[GRASS-SVN] r74179 - grass/trunk
Thu Mar 7 12:04:26 PST 2019
Author: neteler
Date: 2019-03-07 12:04:26 -0800 (Thu, 07 Mar 2019)
New Revision: 74179
   grass/trunk/configure
   grass/trunk/configure.in
configure: nad2bin check no longer needed; (user custom) grids are used via PROJ
Modified: grass/trunk/configure
--- grass/trunk/configure	2019-03-07 17:44:52 UTC (rev 74178)
+++ grass/trunk/configure	2019-03-07 20:04:26 UTC (rev 74179)
@@ -6194,45 +6194,6 @@
-# nad2bin needs to be in path for installing datum gridshift files
-# Extract the first word of "nad2bin", so it can be a program name with args.
-set dummy nad2bin; ac_word=$2
-echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:6203: checking for $ac_word" >&5
-case "$NAD2BIN" in
-  ac_cv_path_NAD2BIN="$NAD2BIN" # Let the user override the test with a path.
-  ac_cv_path_NAD2BIN="$NAD2BIN" # Let the user override the test with a dos path.
-  IFS="${IFS= 	}"; ac_save_ifs="$IFS"; IFS=":"
-  ac_dummy="$PATH"
-  for ac_dir in $ac_dummy; do
-    test -z "$ac_dir" && ac_dir=.
-    if test -f $ac_dir/$ac_word; then
-      ac_cv_path_NAD2BIN="$ac_dir/$ac_word"
-      break
-    fi
-  done
-  IFS="$ac_save_ifs"
-  test -z "$ac_cv_path_NAD2BIN" && ac_cv_path_NAD2BIN="no"
-esac
-NAD2BIN="$ac_cv_path_NAD2BIN"
-if test -n "$NAD2BIN"; then
-  echo "$ac_t""$NAD2BIN" 1>&6
-else
-  echo "$ac_t""no" 1>&6
-fi
-if test "$NAD2BIN" = "no"; then
-    { echo "configure: error: *** Unable to locate nad2bin (needs to be in PATH)." 1>&2; exit 1; }
-fi
 # Done checking PROJ
 # Enable regex option
@@ -6239,7 +6200,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:6243: checking whether to use regex" >&5
+echo "configure:6204: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -6259,7 +6220,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:6263: checking for location of regex includes" >&5
+echo "configure:6224: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -6285,15 +6246,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:6289: checking for $ac_hdr" >&5
+echo "configure:6250: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 6292 "configure"
+#line 6253 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:6297: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -6327,7 +6288,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:6331: checking for location of regex library" >&5
+echo "configure:6292: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -6352,10 +6313,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:6356: checking for regcomp" >&5
+echo "configure:6317: checking for regcomp" >&5
-#line 6359 "configure"
+#line 6320 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char regcomp(); below.  */
@@ -6378,7 +6339,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -6405,13 +6366,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:6409: checking for regcomp in -lregex" >&5
+echo "configure:6370: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lregex  $LIBS"
-#line 6415 "configure"
+#line 6376 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -6422,7 +6383,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:6426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -6472,7 +6433,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:6476: checking whether to use Readline" >&5
+echo "configure:6437: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -6493,7 +6454,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:6497: checking for location of Readline includes" >&5
+echo "configure:6458: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -6519,15 +6480,15 @@
 do
-echo "configure:6523: checking for $ac_hdr" >&5
+echo "configure:6484: checking for $ac_hdr" >&5
-#line 6526 "configure"
+#line 6487 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6531: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6492: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6563,15 +6524,15 @@
 do
-echo "configure:6567: checking for $ac_hdr" >&5
+echo "configure:6528: checking for $ac_hdr" >&5
-#line 6570 "configure"
+#line 6531 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6575: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6605,7 +6566,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:6609: checking for location of Readline library" >&5
+echo "configure:6570: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -6630,13 +6591,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:6634: checking for readline in -lreadline" >&5
+echo "configure:6595: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 6640 "configure"
+#line 6601 "configure"
@@ -6647,7 +6608,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:6651: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6612: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6682,13 +6643,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6686: checking for add_history in -lhistory" >&5
+echo "configure:6647: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6692 "configure"
+#line 6653 "configure"
@@ -6699,7 +6660,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6664: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6741,7 +6702,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6745: checking whether to use GDAL" >&5
+echo "configure:6706: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6759,7 +6720,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6763: checking for $ac_word" >&5
+echo "configure:6724: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6814,7 +6775,7 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6818 "configure"
+#line 6779 "configure"
 #include <gdal.h>
 int main() {
@@ -6821,7 +6782,7 @@
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6830,7 +6791,7 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6834 "configure"
+#line 6795 "configure"
 #include <gdal.h>
 int main() {
@@ -6837,7 +6798,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6841: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6869,7 +6830,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6873: checking whether to use libLAS" >&5
