[GRASS-SVN] r74032 - in grass/trunk/lib/python: ctypes/ctypesgencore/parser gunittest
svn_grass at osgeo.org
Sun Jan 27 20:53:12 PST 2019
Author: annakrat
Date: 2019-01-27 20:53:12 -0800 (Sun, 27 Jan 2019)
New Revision: 74032
grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
grass/trunk/lib/python/gunittest/invoker.py
grass/trunk/lib/python/gunittest/multirunner.py
gunittest: first part of fixes for #3737
Modified: grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py
--- grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py 2019-01-27 20:56:28 UTC (rev 74031)
+++ grass/trunk/lib/python/ctypes/ctypesgencore/parser/lextab.py 2019-01-28 04:53:12 UTC (rev 74032)
@@ -1,8 +1,8 @@
# lextab.py. This file automatically created by PLY (version 2.2). Don't edit!
-_lextokens = {'PP_END_DEFINE': None, 'DIV_ASSIGN': None, 'AND_OP': None, 'PERIOD': None, 'PTR_OP': None, 'PP_MACRO_PARAM': None, 'OTHER': None, 'IDENTIFIER': None, 'PP_STRINGIFY': None, 'XOR_ASSIGN': None, 'PP_DEFINE_NAME': None, 'ELLIPSIS': None, 'INC_OP': None, 'GE_OP': None, 'LEFT_ASSIGN': None, 'MUL_ASSIGN': None, 'RIGHT_ASSIGN': None, 'SUB_ASSIGN': None, 'LPAREN': None, 'PP_IDENTIFIER_PASTE': None, 'PP_DEFINE': None, 'OR_ASSIGN': None, 'ADD_ASSIGN': None, 'HEADER_NAME': None, 'LE_OP': None, 'LEFT_OP': None, 'PP_NUMBER': None, 'DEC_OP': None, 'RIGHT_OP': None, 'MOD_ASSIGN': None, 'STRING_LITERAL': None, 'EQ_OP': None, 'OR_OP': None, 'AND_ASSIGN': None, 'CHARACTER_CONSTANT': None, 'PP_DEFINE_MACRO_NAME': None, 'NE_OP': None, 'NEWLINE': None}
+_lextokens = {'LE_OP': None, 'DEC_OP': None, 'DIV_ASSIGN': None, 'XOR_ASSIGN': None, 'CHARACTER_CONSTANT': None, 'PP_IDENTIFIER_PASTE': None, 'PP_MACRO_PARAM': None, 'HEADER_NAME': None, 'STRING_LITERAL': None, 'OTHER': None, 'RIGHT_ASSIGN': None, 'PERIOD': None, 'PP_DEFINE': None, 'LEFT_ASSIGN': None, 'AND_OP': None, 'PP_NUMBER': None, 'PP_DEFINE_MACRO_NAME': None, 'ADD_ASSIGN': None, 'PP_END_DEFINE': None, 'EQ_OP': None, 'OR_OP': None, 'OR_ASSIGN': None, 'MOD_ASSIGN': None, 'ELLIPSIS': None, 'AND_ASSIGN': None, 'LEFT_OP': None, 'NE_OP': None, 'RIGHT_OP': None, 'GE_OP': None, 'NEWLINE': None, 'INC_OP': None, 'SUB_ASSIGN': None, 'PTR_OP': None, 'LPAREN': None, 'PP_STRINGIFY': None, 'MUL_ASSIGN': None, 'IDENTIFIER': None, 'PP_DEFINE_NAME': None}
_lexreflags = 0
_lexliterals = ''
_lexstateinfo = {'DEFINE': 'exclusive', 'INITIAL': 'inclusive'}
-_lexstatere = {'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\|=|\\+=|>>=|\\^=|<<=|\\)|-=|<%|<<|%>|\\+|>>|<=|/=|->|!=|&&|\\*|\\[|\\?|--|>=|\\.|:>|&=|==|<:|%=|\\||\\^|/|:|{|~|,|>|-|%|}|;|!|=|&|]|<))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t
_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])], 'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\|\\||\\+\\+|\\*=|\\|=|\\+=|>>=|\\^=|<<=|\\)|-=|<%|<<|%>|\\+|>>|<=|/=|->|!=|&&|\\*|\\[|\\?|--|>=|\\.|:>|&=|==|<:|%=|\\||\\^|/|:|{|~|,|>|-|%|}|;|!|=|&|]|<))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t
_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_INITIAL_newline>\\n)|(?P<t_INITIAL_pp_define>\\#define)', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_INITIAL_newline', 'INITIAL_newline'), ('t_INITIAL_pp_define', 'INITIAL_pp_define')])]}
+_lexstatere = {'DEFINE': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\+\\+|\\|\\||\\|=|\\*=|\\^=|>>=|\\+=|<<=|/=|:>|<:|->|&&|\\+|<=|!=|\\.|\\?|\\[|\\*|&=|\\^|\\)|--|==|>=|%=|>>|<<|%>|-=|\\||<%|~|<|;|/|!|&|}|>|,|:|]|{|%|=|-))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_DEFINE_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_DEFINE_identifier', 'DEFINE_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t_ANY_int>(?P<p1>(?:0x[a-fA-F0-9]+)|(?:[0-9]+))(?P<suf>[uUlL]*))', [None, ('t_ANY_int', 'ANY_int'), None, None]), ('(?P<t_ANY_character_constant>L?\'(\\\\.|[^\\\\\'])+\')|(?P<t_ANY_string_literal>L?"(\\\\.|[^\\\\"])*")|(?P<t_ANY_lparen>\\()|(?P<t_DEFINE_newline>\\n)|(?P<t
