[GRASS-SVN] r73970 - grass-addons/grass7/vector/v.surf.icw
svn_grass at osgeo.org
Thu Jan 17 13:58:28 PST 2019
Author: neteler
Date: 2019-01-17 13:58:28 -0800 (Thu, 17 Jan 2019)
New Revision: 73970
grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
v.surf.icw addon: fix tab/space indentation; tabs are to be avoided, see https://trac.osgeo.org/grass/wiki/Submitting/Python?version=19#Editorsettingsfor4-spaceindentation
Modified: grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
--- grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py 2019-01-17 21:46:42 UTC (rev 73969)
+++ grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py 2019-01-17 21:58:28 UTC (rev 73970)
@@ -2,16 +2,16 @@
# MODULE: v.surf.icw
-# version $Id$
+# version $Id$
# AUTHOR: M. Hamish Bowman, Dunedin, New Zealand
-# Originally written aboard the NZ DoC ship M/V Renown,
-# Bligh Sound, Fiordland National Park, November 2003
-# With thanks to Franz Smith and Steve Wing for support
-# Ported to Python for GRASS 7 December 2011
+# Originally written aboard the NZ DoC ship M/V Renown,
+# Bligh Sound, Fiordland National Park, November 2003
+# With thanks to Franz Smith and Steve Wing for support
+# Ported to Python for GRASS 7 December 2011
# PURPOSE: Like IDW interpolation, but distance is cost to get to any
-# other site.
+# other site.
# COPYRIGHT: (c) 2003-2014 Hamish Bowman
# This program is free software under the GNU General Public
@@ -132,7 +132,7 @@
grass.verbose(_("Cleanup.."))
tmp_base = 'tmp_icw_' + str(os.getpid()) + '_'
grass.run_command('g.remove', flags = 'f', type = 'raster', pattern = tmp_base + '*',
- quiet = True)
+ quiet = True)
grass.try_remove(TMP_FILE)
@@ -160,7 +160,7 @@
if not grass.find_file(pts_input, element = 'vector')['file']:
grass.fatal(_("Vector map <%s> not found") % pts_input)
if post_mask:
- if grass.find_file('MASK')['file']:
+ if grass.find_file('MASK')['file']:
grass.fatal(_("A MASK already exists; remove it before using the post_mask option."))
if not grass.find_file(post_mask)['file']:
grass.fatal(_("Raster map <%s> not found") % post_mask)
@@ -167,7 +167,7 @@
grass.verbose(_("v.surf.icw -- Inverse Cost Weighted Interpolation"))
grass.verbose(_("Processing %s -> %s, column=%s, Cf=%g")
- % (pts_input, output, column, friction))
+ % (pts_input, output, column, friction))
if flags['r']:
grass.verbose(_("Using (d^n)*log(d) radial basis function."))
@@ -188,7 +188,7 @@
coltype = grass.vector_columns(pts_input, layer)[column]
except KeyError:
grass.fatal(_("Data column <%s> not found in vector points map <%s>")
- % (column, pts_input))
+ % (column, pts_input))
if coltype['type'] not in ('INTEGER', 'DOUBLE PRECISION'):
grass.fatal(_("Data column must be numberic"))
@@ -197,7 +197,7 @@
area_mask = tmp_base + 'area'
grass.mapcalc("$result = if($cost_map, 1, null())",
result = area_mask, cost_map = cost_map,
- quiet = True)
+ quiet = True)
## done with prep work,
@@ -210,7 +210,7 @@
points_list = grass.read_command('v.out.ascii', input = pts_input,
output = '-', flags = 'r',
- **addl_opts).splitlines()
+ **addl_opts).splitlines()
# Needed to strip away empty entries from MS Windows newlines
# list() is needed for Python 3 compatibility
@@ -228,7 +228,7 @@
if n > 200:
grass.warning(_("Computation is expensive! Please consider " \
- + "fewer points or get ready to wait a while ..."))
