[GRASS-SVN] r74038 - in grass/branches/releasebranch_7_6: . mswindows mswindows/osgeo4w
svn_grass at osgeo.org
Mon Jan 28 01:56:40 PST 2019
Author: martinl
Date: 2019-01-28 01:56:40 -0800 (Mon, 28 Jan 2019)
New Revision: 74038
grass/branches/releasebranch_7_6/configure
grass/branches/releasebranch_7_6/configure.in
grass/branches/releasebranch_7_6/mswindows/GRASS-Installer.nsi.tmpl
grass/branches/releasebranch_7_6/mswindows/GRASS-Packager.bat.tmpl
grass/branches/releasebranch_7_6/mswindows/Makefile
grass/branches/releasebranch_7_6/mswindows/osgeo4w/env.bat.tmpl
grass/branches/releasebranch_7_6/mswindows/osgeo4w/grass.bat.tmpl
grass/branches/releasebranch_7_6/mswindows/osgeo4w/package.sh
grass/branches/releasebranch_7_6/mswindows/osgeo4w/postinstall.bat
grass/branches/releasebranch_7_6/mswindows/osgeo4w/preremove.bat
wingrass: change instalation target, see #3732 (g76: merge r74027:74029 from trunk)
Modified: grass/branches/releasebranch_7_6/configure
--- grass/branches/releasebranch_7_6/configure 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/configure 2019-01-28 09:56:40 UTC (rev 74038)
@@ -1448,7 +1448,7 @@
if test -n "$MACOSX_APP" ; then
INSTDIR='${prefix}'"/GRASS-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.app/Contents/MacOS"
else
- INSTDIR='${prefix}'"/grass-${GRASS_VERSION_MAJOR}.${GRASS_VERSION_MINOR}.${GRASS_VERSION_RELEASE}"
+ INSTDIR='${prefix}'"/grass${GRASS_VERSION_MAJOR}${GRASS_VERSION_MINOR}"
fi
@@ -12715,58 +12715,7 @@
fi
fi
-for ac_declaration in \
- '#include <stdlib.h>' \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
- cat > conftest.$ac_ext <<EOF
-#line 12729 "configure"
-#include "confdefs.h"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12737: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
- echo "configure: failed program was:" >&5
- cat conftest.$ac_ext >&5
- rm -rf conftest*
- continue
-fi
-rm -f conftest*
-#line 12747 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12754: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
- rm -rf conftest*
- break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
CXX=
CXXFLAGS=
@@ -12779,7 +12728,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12783: checking whether to use openDWG" >&5
+echo "configure:12732: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12799,7 +12748,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12803: checking for location of openDGW includes" >&5
+echo "configure:12752: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12825,15 +12774,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:12829: checking for $ac_hdr" >&5
+echo "configure:12778: checking for $ac_hdr" >&5
-#line 12832 "configure"
+#line 12781 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12786: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12867,7 +12816,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12871: checking for location of openDWG library" >&5
+echo "configure:12820: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12908,7 +12857,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12912: checking whether to use POSIX threads" >&5
+echo "configure:12861: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12928,7 +12877,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12932: checking for location of POSIX threads includes" >&5
+echo "configure:12881: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12954,15 +12903,15 @@
do
-echo "configure:12958: checking for $ac_hdr" >&5
+echo "configure:12907: checking for $ac_hdr" >&5
-#line 12961 "configure"
+#line 12910 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12966: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12996,7 +12945,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:13000: checking for location of POSIX threads library" >&5
+echo "configure:12949: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -13021,10 +12970,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:13025: checking for pthread_create" >&5
+echo "configure:12974: checking for pthread_create" >&5
-#line 13028 "configure"
+#line 12977 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char pthread_create(); below. */
@@ -13047,7 +12996,7 @@
; return 0; }
EOF
-if { (eval echo configure:13051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -13074,13 +13023,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13078: checking for pthread_create in -lpthread" >&5
+echo "configure:13027: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 13084 "configure"
+#line 13033 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13091,7 +13040,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:13095: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13141,7 +13090,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13145: checking whether to use OpenMP" >&5
+echo "configure:13094: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -13162,7 +13111,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13166: checking for location of OpenMP includes" >&5
