[GRASS-SVN] r73914 - grass-addons/grass7/raster/r.learn.ml
svn_grass at osgeo.org
Sat Jan 5 23:32:02 PST 2019
Author: spawley
Date: 2019-01-05 23:32:02 -0800 (Sat, 05 Jan 2019)
New Revision: 73914
grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
r.learn.ml bug fix for handling multiple categorical rasters; changed dict iteritems method to items for python3 compatibility
Modified: grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py
--- grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2019-01-05 00:01:42 UTC (rev 73913)
+++ grass-addons/grass7/raster/r.learn.ml/r.learn.ml.py 2019-01-06 07:32:02 UTC (rev 73914)
@@ -1254,7 +1254,7 @@
if isinstance(scoring, basestring):
scoring = [scoring]
scores = dict.fromkeys(scoring)
- scores = {key: [] for key, value in scores.iteritems()}
+ scores = {key: [] for key, value in scores.items()}
scoring_methods = {'accuracy': metrics.accuracy_score,
'balanced_accuracy': metrics.recall_score,
'average_precision': metrics.average_precision_score,
@@ -1287,10 +1287,10 @@
n_classes = len(np.unique(y))
labels = np.unique(y)
byclass_scores = dict.fromkeys(byclass_methods)
- byclass_scores = {key: np.zeros((0, n_classes)) for key, value in byclass_scores.iteritems()}
+ byclass_scores = {key: np.zeros((0, n_classes)) for key, value in byclass_scores.items()}
# remove any byclass_scorers that are not in the scoring list
- byclass_scores = {key: value for key, value in byclass_scores.iteritems() if key in scores}
+ byclass_scores = {key: value for key, value in byclass_scores.items() if key in scores}
# check if remaining scorers are valid sklearn metrics
for i in scores.keys():
@@ -1494,15 +1494,21 @@
balance = flags['b']
# fetch individual raster names from group
- maplist, mapnames = maps_from_group(group)
+ maplist, _ = maps_from_group(group)
# extract indices of category maps
if categorymaps.strip() == '':
categorymaps = None
else:
- if isinstance(categorymaps, str):
+ # split string into list
+ if ',' in categorymaps is False:
categorymaps = [categorymaps]
+ else:
+ categorymaps = categorymaps.split(',')
cat_indexes = []
+ # check that each category map is also in the imagery group
for cat in categorymaps:
try:
cat_indexes.append(maplist.index(cat))
@@ -1553,7 +1559,7 @@
param_grid = deepcopy(hyperparams_type)
param_grid = dict.fromkeys(param_grid, None)
- for key, val in hyperparams.iteritems():
+ for key, val in hyperparams.items():
# split any comma separated strings and add them to the param_grid
if ',' in val:
param_grid[key] = [hyperparams_type[key](i) for i in val.split(',')] # add all vals to param_grid
@@ -1564,7 +1570,7 @@
if hyperparams['max_depth'] == 0: hyperparams['max_depth'] = None
if hyperparams['max_features'] == 0: hyperparams['max_features'] = 'auto'
- param_grid = {k: v for k, v in param_grid.iteritems() if v is not None}
+ param_grid = {k: v for k, v in param_grid.items() if v is not None}
# retrieve sklearn classifier object and parameters
clf, mode = model_classifiers(
@@ -1573,7 +1579,7 @@
# remove dict keys that are incompatible for the selected classifier
clf_params = clf.get_params()
param_grid = {
- key: value for key, value in param_grid.iteritems()
+ key: value for key, value in param_grid.items()
if key in clf_params}
# scoring metrics
@@ -1828,7 +1834,7 @@
preds = np.hstack((preds, sample_coords))
- for method, val in scores.iteritems():
+ for method, val in scores.items():
gs.message(
method+":\t%0.3f\t+/-SD\t%0.3f" %
(val.mean(), val.std()))
@@ -1840,7 +1846,7 @@
'Cross validation class performance measures......:')
gs.message('Class \t' + '\t'.join(map(str, np.unique(y))))
- for method, val in cscores.iteritems():
+ for method, val in cscores.items():
mat_cscores = np.matrix(val)
gs.message(
method+':\t' + '\t'.join(
