[GRASS-SVN] r74001 - grass/trunk/vector/v.out.lidar
svn_grass at osgeo.org
Tue Jan 22 06:37:00 PST 2019
Author: neteler
Date: 2019-01-22 06:37:00 -0800 (Tue, 22 Jan 2019)
New Revision: 74001
grass/trunk/vector/v.out.lidar/main.c
v.out.lidar: print names of column/table in error messages
Modified: grass/trunk/vector/v.out.lidar/main.c
--- grass/trunk/vector/v.out.lidar/main.c 2019-01-22 12:27:31 UTC (rev 74000)
+++ grass/trunk/vector/v.out.lidar/main.c 2019-01-22 14:37:00 UTC (rev 74001)
@@ -118,9 +118,11 @@
G_fatal_error(_("Column <%s> not found in table <%s>"),
column, f_info->table);
if (ctype != DB_C_TYPE_INT && ctype != DB_C_TYPE_DOUBLE)
- G_fatal_error(_("Only numeric column type is supported"));
+ G_fatal_error(_("Only numeric column type is supported (column <%s> in table <%s>)"),
+ column, f_info->table);
if (ctype == DB_C_TYPE_DOUBLE)
- G_warning(_("Double values will be converted to integers"));
+ G_warning(_("Double values will be converted to integers (column <%s> in table <%s>)"),
db_CatValArray_init(column_values);
int nrec =