+echo "configure:13115: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -13188,15 +13137,15 @@
do
-echo "configure:13192: checking for $ac_hdr" >&5
+echo "configure:13141: checking for $ac_hdr" >&5
-#line 13195 "configure"
+#line 13144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13200: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13234,7 +13183,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:13238: checking for location of OpenMP library" >&5
+echo "configure:13187: checking for location of OpenMP library" >&5
case "$with_openmp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -13259,10 +13208,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:13263: checking for GOMP_parallel_start" >&5
+echo "configure:13212: checking for GOMP_parallel_start" >&5
-#line 13266 "configure"
+#line 13215 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -13285,7 +13234,7 @@
; return 0; }
EOF
-if { (eval echo configure:13289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -13312,13 +13261,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:13316: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:13265: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 13322 "configure"
+#line 13271 "configure"
@@ -13329,7 +13278,7 @@
; return 0; }
EOF
-if { (eval echo configure:13333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13402,7 +13351,7 @@
echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13406: checking whether to use OpenCL" >&5
+echo "configure:13355: checking whether to use OpenCL" >&5
echo "$ac_t"""$with_opencl"" 1>&6
case "$with_opencl" in
"no") USE_OPENCL= ;;
@@ -13422,7 +13371,7 @@
echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13426: checking for location of OpenCL includes" >&5
+echo "configure:13375: checking for location of OpenCL includes" >&5
case "$with_opencl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13449,15 +13398,15 @@
do
-echo "configure:13453: checking for $ac_hdr" >&5
+echo "configure:13402: checking for $ac_hdr" >&5
-#line 13456 "configure"
+#line 13405 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13461: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13410: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13497,10 +13446,10 @@
LIBS="-framework OpenCL $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13501: checking for clGetPlatformInfo" >&5
+echo "configure:13450: checking for clGetPlatformInfo" >&5
-#line 13504 "configure"
+#line 13453 "configure"
which can conflict with char clGetPlatformInfo(); below. */
@@ -13523,7 +13472,7 @@
; return 0; }
EOF
-if { (eval echo configure:13527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_clGetPlatformInfo=yes"
else
@@ -13562,15 +13511,15 @@
do
-echo "configure:13566: checking for $ac_hdr" >&5
+echo "configure:13515: checking for $ac_hdr" >&5
-#line 13569 "configure"
+#line 13518 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13574: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13603,7 +13552,7 @@
# With OpenCL library directory
echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13607: checking for location of OpenCL library" >&5
+echo "configure:13556: checking for location of OpenCL library" >&5
case "$with_opencl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13627,13 +13576,13 @@
echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13631: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13580: checking for clGetPlatformInfo in -lOpenCL" >&5
ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
LIBS="-lOpenCL $LIBS"
-#line 13637 "configure"
+#line 13586 "configure"
@@ -13644,7 +13593,7 @@
clGetPlatformInfo()
; return 0; }
EOF
-if { (eval echo configure:13648: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13704,7 +13653,7 @@
fi
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13708: checking for special C compiler options needed for large files" >&5
+echo "configure:13657: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -13712,7 +13661,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 13716 "configure"
+#line 13665 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -13728,7 +13677,7 @@
; return 0; }
EOF
-if { (eval echo configure:13732: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13681: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13737,7 +13686,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 13741 "configure"
+#line 13690 "configure"
@@ -13753,7 +13702,7 @@
; return 0; }
EOF
-if { (eval echo configure:13757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13706: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13780,11 +13729,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13784: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13733: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13788 "configure"
+#line 13737 "configure"
@@ -13800,7 +13749,7 @@
