[GRASS-SVN] r74146 - grass/branches/releasebranch_7_6/vector/v.external
svn_grass at osgeo.org
Fri Mar 1 11:48:05 PST 2019
Author: mmetz
Date: 2019-03-01 11:48:05 -0800 (Fri, 01 Mar 2019)
New Revision: 74146
grass/branches/releasebranch_7_6/vector/v.external/dsn.c
grass/branches/releasebranch_7_6/vector/v.external/main.c
v.external: enable GRASS-internal PostGIS driver again (backport trunk r74145)
Modified: grass/branches/releasebranch_7_6/vector/v.external/dsn.c
--- grass/branches/releasebranch_7_6/vector/v.external/dsn.c 2019-03-01 19:47:21 UTC (rev 74145)
+++ grass/branches/releasebranch_7_6/vector/v.external/dsn.c 2019-03-01 19:48:05 UTC (rev 74146)
@@ -8,12 +8,6 @@
char *dsn;
- dsn = G_store(opt_dsn);
- return dsn;
- /* OGR dsn and GRASS db connections are independent of each other */
if (G_strncasecmp(opt_dsn, "PG:", 3) == 0) {
/* PostgreSQL/PostGIS */
size_t i;
Modified: grass/branches/releasebranch_7_6/vector/v.external/main.c
--- grass/branches/releasebranch_7_6/vector/v.external/main.c 2019-03-01 19:47:21 UTC (rev 74145)
+++ grass/branches/releasebranch_7_6/vector/v.external/main.c 2019-03-01 19:48:05 UTC (rev 74146)
@@ -101,12 +101,8 @@
dsn = NULL;
- /* disabling GRASS-PostGIS driver:
- * TODO: a new fn that converts OGR dsn to PQ connection info,
- * ignoring current GRASS db connection */
- use_ogr = TRUE;
if (options.dsn->answer)
- dsn = G_store(options.dsn->answer);
+ dsn = get_datasource_name(options.dsn->answer, use_ogr);
if (flags.list->answer || flags.tlist->answer) {
/* list layers */
