[GRASS-SVN] r74052 - grass-addons/grass7/raster/r.viewshed.cva
svn_grass at osgeo.org
Thu Jan 31 19:31:52 PST 2019
Author: annakrat
Date: 2019-01-31 19:31:51 -0800 (Thu, 31 Jan 2019)
New Revision: 74052
grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
r.viewshed.cva: fix cases when points have the same category, fix when using -b flag
Modified: grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py
--- grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py 2019-01-31 14:40:52 UTC (rev 74051)
+++ grass-addons/grass7/raster/r.viewshed.cva/r.viewshed.cva.py 2019-02-01 03:31:51 UTC (rev 74052)
@@ -85,7 +85,7 @@
#%flag
#% key: k
-#% description: Keep all interim viewshed maps produced by the routine (maps will be named "vshed_'name'", where 'name' is the value in "name_column" for each input point. If no value specified in "name_column", cat value will be used instead)
+#% description: Keep all interim viewshed maps produced by the routine (maps will be named "vshed_'name'_uniquenumber", where 'name' is the value in "name_column" for each input point. If no value specified in "name_column", cat value will be used instead)
#%end
#%flag
@@ -153,6 +153,7 @@
# now, loop through the master list and run r.viewshed for each of the sites,
# and append the viewsheds to a list (so we can work with them later)
vshed_list = []
+ counter = 0
for site in masterlist:
if flags['k'] and options["name_column"] is not '':
ptname = site[3]
@@ -159,14 +160,18 @@
else:
ptname = site[2]
grass.verbose(_('Calculating viewshed for location %s,%s (point name = %s)') % (site[0], site[1], ptname))
- tempry = "vshed_%s" % ptname
+ # need additional number for cases when points have the same category (e.g. from v.to.points)
+ tempry = "vshed_{ptname}_{c}".format(ptname=ptname, c=counter)
+ counter += 1
vshed_list.append(tempry)
grass.run_command("r.viewshed", quiet=True, overwrite=grass.overwrite(), flags=flagstring,
input=elev, output=tempry, coordinates=site[0] + "," + site[1], **viewshed_options)
# now make a mapcalc statement to add all the viewsheds together to make the outout cumulative viewsheds map
grass.message(_("Calculating \"Cumulative Viewshed\" map"))
+ # when binary viewshed, r.series has to use sum instead of count
+ rseries_method = 'sum' if 'b' in flagstring else 'count'
grass.run_command("r.series", quiet=True, overwrite=grass.overwrite(),
- input=(",").join(vshed_list), output=out, method="count")
+ input=(",").join(vshed_list), output=out, method=rseries_method)
# Clean up temporary maps, if requested
if flags['k']:
grass.message(_("Temporary viewshed maps will not removed"))