; return 0; }
EOF
-if { (eval echo configure:13804: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13753: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13807,7 +13756,7 @@
rm -rf conftest*
-#line 13811 "configure"
+#line 13760 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13825,7 +13774,7 @@
; return 0; }
EOF
-if { (eval echo configure:13829: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13778: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13851,11 +13800,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13855: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13804: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13859 "configure"
+#line 13808 "configure"
@@ -13871,7 +13820,7 @@
; return 0; }
EOF
-if { (eval echo configure:13875: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13824: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13878,7 +13827,7 @@
rm -rf conftest*
-#line 13882 "configure"
+#line 13831 "configure"
#define _LARGE_FILES 1
@@ -13896,7 +13845,7 @@
; return 0; }
EOF
-if { (eval echo configure:13900: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13849: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13922,11 +13871,11 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13926: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13875: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13930 "configure"
+#line 13879 "configure"
#include <stdio.h>
int main() {
@@ -13933,7 +13882,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13937: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13886: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13940,7 +13889,7 @@
rm -rf conftest*
-#line 13944 "configure"
+#line 13893 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13949,7 +13898,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13953: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13902: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13981,11 +13930,11 @@
ac_save_cflags=${CFLAGS}
CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13985: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13934: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13989 "configure"
+#line 13938 "configure"
#include <stdio.h>
int main() {
@@ -13992,7 +13941,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13945: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -13999,7 +13948,7 @@
rm -rf conftest*
-#line 14003 "configure"
+#line 13952 "configure"
#include <stdio.h>
@@ -14008,7 +13957,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:14012: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -14038,11 +13987,11 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:14042: checking for fseeko" >&5
+echo "configure:13991: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 14046 "configure"
+#line 13995 "configure"
#include <stdio.h>
int main() {
@@ -14049,7 +13998,7 @@
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:14053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -14066,10 +14015,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14070: checking if system supports Large Files at all" >&5
+echo "configure:14019: checking if system supports Large Files at all" >&5
-#line 14073 "configure"
+#line 14022 "configure"
#include <stdio.h>
@@ -14101,7 +14050,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:14105: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
Modified: grass/branches/releasebranch_7_6/configure.in
--- grass/branches/releasebranch_7_6/configure.in 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/configure.in 2019-01-28 09:56:40 UTC (rev 74038)
@@ -216,7 +216,7 @@
else
fi
AC_SUBST(INSTDIR)
Modified: grass/branches/releasebranch_7_6/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_7_6/mswindows/GRASS-Installer.nsi.tmpl 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/GRASS-Installer.nsi.tmpl 2019-01-28 09:56:40 UTC (rev 74038)
@@ -29,7 +29,7 @@
!endif
!define BINARY_REVISION "1"
!define VERSION_NUMBER "@GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@"
-!define GRASS_BASE "GRASS GIS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR at .@GRASS_VERSION_RELEASE@"
+!define GRASS_BASE "GRASS GIS @GRASS_VERSION_MAJOR at .@GRASS_VERSION_MINOR@"
!if ${INSTALLER_TYPE} == "Release"
!define GRASS_COMMAND "grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@"
!else
Modified: grass/branches/releasebranch_7_6/mswindows/GRASS-Packager.bat.tmpl
--- grass/branches/releasebranch_7_6/mswindows/GRASS-Packager.bat.tmpl 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/GRASS-Packager.bat.tmpl 2019-01-28 09:56:40 UTC (rev 74038)
@@ -23,7 +23,7 @@
set MSYS_BLD_DIR=C:\msys%1\mingw%1
-set GRASS_PREFIX=%OSGEO4W_BLD_DIR%\apps\grass\grass- at GRASS_VERSION_MAJOR@. at GRASS_VERSION_MINOR@. at GRASS_VERSION_RELEASE@
+set GRASS_PREFIX=%OSGEO4W_BLD_DIR%\apps\grass\grass at GRASS_VERSION_MAJOR@@GRASS_VERSION_MINOR@
@echo.