+echo "configure:6834: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6886,7 +6847,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6890: checking for $ac_word" >&5
+echo "configure:6851: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6939,15 +6900,15 @@
 do
-echo "configure:6943: checking for $ac_hdr" >&5
+echo "configure:6904: checking for $ac_hdr" >&5
-#line 6946 "configure"
+#line 6907 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6951: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6973,7 +6934,7 @@
 done
-#line 6977 "configure"
+#line 6938 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
@@ -6980,7 +6941,7 @@
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6984: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6945: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6988,7 +6949,7 @@
   rm -rf conftest*
-#line 6992 "configure"
+#line 6953 "configure"
 int main() {
@@ -6995,7 +6956,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -7028,7 +6989,7 @@
 # PDAL option
 echo $ac_n "checking whether to use PDAL""... $ac_c" 1>&6
-echo "configure:7032: checking whether to use PDAL" >&5
+echo "configure:6993: checking whether to use PDAL" >&5
 # new and currently used way to switch language to C++
 # AC_LANG_PUSH(C++)
@@ -7056,7 +7017,7 @@
   # Extract the first word of "pdal-config", so it can be a program name with args.
 set dummy pdal-config; ac_word=$2
-echo "configure:7060: checking for $ac_word" >&5
+echo "configure:7021: checking for $ac_word" >&5
 case "$PDAL_CONFIG" in
@@ -7106,7 +7067,7 @@
   CFLAGS="$CFLAGS $PDAL_CFLAGS"
   CPPFLAGS="$CPPFLAGS $PDAL_CPPFLAGS $PDAL_INC"
-#line 7110 "configure"
+#line 7071 "configure"
 #include <pdal/PointTable.hpp>
 int main() {
@@ -7113,7 +7074,7 @@
 pdal::PointTable table;
 ; return 0; }
 EOF
-if { (eval echo configure:7117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7078: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -7121,7 +7082,7 @@
   rm -rf conftest*
-#line 7125 "configure"
+#line 7086 "configure"
 int main() {
@@ -7128,7 +7089,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   PDAL_LIBS="$PDAL_LIBS"
 else
@@ -7178,7 +7139,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:7182: checking whether to use NetCDF" >&5
+echo "configure:7143: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -7195,7 +7156,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:7199: checking for $ac_word" >&5
+echo "configure:7160: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -7242,7 +7203,7 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 7246 "configure"
+#line 7207 "configure"
 #include <netcdf.h>
 int main() {
@@ -7249,7 +7210,7 @@
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:7253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -7257,7 +7218,7 @@
   rm -rf conftest*
-#line 7261 "configure"
+#line 7222 "configure"
 #include <netcdf.h>
 int main() {
@@ -7264,7 +7225,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -7295,7 +7256,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7299: checking whether to use GEOS" >&5
+echo "configure:7260: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -7313,7 +7274,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7317: checking for $ac_word" >&5
+echo "configure:7278: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -7361,15 +7322,15 @@
 do
-echo "configure:7365: checking for $ac_hdr" >&5
+echo "configure:7326: checking for $ac_hdr" >&5
-#line 7368 "configure"
+#line 7329 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7373: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7334: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7408,13 +7369,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:7412: checking for initGEOS in -lgeos_c" >&5
+echo "configure:7373: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 7418 "configure"
+#line 7379 "configure"
@@ -7425,7 +7386,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:7429: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7469,7 +7430,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:7473: checking whether to use TIFF" >&5
+echo "configure:7434: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -7489,7 +7450,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:7493: checking for location of TIFF includes" >&5
+echo "configure:7454: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -7515,15 +7476,15 @@
 do
-echo "configure:7519: checking for $ac_hdr" >&5
+echo "configure:7480: checking for $ac_hdr" >&5
-#line 7522 "configure"
+#line 7483 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7488: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7557,7 +7518,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:7561: checking for location of TIFF library" >&5
+echo "configure:7522: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -7588,13 +7549,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:7592: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7553: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 7598 "configure"
+#line 7559 "configure"
@@ -7605,7 +7566,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7570: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7624,13 +7585,13 @@
-echo "configure:7628: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7589: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 7634 "configure"
+#line 7595 "configure"
@@ -7641,7 +7602,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7660,13 +7621,13 @@
-echo "configure:7664: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7625: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 7670 "configure"
+#line 7631 "configure"
@@ -7677,7 +7638,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7696,13 +7657,13 @@
-echo "configure:7700: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7661: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 7706 "configure"
+#line 7667 "configure"
@@ -7713,7 +7674,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7732,13 +7693,13 @@
-echo "configure:7736: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7697: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 7742 "configure"
