[GRASS-SVN] r74128 - in grass/trunk: doc/python lib/python/pygrass/modules/interface lib/python/pygrass/raster lib/python/pygrass/vector lib/python/temporal
Sat Feb 23 20:59:47 PST 2019
Author: annakrat
Date: 2019-02-23 20:59:47 -0800 (Sat, 23 Feb 2019)
New Revision: 74128
   grass/trunk/doc/python/raster_example_ctypes.py
   grass/trunk/lib/python/pygrass/modules/interface/module.py
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/vector/basic.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
fix #3757: replace xrange with range
Modified: grass/trunk/doc/python/raster_example_ctypes.py
--- grass/trunk/doc/python/raster_example_ctypes.py	2019-02-23 14:01:46 UTC (rev 74127)
+++ grass/trunk/doc/python/raster_example_ctypes.py	2019-02-24 04:59:47 UTC (rev 74128)
@@ -64,7 +64,7 @@
 # iterate through map rows
 print "Map data:"
-for row_n in xrange(rows):
+for row_n in range(rows):
     # read a row of raster data into memory, then print it
     Rast_get_row(in_fd, in_rast, row_n, data_type)
     print row_n, in_rast[0:cols]
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py	2019-02-23 14:01:46 UTC (rev 74127)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py	2019-02-24 04:59:47 UTC (rev 74128)
@@ -61,7 +61,7 @@
     >>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
     >>> queue = ParallelModuleQueue(nprocs=3)
-    >>> for i in xrange(5):
+    >>> for i in range(5):
     ...     new_mapcalc = copy.deepcopy(mapcalc)
     ...     mapcalc_list.append(new_mapcalc)
     ...     m = new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
@@ -84,7 +84,7 @@
     >>> queue = ParallelModuleQueue(nprocs=8)
     >>> mapcalc_list = []
@@ -108,7 +108,7 @@
     >>> gregion = Module("g.region", flags="p", run_=False)
     >>> proc_list = []
-    >>> for i in xrange(3):
+    >>> for i in range(3):
     ...     new_gregion = copy.deepcopy(gregion)
     ...     proc_list.append(new_gregion)
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2019-02-23 14:01:46 UTC (rev 74127)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2019-02-24 04:59:47 UTC (rev 74128)
@@ -409,7 +409,7 @@
             >>> map_b = RasterSegment(test_raster_name + "_segment")
             >>> map_a.open('r')
             >>> map_b.open('w', mtype="CELL", overwrite=True)
-            >>> for row in xrange(map_a.info.rows):
+            >>> for row in range(map_a.info.rows):
             ...     map_b[row] = map_a[row] + 1000
             >>> map_a.close()
             >>> map_b.close()
@@ -439,7 +439,7 @@
             >>> elev = RasterSegment(test_raster_name)
             >>> elev.open('r')
-            >>> for i in xrange(4):
+            >>> for i in range(4):
             ...     elev.get(i,i)
             11
             22
@@ -476,8 +476,8 @@
             >>> map_a.open('r')
             >>> map_b.open('w', mtype="FCELL", overwrite=True)
-            ...     for col in xrange(map_a.info.cols):
+            ...     for col in range(map_a.info.cols):
             ...         value = map_a.get(row,col)
             ...         map_b.put(row,col,value + 100)
             >>> map_a.close()
Modified: grass/trunk/lib/python/pygrass/vector/basic.py
--- grass/trunk/lib/python/pygrass/vector/basic.py	2019-02-23 14:01:46 UTC (rev 74127)
+++ grass/trunk/lib/python/pygrass/vector/basic.py	2019-02-24 04:59:47 UTC (rev 74128)
@@ -381,7 +381,7 @@
     to the C line_cats struct.
     >>> cats = Cats()
-    >>> for cat in xrange(100, 110): cats.set(cat, layer=cat-50)
+    >>> for cat in range(100, 110): cats.set(cat, layer=cat-50)
     >>> cats.n_cats
     10
     >>> cats.cat
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2019-02-23 14:01:46 UTC (rev 74127)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2019-02-24 04:59:47 UTC (rev 74128)
@@ -1143,7 +1143,7 @@
                 >>> import grass.temporal as tgis
                 >>> maps = []
                 ...     map = tgis.RasterDataset("map%i at PERMANENT"%i)
                 ...     check = map.set_relative_time(i + 2, i + 3, "days")
                 ...     maps.append(map)
