[GRASS-SVN] r73954 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jan 16 10:03:29 PST 2019
Author: mmetz
Date: 2019-01-16 10:03:29 -0800 (Wed, 16 Jan 2019)
New Revision: 73954
grass/trunk/lib/vector/Vlib/intersect.c
Vlib: fix fp error in Vect_segment_intersection()
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c 2019-01-16 16:14:47 UTC (rev 73953)
+++ grass/trunk/lib/vector/Vlib/intersect.c 2019-01-16 18:03:29 UTC (rev 73954)
@@ -115,6 +115,7 @@
static int first_3d = 1;
double d, d1, d2, r1, dtol, t;
int switched;
+ int end_points;
/* TODO: Works for points ? */
@@ -128,6 +129,13 @@
first_3d = 0;
+ *x1 = 0;
+ *y1 = 0;
+ *z1 = 0;
+ *x2 = 0;
+ *y2 = 0;
+ *z2 = 0;
/* 'Sort' each segment by x, y
* MUST happen before D, D1, D2 are calculated */
switched = 0;
@@ -230,6 +238,28 @@
G_debug(2, "Vect_segment_intersection(): d = %f, d1 = %f, d2 = %f", d, d1,
d2);
+ end_points = 0;
+ if (ax1 == bx1 && ay1 == by1) {
+ end_points = 1;
+ *x1 = ax1;
+ *y1 = ay1;
+ if (ax1 == bx2 && ay1 == by2) {
+ end_points = 1;
+ *x1 = ax1;
+ *y1 = ay1;
+ if (ax2 == bx1 && ay2 == by1) {
+ end_points = 2;
+ *x1 = ax2;
+ *y1 = ay2;
+ if (ax2 == bx2 && ay2 == by2) {
+ end_points = 2;
+ *x1 = ax2;
+ *y1 = ay2;
/* TODO: dtol was originally set to 1.0e-10, which was usually working but not always.
* Can it be a problem to set the tolerance to 0.0 ? */
dtol = 0.0;
@@ -238,14 +268,30 @@
G_debug(2, " -> not parallel/collinear: d1 = %f, d2 = %f", d1, d2);
if (d > 0) {
if (d1 < 0 || d1 > d || d2 < 0 || d2 > d) {
- G_debug(2, " -> no intersection");
- return 0;
+ if (end_points) {
+ G_debug(2, " -> fp error, but intersection at end points %f, %f", *x1, *y1);
+ return 1;
+ else {
+ G_debug(2, " -> no intersection");
+ return 0;
else {
if (d1 < d || d1 > 0 || d2 < d || d2 > 0) {
- return 0;
+ if (end_points) {
+ return 1;
+ else {
+ return 0;
@@ -264,7 +310,10 @@
if (d1 || d2) { /* lines are parallel */
G_debug(2, " -> parallel");
- return 0;
+ if (end_points)
+ G_debug(2, "Segments are apparently parallel, but connected at end points -> collinear");
+ else
+ return 0;
/* segments are colinear. check for overlap */
