[GRASS-SVN] r74152 - grass-addons/grass7/raster/r.landscape.evol
svn_grass at osgeo.org
Mon Mar 4 05:32:40 PST 2019
Author: cmbarton
Date: 2019-03-04 05:32:40 -0800 (Mon, 04 Mar 2019)
New Revision: 74152
grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py
fixing GRASS 7.x update bugs with the sampled points flag -p
Modified: grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py
--- grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py 2019-03-04 12:26:15 UTC (rev 74151)
+++ grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py 2019-03-04 13:32:40 UTC (rev 74152)
@@ -403,12 +403,11 @@
numpts = int(math.log(int(flaccstats['n']))*100)
grass.message('5) Creating random points and sampling values of flow accumulation, curvatures, and slope.')
vout = '%s%s_randomly_sampled_points' % (p, numpts)
- grass.run_command('r.random', quiet = "True", input = flowacc, cover = pc, n = numpts, vector_output = vout)
- grass.run_command('v.db.renamecol', quiet = "True", map = vout, column = 'value,Flow_acc')
- grass.run_command('v.db.renamecol', quiet = "True", map = vout, column = 'covervalue,Princ_curv')
- grass.run_command('v.db.addcol', quiet = "True", map = vout, columns = 'Tang_curv double precision, Slope double precision')
- grass.run_command('v.what.rast', quiet = "True", vector = vout, raster = tc, column = "Tang_curv")
- grass.run_command('v.what.rast', quiet = "True", vector = vout, raster = slope, column = "Slope")
+ grass.run_command('r.random', quiet = "True", input = flowacc, cover = pc, npoints = numpts, vector = vout)
+ grass.run_command('v.db.renamecolumn', quiet = "True", map = vout, column = 'value,Flow_acc')
+ grass.run_command('v.db.renamecolumn', quiet = "True", map = vout, column = 'covervalue,Princ_curv')
+ grass.run_command('v.db.addcolumn', quiet = "True", map = vout, columns = 'Tang_curv double precision, Slope double precision')
+ grass.run_command('v.what.rast', quiet = "True", map = vout, raster = tc, column = "Tang_curv")
if ( flags["k"] is True ):
grass.message('--Keeping the created maps (Flow Accumulation, Slope, Principle Curvature, Tangential Curvature)')
else:
@@ -683,7 +682,3 @@
f.close()
grass.message('\nIterations complete!\n\nDone with everything')
sys.exit(0)
