[GRASS-SVN] r74141 - in grass-addons/grass7/raster/r.in.pdal: . testsuite
svn_grass at osgeo.org
Thu Feb 28 09:12:05 PST 2019
Author: neteler
Date: 2019-02-28 09:12:05 -0800 (Thu, 28 Feb 2019)
New Revision: 74141
Added:
grass-addons/grass7/raster/r.in.pdal/testsuite/
grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
grass-addons/grass7/raster/r.in.pdal/testsuite/test_base_resolution.sh
r.in.pdal addon: testsuite added (derived from r.in.lidar testsuite)
Modified: grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py
--- grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2019-02-28 17:02:36 UTC (rev 74140)
+++ grass-addons/grass7/raster/r.in.pdal/r.in.pdal.py 2019-02-28 17:12:05 UTC (rev 74141)
@@ -464,10 +464,10 @@
grass.fatal(_("r.in.xyz is broken..."))
# metadata
- empty_histroy = grass.tempfile()
- if empty_histroy is None:
+ empty_history = grass.tempfile()
+ if empty_history is None:
grass.fatal("Unable to create temporary files")
- f = open(empty_histroy, 'w')
+ f = open(empty_history, 'w')
f.close()
grass.run_command(
'r.support',
@@ -474,7 +474,7 @@
map=outfile,
source1=infile,
description='generated by r.in.pdal',
- loadhistory=empty_histroy
+ loadhistory=empty_history
grass.run_command(
'r.support',
@@ -481,7 +481,7 @@
map=outfile,
history=os.environ['CMDLINE']
- os.remove(empty_histroy)
+ os.remove(empty_history)
# Cleanup
grass.message(_("Cleaning up..."))
Modified: grass-addons/grass7/raster/r.in.pdal/testsuite/test_base_resolution.sh
--- grass/trunk/raster/r.in.lidar/testsuite/test_base_resolution.sh 2019-02-28 11:54:47 UTC (rev 74139)
+++ grass-addons/grass7/raster/r.in.pdal/testsuite/test_base_resolution.sh 2019-02-28 17:12:05 UTC (rev 74141)
@@ -3,7 +3,7 @@
set -e
set -x
-basename="test_rinlidar_"
+basename="test_rinpdal_"
g.region n=20 s=10 e=30 w=20 res=2.5
r.in.xyz data/points.txt output=${basename}base x=1 y=2 z=3 separator=comma
@@ -10,8 +10,9 @@
echo "With base raster resolution matching current region"
-r.in.lidar input=data/points.las output=${basename}with_region \
- base_raster=${basename}base method=min -o
+g.region align=${basename}base
+r.in.pdal input=data/points.las output=${basename}with_region \
+ method=min
echo "Almost all in the following r.univar output should be zero"
r.univar ${basename}with_region
echo "Automatic test if there are only allowed values..."
@@ -21,9 +22,9 @@
echo "With base raster resolution different from current region"
g.region res=5
-r.in.lidar input=data/points.las output=${basename}with_base \
- base_raster=${basename}base method=min -o -d
+r.in.pdal input=data/points.las output=${basename}with_base \
+ method=min
r.univar ${basename}with_base
@@ -32,5 +33,5 @@
echo "Test successful
When running manually maps can be now removed with:
- g.remove type=rast pattern='test_rinlidar_*' -f
+ g.remove type=rast pattern='test_rinpdal_*' -f
However, the region was changed to whatever the test needed."
