[GRASS-SVN] r73927 - grass/branches/releasebranch_7_4/lib/init
svn_grass at osgeo.org
Thu Jan 10 13:05:48 PST 2019
Author: neteler
Date: 2019-01-10 13:05:48 -0800 (Thu, 10 Jan 2019)
New Revision: 73927
grass/branches/releasebranch_7_4/lib/init/grass.py
grass.py: added --config svn_revision
Modified: grass/branches/releasebranch_7_4/lib/init/grass.py
--- grass/branches/releasebranch_7_4/lib/init/grass.py 2019-01-10 12:40:53 UTC (rev 73926)
+++ grass/branches/releasebranch_7_4/lib/init/grass.py 2019-01-10 21:05:48 UTC (rev 73927)
@@ -343,7 +343,7 @@
gui=_("use $DEFAULT_GUI graphical user interface"),
gui_detail=_("and set as default"),
config=_("print GRASS configuration parameters"),
- config_detail=_("options: arch,build,compiler,path,revision,version"),
+ config_detail=_("options: arch,build,compiler,path,revision,svn_revision,version"),
params=_("Parameters"),
gisdbase=_("initial GRASS GIS database directory"),
gisdbase_detail=_("directory containing Locations"),
@@ -1687,7 +1687,17 @@
linesrev = filerev.readlines()
val = grep('#define GIS_H_VERSION', linesrev)
filerev.close()
- sys.stdout.write("%s\n" % val[0].split(':')[1].rstrip('$"\n').strip())
+ sys.stdout.write(
+ "%s\n" % val[0].split(':')[1].rstrip('$"\n').strip())
+ elif arg == 'svn_revision':
+ filerev = open(gpath('etc', 'VERSIONNUMBER'))
+ linerev = filerev.readline().rstrip('\n')
+ filerev.close()
+ try:
+ revision = linerev.split(' ')[1]
+ sys.stdout.write("%s\n" % revision[1:])
+ except:
+ sys.stdout.write("No SVN revision defined\n")
elif arg == 'version':
sys.stdout.write("%s\n" % grass_version)
else:
