[GRASS-SVN] r73963 - grass-addons/grass7/vector/v.in.pygbif
svn_grass at osgeo.org
Thu Jan 17 11:43:38 PST 2019
Author: neteler
Date: 2019-01-17 11:43:38 -0800 (Thu, 17 Jan 2019)
New Revision: 73963
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
v.in.pygbif addon: Python3 compatibility, using 2to3 from python-tools; HTML fixes
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html 2019-01-17 15:19:37 UTC (rev 73962)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.html 2019-01-17 19:43:38 UTC (rev 73963)
@@ -1,10 +1,16 @@
-<h2>DESCRIPTION:</h2>
+<h2>DESCRIPTION</h2>
<p>The module <em>v.in.pygbif</em> is a wrapper around the
-<a href="http://pygbif.readthedocs.io/en/latest/index.html">pygbif</a> package.<br>
+<a href="http://pygbif.readthedocs.io/en/latest/index.html">pygbif</a> package.
+<br>
Thus, <em>pygbif</em> is a dependency of v.in.pygbif. pygbif can be installed like this:</p>
-<div class="code"><pre>pip install pygbif</pre></div>
+<div class="code"><pre>
+pip install pygbif [--user]
+</pre></div>
<p>Through <em>pygbif</em>, the module allows to download data from the Global Biodiversity
-Information Facility (<a href="www.gbif.org">GBIF</a>) using different search ⁄ filter
+Information Facility (<a href="http://www.gbif.org">GBIF</a>) using different search/filter
criteria.</p>
<p>Since some of the Darwin Core attribute columns represent SQL key-words, the prefix "g_"
was added to all attribute columns. The names of taxa provided at input to the search are
@@ -17,17 +23,18 @@
Providing a mask automatically overrides the limitation of the search to the current
computational region.</p>
-<p>Terminology in v.in.pygbif is oriented on the <em>Darwin Core</em> standard:
+<p>Terminology in <b>v.in.pygbif</b> is oriented on the <em>Darwin Core</em> standard:
<a href="http://rs.tdwg.org/dwc/"> http://rs.tdwg.org/dwc/</a>.</p>
<p>Please note that the GBIF Search API has a hard limit of 200,000 occurrences
per request. If you want to fetch more records, either subivide your area of
interest or split up your search by using different search criteria.<br>
-When a list of taxa is given as input, v.in.pygbif issues a search for each taxon individually. Thus, in order to split up a search it is recommended to either use different filters on time or space.</p>
+When a list of taxa is given as input, <b>v.in.pygbif</b> issues a search for each taxon
+individually. Thus, in order to split up a search it is recommended to either use different
+filters on time or space.</p>
-<div id="examples">
+<h2>EXAMPLES</h2>
-<h2>EXAMPLES:</h2>
# Check matching taxon names and alternatives in GBIF:
v.in.pygbif taxa="Poa,Plantago" rank=genus -p
@@ -45,17 +52,13 @@
v.in.pygbif taxa="Poa pratensis,Plantago media" rank=species output=gbif -i
</pre></div>
-</div>
-<div id="seealso">
+<h2>SEE ALSO:</h2>
-<h2>SEE ALSO:</h2>
<a href="v.in.gbif.html">v.in.gbif</a>
-</div>
-<div id="references">
+<h2>REFERENCES</h2>
-<h2>REFERENCES:</h2>
http://pygbif.readthedocs.io/en/latest/index.html</a><br>
@@ -62,11 +65,9 @@
http://www.gbif.org</a><br>
<a href="http://www.gbif.org/developer/summary">
http://www.gbif.org/developer/summary</a>
-</div>
-<div id="author">
-<h2>AUTHOR:</h2>
+<h2>AUTHORS</h2>
Stefan Blumentrath, Norwegian Institute for Nature Research, Oslo, Norway<br>
Helmut Kudrnovsky
-</div>
Modified: grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py
--- grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2019-01-17 15:19:37 UTC (rev 73962)
+++ grass-addons/grass7/vector/v.in.pygbif/v.in.pygbif.py 2019-01-17 19:43:38 UTC (rev 73963)
@@ -188,7 +188,7 @@
#reload(sys)
#sys.setdefaultencoding('utf-8')
-if not "GISBASE" in os.environ.keys():
+if not "GISBASE" in list(os.environ.keys()):
grass.message("You must be in GRASS GIS to run this program.")
sys.exit(1)
@@ -277,82 +277,82 @@
'lastCrawled', 'specificEpithet', 'facts', 'issues',
'extensions', 'language']
# Deinfe columns for attribute table
- cols = [(u'cat', 'INTEGER PRIMARY KEY'),
- (u'g_search', 'varchar(100)'),
- (u'g_key', 'integer'),
- (u'g_taxonrank', 'varchar(50)'),
- (u'g_taxonkey', 'integer'),
- (u'g_taxonid', 'varchar(50)'),
- (u'g_scientificname', 'varchar(255)'),
- (u'g_species', 'varchar(255)'),
- (u'g_specieskey', 'integer'),
- (u'g_genericname', 'varchar(255)'),
- (u'g_genus', 'varchar(50)'),
- (u'g_genuskey', 'integer'),
- (u'g_family', 'varchar(50)'),
- (u'g_familykey', 'integer'),
- (u'g_order', 'varchar(50)'),
- (u'g_orderkey', 'integer'),
- (u'g_class', 'varchar(50)'),
- (u'g_classkey', 'integer'),
- (u'g_phylum', 'varchar(50)'),
- (u'g_phylumkey', 'integer'),
- (u'g_kingdom', 'varchar(50)'),
- (u'g_kingdomkey', 'integer'),
- (u'g_eventdate', 'text'),
- (u'g_verbatimeventdate', 'varchar(50)'),
- (u'g_startDayOfYear', 'integer'),
- (u'g_endDayOfYear', 'integer'),
- (u'g_year', 'integer'),
- (u'g_month', 'integer'),
- (u'g_day', 'integer'),
- (u'g_occurrenceid', 'varchar(255)'),
- (u'g_occurrenceStatus', 'varchar(50)'),
- (u'g_occurrenceRemarks', 'varchar(50)'),
- (u'g_Habitat', 'varchar(50)'),
- (u'g_basisofrecord', 'varchar(50)'),
- (u'g_preparations', 'varchar(50)'),
- (u'g_sex', 'varchar(50)'),
- (u'g_type', 'varchar(50)'),
- (u'g_locality', 'varchar(255)'),
- (u'g_verbatimlocality', 'varchar(255)'),
- (u'g_decimallongitude', 'double precision'),
- (u'g_decimallatitude', 'double precision'),
- (u'g_geodeticdatum', 'varchar(50)'),
- (u'g_higerGeography', 'varchar(255)'),
- (u'g_continent', 'varchar(50)'),
- (u'g_country', 'varchar(50)'),
- (u'g_countryCode', 'varchar(50)'),
- (u'g_stateProvince', 'varchar(50)'),
- (u'g_gbifid', 'varchar(255)'),
- (u'g_protocol', 'varchar(255)'),
- (u'g_identifier', 'varchar(50)'),
- (u'g_recordedby', 'varchar(255)'),
- (u'g_identificationid', 'varchar(255)'),
- (u'g_identifiers', 'text'),
- (u'g_dateidentified', 'text'),
- (u'g_modified', 'text'),
- (u'g_institutioncode', 'varchar(50)'),
- (u'g_lastinterpreted', 'text'),
- (u'g_lastparsed', 'text'),
- (u'g_references', 'varchar(255)'),
- (u'g_relations', 'text'),
- (u'g_catalognumber', 'varchar(50)'),
- (u'g_occurrencedetails', 'text'),
- (u'g_datasetkey', 'varchar(50)'),
- (u'g_datasetname', 'varchar(255)'),
- (u'g_collectioncode', 'varchar(50)'),
- (u'g_rights', 'varchar(255)'),
- (u'g_rightsholder', 'varchar(255)'),
- (u'g_license', 'varchar(50)'),
- (u'g_publishingorgkey', 'varchar(50)'),
- (u'g_publishingcountry', 'varchar(50)'),
- (u'g_lastcrawled', 'text'),
- (u'g_specificepithet', 'varchar(50)'),
- (u'g_facts', 'text'),
- (u'g_issues', 'text'),
- (u'g_extensions', 'text'),
- (u'g_language', 'varchar(50)')]
+ cols = [('cat', 'INTEGER PRIMARY KEY'),
+ ('g_search', 'varchar(100)'),
+ ('g_key', 'integer'),
+ ('g_taxonrank', 'varchar(50)'),
+ ('g_taxonkey', 'integer'),
+ ('g_taxonid', 'varchar(50)'),
+ ('g_scientificname', 'varchar(255)'),
+ ('g_species', 'varchar(255)'),
+ ('g_specieskey', 'integer'),
+ ('g_genericname', 'varchar(255)'),
+ ('g_genus', 'varchar(50)'),
+ ('g_genuskey', 'integer'),
+ ('g_family', 'varchar(50)'),
+ ('g_familykey', 'integer'),
+ ('g_order', 'varchar(50)'),
+ ('g_orderkey', 'integer'),
+ ('g_class', 'varchar(50)'),
+ ('g_classkey', 'integer'),
+ ('g_phylum', 'varchar(50)'),
+ ('g_phylumkey', 'integer'),
+ ('g_kingdom', 'varchar(50)'),
+ ('g_kingdomkey', 'integer'),
+ ('g_eventdate', 'text'),
+ ('g_verbatimeventdate', 'varchar(50)'),
+ ('g_startDayOfYear', 'integer'),
+ ('g_endDayOfYear', 'integer'),
+ ('g_year', 'integer'),
+ ('g_month', 'integer'),
+ ('g_day', 'integer'),
+ ('g_occurrenceid', 'varchar(255)'),
+ ('g_occurrenceStatus', 'varchar(50)'),
+ ('g_occurrenceRemarks', 'varchar(50)'),
+ ('g_Habitat', 'varchar(50)'),
+ ('g_basisofrecord', 'varchar(50)'),
+ ('g_preparations', 'varchar(50)'),
+ ('g_sex', 'varchar(50)'),
+ ('g_type', 'varchar(50)'),
+ ('g_locality', 'varchar(255)'),
+ ('g_verbatimlocality', 'varchar(255)'),
+ ('g_decimallongitude', 'double precision'),
+ ('g_decimallatitude', 'double precision'),
+ ('g_geodeticdatum', 'varchar(50)'),
+ ('g_higerGeography', 'varchar(255)'),
+ ('g_continent', 'varchar(50)'),
+ ('g_country', 'varchar(50)'),
+ ('g_countryCode', 'varchar(50)'),
+ ('g_stateProvince', 'varchar(50)'),
+ ('g_gbifid', 'varchar(255)'),
+ ('g_protocol', 'varchar(255)'),
+ ('g_identifier', 'varchar(50)'),
+ ('g_recordedby', 'varchar(255)'),
+ ('g_identificationid', 'varchar(255)'),
+ ('g_identifiers', 'text'),
+ ('g_dateidentified', 'text'),
+ ('g_modified', 'text'),
+ ('g_institutioncode', 'varchar(50)'),
+ ('g_lastinterpreted', 'text'),
+ ('g_lastparsed', 'text'),
+ ('g_references', 'varchar(255)'),
+ ('g_relations', 'text'),
+ ('g_catalognumber', 'varchar(50)'),
+ ('g_occurrencedetails', 'text'),
+ ('g_datasetkey', 'varchar(50)'),
+ ('g_datasetname', 'varchar(255)'),
+ ('g_collectioncode', 'varchar(50)'),
+ ('g_rights', 'varchar(255)'),
+ ('g_rightsholder', 'varchar(255)'),
+ ('g_license', 'varchar(50)'),
+ ('g_publishingorgkey', 'varchar(50)'),
+ ('g_publishingcountry', 'varchar(50)'),
+ ('g_lastcrawled', 'text'),
+ ('g_specificepithet', 'varchar(50)'),
+ ('g_facts', 'text'),
+ ('g_issues', 'text'),
+ ('g_extensions', 'text'),
+ ('g_language', 'varchar(50)')]
set_output_encoding()
# Set temporal filter if requested by user
@@ -394,7 +394,7 @@
# Set reprojection parameters
# Set target projection of current LOCATION
- target_crs = grass.read_command('g.proj', flags='fj').rstrip(os.linesep).encode('utf-8')
+ target_crs = grass.read_command('g.proj', flags='fj').rstrip(os.linesep)
target = osr.SpatialReference(target_crs)
target.ImportFromProj4(target_crs)
if target == 'XY location (unprojected)':
@@ -474,33 +474,33 @@
# Return matching taxon and alternatives and exit
if print_species:
- print u'Matching taxon for {} is:'.format(s)
- print u'{} {}'.format(species_match['scientificName'], species_match['status'])
- if 'alternatives' in species_match.keys():
- print 'Alternative matches might be:'.format(s)
+ print('Matching taxon for {} is:'.format(s))
+ print('{} {}'.format(species_match['scientificName'], species_match['status']))
+ if 'alternatives' in list(species_match.keys()):
+ print('Alternative matches might be:'.format(s))
for m in species_match['alternatives']:
- print u'{} {}'.format(m['scientificName'], m['status'])
+ print('{} {}'.format(m['scientificName'], m['status']))
else:
- print 'No alternatives found for the given taxon'
+ print('No alternatives found for the given taxon')
continue
if print_species_shell:
- print u'match={}'.format(species_match['scientificName'])
+ print('match={}'.format(species_match['scientificName']))
alternatives = []
alternatives.append(m['scientificName'])
- print u'alternatives={}'.format(u','.join(alternatives))
+ print('alternatives={}'.format(','.join(alternatives)))
continue
if print_species_table:
if len(species_match['alternatives']) == 0:
- print u'{0}|{1}|{2}|'.format(s, key, species_match['scientificName'])
+ print('{0}|{1}|{2}|'.format(s, key, species_match['scientificName']))
else:
alternatives = []
- print u'{0}|{1}|{2}|{3}'.format(s, key, species_match['scientificName'],
- u','.join(alternatives))
+ print('{0}|{1}|{2}|{3}'.format(s, key, species_match['scientificName'],
+ ','.join(alternatives)))
continue
try:
returns_n = occurrences.search(taxonKey=key,
@@ -579,12 +579,12 @@
point = Point(x, y)
for k in dwc_keys:
- if k not in res.keys():
+ if k not in list(res.keys()):
res.update({k: None})
cat = cat + 1
new.write(point, cat=cat, attrs=(
- u'{}'.format(s.decode('utf-8')),
+ '{}'.format(s),
res['key'],
res['taxonRank'],
res['taxonKey'],
@@ -605,8 +605,8 @@
res['phylumKey'],
res['kingdom'],
res['kingdomKey'],
- u'{}'.format(res['eventDate']) if res['eventDate'] else None,
- u'{}'.format(res['verbatimEventDate']) if res['verbatimEventDate'] else None,
+ '{}'.format(res['eventDate']) if res['eventDate'] else None,
+ '{}'.format(res['verbatimEventDate']) if res['verbatimEventDate'] else None,
res['startDayOfYear'],
res['endDayOfYear'],
res['year'],
@@ -635,16 +635,16 @@
res['identifier'],
res['recordedBy'],
res['identificationID'],
- u','.join(res['identifiers']),
- u'{}'.format(res['dateIdentified']) if res['dateIdentified'] else None,
- u'{}'.format(res['modified']) if res['modified'] else None,
+ ','.join(res['identifiers']),
+ '{}'.format(res['dateIdentified']) if res['dateIdentified'] else None,
+ '{}'.format(res['modified']) if res['modified'] else None,
res['institutionCode'],
- u'{}'.format(res['lastInterpreted']) if res['lastInterpreted'] else None,
- u'{}'.format(res['lastParsed']) if res['lastParsed'] else None,
+ '{}'.format(res['lastInterpreted']) if res['lastInterpreted'] else None,
+ '{}'.format(res['lastParsed']) if res['lastParsed'] else None,
res['references'],
- u','.join(res['relations']),
+ ','.join(res['relations']),
res['catalogNumber'],
- u'{}'.format(res['occurrenceDetails']) if res['occurrenceDetails'] else None,
+ '{}'.format(res['occurrenceDetails']) if res['occurrenceDetails'] else None,
res['datasetKey'],
res['datasetName'],
res['collectionCode'],
@@ -653,11 +653,11 @@
res['license'],
res['publishingOrgKey'],
res['publishingCountry'],
- u'{}'.format(res['lastCrawled']) if res['lastCrawled'] else None,
+ '{}'.format(res['lastCrawled']) if res['lastCrawled'] else None,
res['specificEpithet'],
- u','.join(res['facts']),
- u','.join(res['issues']),
- u','.join(res['extensions']),
+ ','.join(res['facts']),
+ ','.join(res['issues']),
+ ','.join(res['extensions']),
res['language'],))
cat = cat + 1