+#line 7703 "configure"
@@ -7749,7 +7710,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7768,13 +7729,13 @@
-echo "configure:7772: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7733: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 7778 "configure"
+#line 7739 "configure"
@@ -7785,7 +7746,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7804,13 +7765,13 @@
-echo "configure:7808: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7769: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 7814 "configure"
+#line 7775 "configure"
@@ -7821,7 +7782,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7840,13 +7801,13 @@
-echo "configure:7844: checking for TIFFOpen in -ltiff" >&5
+echo "configure:7805: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 7850 "configure"
+#line 7811 "configure"
@@ -7857,7 +7818,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7955,7 +7916,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7959: checking whether to use PNG" >&5
+echo "configure:7920: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7974,7 +7935,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7978: checking for location of PNG includes" >&5
+echo "configure:7939: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8000,15 +7961,15 @@
 do
-echo "configure:8004: checking for $ac_hdr" >&5
+echo "configure:7965: checking for $ac_hdr" >&5
-#line 8007 "configure"
+#line 7968 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8012: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7973: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8042,7 +8003,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8046: checking for location of PNG library" >&5
+echo "configure:8007: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8067,13 +8028,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8071: checking for png_read_image in -lpng" >&5
+echo "configure:8032: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8077 "configure"
+#line 8038 "configure"
@@ -8084,7 +8045,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8049: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8126,7 +8087,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8130: checking whether to use PostgreSQL" >&5
+echo "configure:8091: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8153,7 +8114,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8157: checking for location of PostgreSQL includes" >&5
+echo "configure:8118: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8179,15 +8140,15 @@
 do
-echo "configure:8183: checking for $ac_hdr" >&5
+echo "configure:8144: checking for $ac_hdr" >&5
-#line 8186 "configure"
+#line 8147 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8191: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8152: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8225,7 +8186,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8229: checking for location of PostgreSQL library" >&5
+echo "configure:8190: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8254,13 +8215,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8258: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8219: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8264 "configure"
+#line 8225 "configure"
@@ -8271,7 +8232,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8290,13 +8251,13 @@
-echo "configure:8294: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8255: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8300 "configure"
+#line 8261 "configure"
@@ -8307,7 +8268,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8326,13 +8287,13 @@
-echo "configure:8330: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8291: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8336 "configure"
+#line 8297 "configure"
@@ -8343,7 +8304,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8347: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8308: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8362,13 +8323,13 @@
-echo "configure:8366: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8327: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 8372 "configure"
+#line 8333 "configure"
@@ -8379,7 +8340,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8383: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8436,13 +8397,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:8440: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8401: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8446 "configure"
+#line 8407 "configure"
@@ -8453,7 +8414,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8475,13 +8436,13 @@
-echo "configure:8479: checking for PQcmdTuples in -lpq" >&5
+echo "configure:8440: checking for PQcmdTuples in -lpq" >&5
-#line 8485 "configure"
+#line 8446 "configure"
@@ -8492,7 +8453,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:8496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8457: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8535,7 +8496,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:8539: checking whether to use MySQL" >&5
+echo "configure:8500: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -8555,7 +8516,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:8559: checking for location of MySQL includes" >&5
+echo "configure:8520: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -8581,15 +8542,15 @@
 do
-echo "configure:8585: checking for $ac_hdr" >&5
+echo "configure:8546: checking for $ac_hdr" >&5
-#line 8588 "configure"
+#line 8549 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8593: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8554: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8626,7 +8587,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:8630: checking for location of MySQL library" >&5
+echo "configure:8591: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -8657,13 +8618,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:8661: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8622: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 8667 "configure"
