- grass/trunk/temporal/t.rast.series/testsuite/test_series.py	2019-02-21 09:48:50 UTC (rev 74122)
+++ grass/trunk/temporal/t.rast.series/testsuite/test_series.py	2019-02-21 10:14:32 UTC (rev 74123)
@@ -85,6 +85,22 @@
         self.assertRasterMinMax(map="series_minimum", refmin=100, refmax=100,
                                 msg="Minimum must be 100")
+    def test_multi_stats(self):
+        self.assertModule("t.rast.series", input="A",
+                          method=["average", "maximum", "minimum",
+                          output=["series_average", "series_maximum",
+                                  "series_minimum"],
+                          overwrite=True)
+        self.assertRasterMinMax(map="series_average", refmin=250, refmax=250,
+                                msg="Average must be 250")
+        self.assertRasterMinMax(map="series_maximum", refmin=400, refmax=400,
+                                msg="Maximum must be 400")
+        self.assertRasterMinMax(map="series_minimum", refmin=100, refmax=100,
+                                msg="Minimum must be 100")
     def test_minimum_where(self):
         self.assertModule("t.rast.series", input="A", method="minimum",
                           output="series_minimum_2",
