[GRASS-SVN] r73996 - grass/trunk/testsuite/examples
svn_grass at osgeo.org
Tue Jan 22 01:11:26 PST 2019
Author: neteler
Date: 2019-01-22 01:11:26 -0800 (Tue, 22 Jan 2019)
New Revision: 73996
grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
test_framework_GRASS_GIS_with_NC.sh: make conf_file a parameter, add help text
Modified: grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
--- grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh 2019-01-22 02:51:33 UTC (rev 73995)
+++ grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh 2019-01-22 09:11:26 UTC (rev 73996)
@@ -26,10 +26,41 @@
-### CONFIGURATION
+### Fetch CONFIGURATION
-source test_framework_GRASS_GIS_with_NC.conf
+CONF="test_framework_GRASS_GIS_with_NC.conf"
+usage_msg(){
+echo "Usage:
+ $0 [conf_file]
+Example:
+ $0 ${CONF}
+if [ ! -z "$1" ] ; then
+ case "$1" in
+ -h | --h | -help | --help)
+ usage_msg
+ exit 0
+ if [ -f ${1} ] ; then
+ CONF="$1"
+ else
+ echo "ERROR: $1 is not a file"
+ exit 1
+ fi
+ esac
+else
+ usage_msg
+ exit 0
+fi
+source ${CONF}
######### nothing to change below
set -e # fail fast
