[GRASS-SVN] r74136 - in grass/trunk/gui/wxpython: core lmgr
svn_grass at osgeo.org
Wed Feb 27 07:11:08 PST 2019
Author: annakrat
Date: 2019-02-27 07:11:08 -0800 (Wed, 27 Feb 2019)
New Revision: 74136
grass/trunk/gui/wxpython/core/render.py
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI: add function to LM interface to programatically change layer
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py 2019-02-26 09:30:25 UTC (rev 74135)
+++ grass/trunk/gui/wxpython/core/render.py 2019-02-27 15:11:08 UTC (rev 74136)
@@ -415,6 +415,8 @@
env_cmd.update(self._render_env)
env_cmd['GRASS_RENDER_FILE'] = self.layer.mapfile
if self.layer.GetType() in ('vector', 'thememap'):
+ if not self.layer._legrow:
+ self.layer._legrow = grass.tempfile(create=True)
if os.path.isfile(self.layer._legrow):
os.remove(self.layer._legrow)
env_cmd['GRASS_LEGEND_FILE'] = text_to_string(self.layer._legrow)
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2019-02-26 09:30:25 UTC (rev 74135)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2019-02-27 15:11:08 UTC (rev 74136)
@@ -21,6 +21,7 @@
from grass.pydispatch.signal import Signal
from core.giface import Notification
+from core.utils import GetLayerNameFromCmd
class Layer(object):
@@ -123,6 +124,22 @@
"Select or unselect layer"
self._tree.SelectItem(layer._layer, select)
+ def ChangeLayer(self, layer, **kwargs):
+ "Change layer (cmd, ltype, opacity)"
+ if 'cmd' in kwargs:
+ layer._pydata[0]['cmd'] = kwargs['cmd']
+ layerName, found = GetLayerNameFromCmd(kwargs['cmd'], fullyQualified=True)
+ if found:
+ layer._pydata[0]['label'] = layerName
+ if 'ltype' in kwargs:
+ layer._pydata[0]['type'] = kwargs['ltype']
+ if 'opacity' in kwargs:
+ layer._pydata[0]['maplayer'].SetOpacity(kwargs['opacity'])
+ self._tree.ChangeLayer(layer._layer)
+ self._tree.SetItemIcon(layer._layer)
+ self._tree.SetItemText(layer._layer, self._tree._getLayerName(layer._layer))
def IsLayerChecked(self, layer):
"""Returns True if layer is checked, False otherwise"""
return self._tree.IsItemChecked(layer._layer)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2019-02-26 09:30:25 UTC (rev 74135)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2019-02-27 15:11:08 UTC (rev 74136)
@@ -2132,7 +2132,7 @@
layer=self.GetLayerInfo(
item,
key='maplayer'),
- type=type,
+ ltype=type,
command=cmdlist,
name=layerName,
active=chk,
