[GRASS-SVN] r74018 - grass-addons/grass7/raster/r.accumulate
Fri Jan 25 21:06:37 PST 2019
Author: hcho
Date: 2019-01-25 21:06:37 -0800 (Fri, 25 Jan 2019)
New Revision: 74018
   grass-addons/grass7/raster/r.accumulate/accumulate.c
   grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
   grass-addons/grass7/raster/r.accumulate/delineate_streams.c
   grass-addons/grass7/raster/r.accumulate/main.c
   grass-addons/grass7/raster/r.accumulate/r.accumulate.html
r.accumulate: run grass_indent.sh
Modified: grass-addons/grass7/raster/r.accumulate/accumulate.c
--- grass-addons/grass7/raster/r.accumulate/accumulate.c	2019-01-26 05:02:55 UTC (rev 74017)
+++ grass-addons/grass7/raster/r.accumulate/accumulate.c	2019-01-26 05:06:37 UTC (rev 74018)
@@ -12,7 +12,7 @@
     G_message(_("Accumulating flows..."));
     for (row = 0; row < rows; row++) {
-	G_percent(row, rows, 1);
+        G_percent(row, rows, 1);
         for (col = 0; col < cols; col++)
             trace_up(dir_buf, weight_buf, accum_buf, done, neg, row, col);
Modified: grass-addons/grass7/raster/r.accumulate/calculate_lfp.c
--- grass-addons/grass7/raster/r.accumulate/calculate_lfp.c	2019-01-26 05:02:55 UTC (rev 74017)
+++ grass-addons/grass7/raster/r.accumulate/calculate_lfp.c	2019-01-26 05:06:37 UTC (rev 74018)
@@ -54,7 +54,7 @@
         int col = (int)Rast_easting_to_col(outlet_pl->x[i], &window);
         int n;
-	G_percent(i, outlet_pl->n, 1);
+        G_percent(i, outlet_pl->n, 1);
         /* if the outlet is outside the computational region, skip */
         if (row < 0 || row >= rows || col < 0 || col >= cols) {
Modified: grass-addons/grass7/raster/r.accumulate/delineate_streams.c
--- grass-addons/grass7/raster/r.accumulate/delineate_streams.c	2019-01-26 05:02:55 UTC (rev 74017)
+++ grass-addons/grass7/raster/r.accumulate/delineate_streams.c	2019-01-26 05:06:37 UTC (rev 74018)
@@ -28,7 +28,7 @@
     /* loop through all cells to find headwater cells */
     G_message(_("Delineating streams..."));
         for (col = 0; col < cols; col++) {
             int i, j;
             int nup = 0;
Modified: grass-addons/grass7/raster/r.accumulate/main.c
--- grass-addons/grass7/raster/r.accumulate/main.c	2019-01-26 05:02:55 UTC (rev 74017)
+++ grass-addons/grass7/raster/r.accumulate/main.c	2019-01-26 05:06:37 UTC (rev 74018)
@@ -57,8 +57,8 @@
         struct Flag *conf;
     } flag;
     char *desc;
-    char *dir_name, *weight_name, *input_accum_name, *accum_name, *stream_name,
-	 *outlet_name, *lfp_name;
+    char *dir_name, *weight_name, *input_accum_name, *accum_name,
+        *stream_name, *outlet_name, *lfp_name;
     int dir_fd;
     double dir_format, thresh;
     struct Range dir_range;
@@ -339,12 +339,12 @@
         Vect_close(&Map);
-	if (driver) {
-	    if (n < outlet_pl.n)
-		G_fatal_error(_("Too few longest flow path IDs specified"));
-	    if (n > outlet_pl.n)
-		G_fatal_error(_("Too many longest flow path IDs specified"));
+        if (driver) {
+            if (n < outlet_pl.n)
+                G_fatal_error(_("Too few longest flow path IDs specified"));
+            if (n > outlet_pl.n)
+                G_fatal_error(_("Too many longest flow path IDs specified"));
     thresh = opt.thresh->answer ? atof(opt.thresh->answer) : 0.0;
@@ -361,7 +361,7 @@
     dir_buf.c = G_malloc(rows * sizeof(CELL *));
     G_message(_("Reading direction map..."));
         done[row] = G_calloc(cols, 1);
         dir_buf.c[row] = Rast_allocate_c_buf();
         Rast_get_c_row(dir_fd, dir_buf.c[row], row);
@@ -387,15 +387,15 @@
         weight_buf.rows = rows;
         weight_buf.cols = cols;
         weight_buf.map.v = (void **)G_malloc(rows * sizeof(void *));
-	G_message(_("Reading weight map..."));
+        G_message(_("Reading weight map..."));
             weight_buf.map.v[row] =
                 (void *)Rast_allocate_buf(weight_buf.type);
             Rast_get_row(weight_fd, weight_buf.map.v[row], row,
                          weight_buf.type);
-	G_percent(1, 1, 1);
+        G_percent(1, 1, 1);
         Rast_close(weight_fd);
     /* create non-weighted accumulation if input accumulation is not given */
@@ -407,20 +407,20 @@
         int accum_fd = Rast_open_old(input_accum_name, "");
         accum_buf.type = Rast_get_map_type(accum_fd);
-	G_message(_("Reading accumulation map..."));
+        G_message(_("Reading accumulation map..."));
             accum_buf.map.v[row] = (void *)Rast_allocate_buf(accum_buf.type);
             Rast_get_row(accum_fd, accum_buf.map.v[row], row, accum_buf.type);
         Rast_close(accum_fd);
     /* accumulate flows if input accumulation is not given */
     else {
-	for (row = 0; row < rows; row++)
-	    accum_buf.map.v[row] = (void *)Rast_allocate_buf(accum_buf.type);
-	accumulate(&dir_buf, &weight_buf, &accum_buf, done, neg);
+        for (row = 0; row < rows; row++)
+            accum_buf.map.v[row] = (void *)Rast_allocate_buf(accum_buf.type);
+        accumulate(&dir_buf, &weight_buf, &accum_buf, done, neg);
     /* write out buffer to the accumulatoin map if requested */
@@ -428,7 +428,7 @@
         int accum_fd = Rast_open_new(accum_name, accum_buf.type);
         struct History hist;
-	G_message(_("Writing accumulation map..."));
+        G_message(_("Writing accumulation map..."));
             Rast_put_row(accum_fd, accum_buf.map.v[row], accum_buf.type);
Modified: grass-addons/grass7/raster/r.accumulate/r.accumulate.html
--- grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2019-01-26 05:02:55 UTC (rev 74017)
+++ grass-addons/grass7/raster/r.accumulate/r.accumulate.html	2019-01-26 05:06:37 UTC (rev 74018)
@@ -38,7 +38,11 @@
 accumulation is calculated by single flow direction (SFD) routing and may not
 be comparable to the result from multiple flow direction (MFD) routing.
-<p>The module requires flow accumulation for any output, so it will internally accumulate flows every time it runs unless <b>input_accumulation</b> option is provided to save computational time by not repeating this process.  In this case, it is important to use flow accumulation consistent with the flow direction map (e.g., <b>accumulation</b> output from this module).
+<p>The module requires flow accumulation for any output, so it will internally
+accumulate flows every time it runs unless <b>input_accumulation</b> option is
+provided to save computational time by not repeating this process.  In this
+case, it is important to use flow accumulation consistent with the flow
+direction map (e.g., <b>accumulation</b> output from this module).
 <h3>Stream network delineation</h3>
