[GRASS-SVN] r73993 - grass/trunk/testsuite/examples
svn_grass at osgeo.org
Mon Jan 21 14:32:12 PST 2019
Author: neteler
Date: 2019-01-21 14:32:12 -0800 (Mon, 21 Jan 2019)
New Revision: 73993
Added:
grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf
grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
test_framework_GRASS_GIS_with_NC.sh: store configuration in separate file
Added: grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf
--- grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf (rev 0)
+++ grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf 2019-01-21 22:32:12 UTC (rev 73993)
@@ -0,0 +1,28 @@
+### CONFIGURATION
+# computer architecture:
+ARCH=x86_64-pc-linux-gnu
+# name of binary:
+GRASSBIN=grass77
+# source code directory as full path:
+GRASSSRC="$HOME/software/grass77"
+# temporary grassdata directory
+GRASSDATA="$HOME/grassdata/tests-grassdata"
+# Python binary to be used (python|python3)
+PYTHON=python
+# here we suppose default compilation settings of GRASS GIS and no 'make install'
+# may be no|yes
+COMPILE="no"
+# configure metascript with compiler flags:
+CONFIGURE="${GRASSSRC}/conf_grass7.sh"
+# directory to store reports, e.g. in a subdirectory
+REPORTS="testreports"
+# publish report on WWW Server (not needed for local tests)
+# may be no|yes
+PUBLISH="no"
+# upload WWW dir on server for report publication (not used for local tests)
+SERVERDIR="/var/www/html/grassgistestreports"
Modified: grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
--- grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh 2019-01-21 20:17:49 UTC (rev 73992)
+++ grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh 2019-01-21 22:32:12 UTC (rev 73993)
@@ -27,34 +27,9 @@
### CONFIGURATION
-# computer architecture:
-ARCH=x86_64-pc-linux-gnu
-# name of binary:
-GRASSBIN=grass77
-# source code directory as full path:
-GRASSSRC="$HOME/software/grass77"
-# temporary grassdata directory
-GRASSDATA="$HOME/grassdata/tests-grassdata"
-# Python binary to be used (python|python3)
-PYTHON=python
+source test_framework_GRASS_GIS_with_NC.conf
-# here we suppose default compilation settings of GRASS GIS and no 'make install'
-# may be no|yes
-COMPILE="no"
-# configure metascript with compiler flags:
-CONFIGURE="${GRASSSRC}/conf_grass7.sh"
-# directory to store reports, e.g. in a subdirectory
-REPORTS="testreports"
-# publish report on WWW Server (not needed for local tests)
-# may be no|yes
-PUBLISH="no"
-# upload WWW dir on server for report publication (not used for local tests)
-SERVERDIR="/var/www/html/grassgistestreports"
######### nothing to change below
set -e # fail fast