+ + "fewer points or get ready to wait a while ..."))
import time
time.sleep(5)
@@ -251,41 +251,41 @@
data_value = grass.vector_db_select(pts_input, columns = column)['values'][cat][0]
if not data_value:
- grass.message(_("Site %d of %d, e=%.4f n=%.4f cat=%d data=?")
- % (num, n, float(easting), float(northing), cat))
+ grass.message(_("Site %d of %d, e=%.4f n=%.4f cat=%d data=?")
+ % (num, n, float(easting), float(northing), cat))
grass.message(_(" -- Skipping, no data here."))
- del(points_list[num-1])
+ del(points_list[num-1])
n -= 1
continue
- else:
- grass.message(_("Site %d of %d, e=%.4f n=%.4f cat=%d data=%.8g")
- % (num, n, float(easting), float(northing), cat,
- float(data_value)))
+ else:
+ grass.message(_("Site %d of %d, e=%.4f n=%.4f cat=%d data=%.8g")
+ % (num, n, float(easting), float(northing), cat,
+ float(data_value)))
- # we know the point is in the region, but is it in a non-null area of the cost surface?
+ # we know the point is in the region, but is it in a non-null area of the cost surface?
rast_val = grass.read_command('r.what', map = area_mask,
- coordinates = '%s,%s' % (position[0], position[1])
- ).strip().split('|')[-1]
- if rast_val == '*':
- grass.message(_(" -- Skipping, point lays outside of cost_map."))
- n -= 1
- continue
+ coordinates = '%s,%s' % (position[0], position[1])
+ ).strip().split('|')[-1]
+ if rast_val == '*':
+ grass.message(_(" -- Skipping, point lays outside of cost_map."))
+ n -= 1
+ continue
- # it's ok to proceed
+ # it's ok to proceed
try:
- data_value = float(data_value)
- except:
- grass.fatal('Data value [%s] is non-numeric' % data_value)
+ data_value = float(data_value)
+ except:
+ grass.fatal('Data value [%s] is non-numeric' % data_value)
cost_site_name = tmp_base + 'cost_site.' + '%05d' % num
proc[num-1] = grass.start_command('r.cost', flags = 'k', input = area_mask,
- output = cost_site_name,
- start_coordinates = easting + ',' + northing,
- quiet = True)
- # stall to wait for the nth worker to complete,
- if num % workers is 0:
- proc[num-1].wait()
+ output = cost_site_name,
+ start_coordinates = easting + ',' + northing,
+ quiet = True)
+ # stall to wait for the nth worker to complete,
+ if num % workers is 0:
+ proc[num-1].wait()
num += 1
@@ -292,7 +292,7 @@
# make sure everyone is finished
for i in range(n):
if proc[i].wait() is not 0:
- grass.fatal(_('Problem running %s') % 'r.cost')
+ grass.fatal(_('Problem running %s') % 'r.cost')
grass.message(_("Removing anomalies at site positions ..."))
@@ -309,15 +309,15 @@
proc[i] = grass.mapcalc_start("$cost_n_cleansed = if($cost_n == 0, 0.1, $cost_n)",
cost_n_cleansed = cost_site_name + '.cleansed',
cost_n = cost_site_name, quiet = True)
- if (i+1) % workers is 0:
- #print 'stalling ...'
- proc[i].wait()
+ if (i+1) % workers is 0:
+ #print 'stalling ...'
+ proc[i].wait()
for i in range(n):
- grass.fatal(_('Problem running %s') % 'r.mapcalc')
+ grass.fatal(_('Problem running %s') % 'r.mapcalc')
grass.message(_("Applying radial decay ..."))
