[GRASS-SVN] r73948 - grass/branches/releasebranch_7_6/temporal/t.rast3d.univar/testsuite
svn_grass at osgeo.org
Wed Jan 16 06:39:17 PST 2019
Author: neteler
Date: 2019-01-16 06:39:17 -0800 (Wed, 16 Jan 2019)
New Revision: 73948
grass/branches/releasebranch_7_6/temporal/t.rast3d.univar/testsuite/test_univar.py
t.rast3d.univar/testsuite: fix test (one more column present) (trunk, r73947)
Modified: grass/branches/releasebranch_7_6/temporal/t.rast3d.univar/testsuite/test_univar.py
--- grass/branches/releasebranch_7_6/temporal/t.rast3d.univar/testsuite/test_univar.py 2019-01-16 14:38:59 UTC (rev 73947)
+++ grass/branches/releasebranch_7_6/temporal/t.rast3d.univar/testsuite/test_univar.py 2019-01-16 14:39:17 UTC (rev 73948)
@@ -48,11 +48,11 @@
overwrite=True, verbose=True)
self.assertModule(t_rast3d_univar)
- univar_text="""id|start|end|mean|min|max|mean_of_abs|stddev|variance|coeff_var|sum|null_cells|cells
-a_1 at testing|2001-01-01 00:00:00|2001-04-01 00:00:00|100|100|100|100|0|0|0|48000000|0|480000
-a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000
-a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|144000000|0|480000
-a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|192000000|0|480000
+ univar_text="""id|start|end|mean|min|max|mean_of_abs|stddev|variance|coeff_var|sum|null_cells|cells|non_null_cells
+a_1 at testing|2001-01-01 00:00:00|2001-04-01 00:00:00|100|100|100|100|0|0|0|48000000|0|480000|480000
+a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000|480000
+a_3 at testing|2001-07-01 00:00:00|2001-10-01 00:00:00|300|300|300|300|0|0|0|144000000|0|480000|480000
+a_4 at testing|2001-10-01 00:00:00|2002-01-01 00:00:00|400|400|400|400|0|0|0|192000000|0|480000|480000
for ref, res in zip(univar_text.split("\n"), t_rast3d_univar.outputs.stdout.split("\n")):
if ref and res:
@@ -67,10 +67,10 @@
if ref and res:
@@ -85,10 +85,10 @@
where="start_time >= '2001-03-01'",
univar_output = open("univar_output.txt", "r").read()
@@ -105,9 +105,9 @@
- univar_text="""a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000
+ univar_text="""a_2 at testing|2001-04-01 00:00:00|2001-07-01 00:00:00|200|200|200|200|0|0|0|96000000|0|480000|480000