_DEFINE_pp_param_op>(\\#\\#)|(\\#))', [None, ('t_ANY_character_constant', 'ANY_character_constant'), None, ('t_ANY_string_literal', 'ANY_string_literal'), None, ('t_ANY_lparen', 'ANY_lparen'), ('t_DEFINE_newline', 'DEFINE_newline'), ('t_DEFINE_pp_param_op', 'DEFINE_pp_param_op')])], 'INITIAL': [('(?P<t_ANY_directive>\\#\\s+(\\d+)\\s+"([^"]+)"[ \\d]*\\n)|(?P<t_ANY_punctuator>(\\.\\.\\.|\\+\\+|\\|\\||\\|=|\\*=|\\^=|>>=|\\+=|<<=|/=|:>|<:|->|&&|\\+|<=|!=|\\.|\\?|\\[|\\*|&=|\\^|\\)|--|==|>=|%=|>>|<<|%>|-=|\\||<%|~|<|;|/|!|&|}|>|,|:|]|{|%|=|-))', [None, ('t_ANY_directive', 'ANY_directive'), None, None, ('t_ANY_punctuator', 'ANY_punctuator')]), ('(?P<t_INITIAL_identifier>[a-zA-Z_]([a-zA-Z_]|[0-9])*)', [None, ('t_INITIAL_identifier', 'INITIAL_identifier')]), ('(?P<t_ANY_float>(?P<p1>[0-9]+)?(?P<dp>[.]?)(?P<p2>(?(p1)[0-9]*|[0-9]+))(?P<exp>(?:[Ee][+-]?[0-9]+)?)(?P<suf>([FfLl]|d[dfl]|D[DFL]|[fFdD][0-9]+x?)?)(?!\\w))', [None, ('t_ANY_float', 'ANY_float'), None, None, None, None, None]), ('(?P<t
_lexstateignore = {'DEFINE': ' \t\x0b\x0c\r', 'INITIAL': ' \t\x0b\x0c\r'}
_lexstateerrorf = {'DEFINE': 't_DEFINE_error', 'INITIAL': 't_INITIAL_error'}
Modified: grass/trunk/lib/python/gunittest/invoker.py
--- grass/trunk/lib/python/gunittest/invoker.py 2019-01-27 20:56:28 UTC (rev 74031)
+++ grass/trunk/lib/python/gunittest/invoker.py 2019-01-28 04:53:12 UTC (rev 74032)
@@ -161,9 +161,11 @@
# ignoring shebang line to use current Python
# and also pass parameters to it
# add also '-Qwarn'?
- p = subprocess.Popen([sys.executable, '-tt', '-3',
- module.abs_file_path],
- cwd=cwd, env=env,
+ if sys.version_info.major >= 3:
+ args = [sys.executable, '-tt', module.abs_file_path]
+ else:
+ args = [sys.executable, '-tt', '-3', module.abs_file_path]
+ p = subprocess.Popen(args, cwd=cwd, env=env,
stdout=stdout, stderr=stderr)
elif module.file_type == 'sh':
# ignoring shebang line to pass parameters to shell
Modified: grass/trunk/lib/python/gunittest/multirunner.py
--- grass/trunk/lib/python/gunittest/multirunner.py 2019-01-27 20:56:28 UTC (rev 74031)
+++ grass/trunk/lib/python/gunittest/multirunner.py 2019-01-28 04:53:12 UTC (rev 74032)
@@ -16,8 +16,51 @@
import argparse
import itertools
import subprocess
+import locale
+try:
+ from itertools import izip as zip
+except ImportError: # will be 3.x series
+ pass
+if sys.version_info.major >= 3:
+ unicode = str
+def _get_encoding():
+ encoding = locale.getdefaultlocale()[1]
+ if not encoding:
+ encoding = 'UTF-8'
+ return encoding
+def decode(bytes_, encoding=None):
+ if isinstance(bytes_, bytes):
+ return bytes_.decode(_get_encoding())
+ else:
+ return bytes_
+def encode(string, encoding=None):
+ if isinstance(string, unicode):
+ return string.encode(_get_encoding())
+ else:
+ return string
+def text_to_string(text):
+ """Convert text to str. Useful when passing text into environments,
+ in Python 2 it needs to be bytes on Windows, in Python 3 in needs unicode.
+ if sys.version[0] == '2':
+ # Python 2
+ return encode(text)
+ else:
+ # Python 3
+ return decode(text)
def main():
parser = argparse.ArgumentParser(
description='Run tests with new')
@@ -70,10 +113,10 @@
if p.returncode != 0:
print("ERROR: Cannot find GRASS GIS 7 start script (%s):\n%s" % (startcmd, err), file=sys.stderr)
return 1
- gisbase = out.strip('\n')
+ gisbase = decode(out.strip())
# set GISBASE environment variable
- os.environ['GISBASE'] = gisbase
+ os.environ['GISBASE'] = text_to_string(gisbase)
# define GRASS Python environment
grass_python_dir = os.path.join(gisbase, "etc", "python")
sys.path.append(grass_python_dir)
@@ -82,7 +125,7 @@
# define GRASS DATABASE
# Set GISDBASE environment variable
- os.environ['GISDBASE'] = gisdb
+ os.environ['GISDBASE'] = text_to_string(gisdb)
# import GRASS Python package for initialization
import grass.script.setup as gsetup
@@ -95,7 +138,7 @@
gsetup.init(gisbase, gisdb, location, mapset)
reports = []
- for location, location_type in itertools.izip(locations, locations_types):
+ for location, location_type in zip(locations, locations_types):
# here it is quite a good place to parallelize
# including also type to make it unique and preserve it for sure
report = 'report_for_' + location + '_' + location_type