@@ -324,7 +324,7 @@
proc = {}
for i in range(n):
- cost_site_name = tmp_base + 'cost_site.' + '%05d' % (i+1)
+ cost_site_name = tmp_base + 'cost_site.' + '%05d' % (i+1)
grass.run_command('g.remove', flags='f', type='raster', name=cost_site_name, quiet=True)
grass.run_command('g.rename', raster = cost_site_name + '.cleansed'
+ ',' + cost_site_name, quiet = True)
@@ -347,14 +347,14 @@
one_by_cost_site_sq_n = tmp_base + '1by_cost_site_sq.' + '%05d' % (i+1)
proc[i] = grass.mapcalc_start("$result = " + expr,
- result = one_by_cost_site_sq_n,
- cost_n = cost_site_name,
- friction = friction,
- quiet = True)
- proc[i].wait()
+ result = one_by_cost_site_sq_n,
+ cost_n = cost_site_name,
+ friction = friction,
+ quiet = True)
+ proc[i].wait()
# r.patch in=1by_cost_site_sqrd.${NUM},tmp_idw_cost_val_$$ out=1by_cost_site_sqrd.${NUM} --o
# g.remove type=rast name=cost_site.$NUM -f
@@ -362,10 +362,10 @@
for i in range(n):
- pattern = tmp_base + 'cost_site.*', quiet = True)
+ pattern = tmp_base + 'cost_site.*', quiet = True)
#grass.run_command('g.list', type = 'raster', mapset = '.')
@@ -417,26 +417,26 @@
northing = position[1]
cat = int(position[-1])
- # failsafe: at this point the data values should all be valid
+ # failsafe: at this point the data values should all be valid
if not data_value:
- grass.message(_("Site %d of %d, cat = %d, data value = ?") % (num, n, cat))
- grass.message(_(" -- Skipping, no data here. [Probably programmer error]"))
- n -= 1
+ grass.message(_("Site %d of %d, cat = %d, data value = ?") % (num, n, cat))
+ grass.message(_(" -- Skipping, no data here. [Probably programmer error]"))
+ n -= 1
continue
- else:
- grass.message(_("Site %d of %d, cat = %d, data value = %.8g")
- % (num, n, cat, data_value))
+ else:
+ grass.message(_("Site %d of %d, cat = %d, data value = %.8g")
+ % (num, n, cat, data_value))
- grass.message(_(" -- Skipping, point lays outside of cost_map. [Probably programmer error]"))
- n -= 1
- continue
+ grass.message(_(" -- Skipping, point lays outside of cost_map. [Probably programmer error]"))
+ n -= 1
+ continue
partial_n = tmp_base + 'partial.' + '%05d' % num
one_by_cost_site_sq = tmp_base + '1by_cost_site_sq.' + '%05d' % num
@@ -444,24 +444,24 @@
#"( $DATA_VALUE / $N ) * (1.0 - ( cost_sq_site.$NUM / sum_of_cost_sqs ))"
#"( cost_sq_site.$NUM / sum_of_cost_sqs ) * ( $DATA_VALUE / $N )"
- proc[num-1] = grass.mapcalc_start(
- "$partial_n = ($data * $one_by_cost_sq) / $sum_of_1by_cost_sqs",
+ proc[num-1] = grass.mapcalc_start(
+ "$partial_n = ($data * $one_by_cost_sq) / $sum_of_1by_cost_sqs",
partial_n = partial_n,
- data = data_value,
- one_by_cost_sq = one_by_cost_site_sq,
- sum_of_1by_cost_sqs = sum_of_1by_cost_sqs,
- quiet = True)
+ data = data_value,
+ one_by_cost_sq = one_by_cost_site_sq,
+ sum_of_1by_cost_sqs = sum_of_1by_cost_sqs,
+ quiet = True)
- # free up disk space ASAP
- #grass.run_command('g.remove', flags = 'f', type = 'raster', name = one_by_cost_site_sq, quiet = True)
+ # free up disk space ASAP
+ #grass.run_command('g.remove', flags = 'f', type = 'raster', name = one_by_cost_site_sq, quiet = True)
num += 1
if num > n:
- break
+ break
for i in range(n):
@@ -469,7 +469,7 @@
- pattern=tmp_base + '1by_cost_site_sq.*', quiet=True)
+ pattern=tmp_base + '1by_cost_site_sq.*', quiet=True)