@echo -----------------------------------------------------------------------------------------------------------------------
Modified: grass/branches/releasebranch_7_6/mswindows/Makefile
--- grass/branches/releasebranch_7_6/mswindows/Makefile 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/Makefile 2019-01-28 09:56:40 UTC (rev 74038)
@@ -17,7 +17,6 @@
sed \
-e 's#@GRASS_VERSION_MAJOR@#$(GRASS_VERSION_MAJOR)#' \
-e 's#@GRASS_VERSION_MINOR@#$(GRASS_VERSION_MINOR)#' \
- -e 's#@GRASS_VERSION_RELEASE@#$(GRASS_VERSION_RELEASE)#' \
GRASS-Installer.nsi: GRASS-Installer.nsi.tmpl
Modified: grass/branches/releasebranch_7_6/mswindows/osgeo4w/env.bat.tmpl
--- grass/branches/releasebranch_7_6/mswindows/osgeo4w/env.bat.tmpl 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/osgeo4w/env.bat.tmpl 2019-01-28 09:56:40 UTC (rev 74038)
@@ -2,7 +2,7 @@
REM Environmental variables for GRASS OSGeo4W installer
REM
-set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@
+set GISBASE=%OSGEO4W_ROOT%\apps\grass\grass at POSTFIX@
REM Uncomment if you want to use Bash instead of Cmd
REM Note that msys package must be also installed
Modified: grass/branches/releasebranch_7_6/mswindows/osgeo4w/grass.bat.tmpl
--- grass/branches/releasebranch_7_6/mswindows/osgeo4w/grass.bat.tmpl 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/osgeo4w/grass.bat.tmpl 2019-01-28 09:56:40 UTC (rev 74038)
@@ -9,7 +9,7 @@
rem Set environmental variables
rem
call "%~dp0\o4w_env.bat"
-call "%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\etc\env.bat"
+call "%OSGEO4W_ROOT%\apps\grass\grass at POSTFIX@\etc\env.bat"
@echo off
rem
Modified: grass/branches/releasebranch_7_6/mswindows/osgeo4w/package.sh
--- grass/branches/releasebranch_7_6/mswindows/osgeo4w/package.sh 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/osgeo4w/package.sh 2019-01-28 09:56:40 UTC (rev 74038)
@@ -85,7 +85,8 @@
read MINOR <&3
read PATCH <&3
-export VERSION=$MAJOR.$MINOR.$PATCH
+export VERSION=${MAJOR}.${MINOR}.${PATCH}
+export POSTFIX=${MAJOR}${MINOR}
if [[ "$PATCH" == *svn* ]] ; then
GRASS_EXECUTABLE=grass${MAJOR}${MINOR}svn
@@ -208,25 +209,25 @@
rm -f diib*
log prepare packaging
-mv $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h \
- $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h.mingw
-cp mswindows/osgeo4w/config.h.switch $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass/config.h
-cp mswindows/osgeo4w/config.h.vc $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/include/grass
+mv $OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/include/grass/config.h \
+ $OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/include/grass/config.h.mingw
+cp mswindows/osgeo4w/config.h.switch $OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/include/grass/config.h
+cp mswindows/osgeo4w/config.h.vc $OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/include/grass
mkdir -p $OSGEO4W_ROOT_MSYS/etc/preremove $OSGEO4W_ROOT_MSYS/etc/postinstall
-sed -e "s#@VERSION@#$VERSION#g" -e "s#@OSGEO4W_ROOT@#$OSGEO4W_ROOT#g" -e "s#@POSTFIX@#$MAJOR$MINOR#g" \
+sed -e "s#@POSTFIX@#$POSTFIX#g" \
mswindows/osgeo4w/grass.bat.tmpl >$OSGEO4W_ROOT_MSYS/bin/${GRASS_EXECUTABLE}.bat
-sed -e "s#@VERSION@#$VERSION#g" -e "s#@OSGEO4W_ROOT_MSYS@#$OSGEO4W_ROOT#g" \
- mswindows/osgeo4w/env.bat.tmpl >$OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/etc/env.bat
-sed -e "s#@VERSION@#$VERSION#g" -e "s#@GRASS_EXECUTABLE@#$GRASS_EXECUTABLE#g" \
+ mswindows/osgeo4w/env.bat.tmpl >$OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/etc/env.bat
+sed -e "s#@POSTFIX@#$POSTFIX#g" -e "s#@VERSION@#$VERSION#g" -e "s#@GRASS_EXECUTABLE@#$GRASS_EXECUTABLE#g" \
mswindows/osgeo4w/postinstall.bat >$OSGEO4W_ROOT_MSYS/etc/postinstall/grass${PACKAGE_POSTFIX}.bat
mswindows/osgeo4w/preremove.bat >$OSGEO4W_ROOT_MSYS/etc/preremove/grass${PACKAGE_POSTFIX}.bat
if [ -n "$PACKAGE_PATCH" ]; then
log building vc libraries
OSGEO4W_POSTFIX=$OSGEO4W_POSTFIX sh \
- mswindows/osgeo4w/mklibs.sh $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib/*.$VERSION.dll
- mv mswindows/osgeo4w/vc/grass*.lib $OSGEO4W_ROOT_MSYS/apps/grass/grass-$VERSION/lib
+ mswindows/osgeo4w/mklibs.sh $OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/lib/*.$VERSION.dll
+ mv mswindows/osgeo4w/vc/grass*.lib $OSGEO4W_ROOT_MSYS/apps/grass/grass$POSTFIX/lib
log creating package
mkdir -p mswindows/osgeo4w/package
@@ -236,8 +237,7 @@
cd $OSGEO4W_ROOT_MSYS
# update startup script
- sed -e "s#@VERSION@#$VERSION#g" -e "s#@OSGEO4W_ROOT@#$OSGEO4W_ROOT#g" \
- -e "s#@POSTFIX@#$MAJOR$MINOR#g" \
+ sed -e "s#@POSTFIX@#$POSTFIX#g" \
$SRC/mswindows/osgeo4w/grass.bat.tmpl > bin/${GRASS_EXECUTABLE}.bat.tmpl
# bat files - unix2dos
@@ -266,13 +266,13 @@
/mingw${MINGW_POSTFIX}/bin/libtre-5.dll \
/mingw${MINGW_POSTFIX}/bin/zlib1.dll \
/mingw${MINGW_POSTFIX}/bin/libstdc++-6.dll \
- apps/grass/grass-$VERSION/bin
+ apps/grass/grass$POSTFIX/bin
cp -uv /mingw${MINGW_POSTFIX}/etc/fonts/fonts.conf \
- apps/grass/grass-$VERSION/etc
+ apps/grass/grass$POSTFIX/etc
# creating grass package
tar -cjf $PDIR/grass$PACKAGE_POSTFIX-$VERSION-$PACKAGE_PATCH.tar.bz2 \
- apps/grass/grass-$VERSION \
+ apps/grass/grass$POSTFIX \
bin/${GRASS_EXECUTABLE}.bat.tmpl \
etc/postinstall/grass${PACKAGE_POSTFIX}.bat \
Modified: grass/branches/releasebranch_7_6/mswindows/osgeo4w/postinstall.bat
--- grass/branches/releasebranch_7_6/mswindows/osgeo4w/postinstall.bat 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/osgeo4w/postinstall.bat 2019-01-28 09:56:40 UTC (rev 74038)
@@ -1,7 +1,7 @@
-set ICON=%OSGEO4W_ROOT%\apps\grass\grass- at VERSION@\gui\icons\grass_osgeo.ico
+set ICON=%OSGEO4W_ROOT%\apps\grass\grass at POSTFIX@\gui\icons\grass_osgeo.ico
set BATCH=%OSGEO4W_ROOT%\bin\@GRASS_EXECUTABLE at .bat
textreplace -std -t "%BATCH%"
-textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\grass- at VERSION@\etc\fontcap
+textreplace -std -t "%OSGEO4W_ROOT%"\apps\grass\grass- at POSTFIX@\etc\fontcap
xxmklink "%OSGEO4W_STARTMENU%\GRASS GIS @VERSION at .lnk" "%BATCH%" "--gui" \ "Launch GRASS GIS @VERSION@" 1 "%ICON%"
xxmklink "%ALLUSERSPROFILE%\Desktop\GRASS GIS @VERSION at .lnk" "%BATCH%" "--gui" \ "Launch GRASS GIS @VERSION@" 1 "%ICON%"
@@ -10,7 +10,7 @@
rem an OSGeo4W installation for updating paths to fonts
rem set gisbase
rem set path to freetype dll and its dependencies
set FREETYPEBASE=%OSGEO4W_ROOT%\bin;%OSGEO4W_ROOT%\apps\msys\bin;%GISBASE%\lib
Modified: grass/branches/releasebranch_7_6/mswindows/osgeo4w/preremove.bat
--- grass/branches/releasebranch_7_6/mswindows/osgeo4w/preremove.bat 2019-01-28 09:48:16 UTC (rev 74037)
+++ grass/branches/releasebranch_7_6/mswindows/osgeo4w/preremove.bat 2019-01-28 09:56:40 UTC (rev 74038)
@@ -2,4 +2,4 @@
del "%ALLUSERSPROFILE%\Desktop\GRASS GIS @VERSION at .lnk"
del "%OSGEO4W_ROOT%\bin\@GRASS_EXECUTABLE at .bat"
-del "%OSGEO4W_ROOT%"\apps\grass\grass- at VERSION@\etc\fontcap
+del "%OSGEO4W_ROOT%"\apps\grass\grass at POSTFIX@\etc\fontcap