+#line 8628 "configure"
@@ -8674,7 +8635,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8639: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8693,13 +8654,13 @@
-echo "configure:8697: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8658: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 8703 "configure"
+#line 8664 "configure"
@@ -8710,7 +8671,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8729,13 +8690,13 @@
-echo "configure:8733: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8694: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 8739 "configure"
+#line 8700 "configure"
@@ -8746,7 +8707,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8765,13 +8726,13 @@
-echo "configure:8769: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8730: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 8775 "configure"
+#line 8736 "configure"
@@ -8782,7 +8743,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8786: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8801,13 +8762,13 @@
-echo "configure:8805: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8766: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 8811 "configure"
+#line 8772 "configure"
@@ -8818,7 +8779,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8837,13 +8798,13 @@
-echo "configure:8841: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8802: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 8847 "configure"
+#line 8808 "configure"
@@ -8854,7 +8815,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8858: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8873,13 +8834,13 @@
-echo "configure:8877: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8838: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8883 "configure"
+#line 8844 "configure"
@@ -8890,7 +8851,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8909,13 +8870,13 @@
-echo "configure:8913: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8874: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8919 "configure"
+#line 8880 "configure"
@@ -8926,7 +8887,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9016,7 +8977,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
-echo "configure:9020: checking for $ac_word" >&5
+echo "configure:8981: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9065,10 +9026,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9069: checking for mysql_server_init" >&5
+echo "configure:9030: checking for mysql_server_init" >&5
-#line 9072 "configure"
+#line 9033 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -9094,7 +9055,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9059: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9146,7 +9107,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9150: checking whether to use SQLite" >&5
+echo "configure:9111: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9166,7 +9127,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9170: checking for location of SQLite includes" >&5
+echo "configure:9131: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9192,15 +9153,15 @@
 do
-echo "configure:9196: checking for $ac_hdr" >&5
+echo "configure:9157: checking for $ac_hdr" >&5
-#line 9199 "configure"
+#line 9160 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9204: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9165: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9243,7 +9204,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9247: checking for location of SQLite library" >&5
+echo "configure:9208: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9272,13 +9233,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9276: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9237: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9282 "configure"
+#line 9243 "configure"
@@ -9289,7 +9250,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9308,13 +9269,13 @@
-echo "configure:9312: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9273: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9318 "configure"
+#line 9279 "configure"
@@ -9325,7 +9286,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9290: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9344,13 +9305,13 @@
-echo "configure:9348: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9309: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9354 "configure"
+#line 9315 "configure"
@@ -9361,7 +9322,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9365: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9326: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9380,13 +9341,13 @@
-echo "configure:9384: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9345: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 9390 "configure"
+#line 9351 "configure"
@@ -9397,7 +9358,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9362: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9472,7 +9433,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9476: checking whether to use OpenGL" >&5
+echo "configure:9437: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9506,7 +9467,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9510: checking for location of OpenGL includes" >&5
+echo "configure:9471: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9532,15 +9493,15 @@
 do
-echo "configure:9536: checking for $ac_hdr" >&5
+echo "configure:9497: checking for $ac_hdr" >&5
-#line 9539 "configure"
+#line 9500 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9544: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9574,7 +9535,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9578: checking for location of OpenGL library" >&5
+echo "configure:9539: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9603,13 +9564,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9607: checking for glBegin in -lGL" >&5
+echo "configure:9568: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9613 "configure"
+#line 9574 "configure"
@@ -9620,7 +9581,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9624: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9639,13 +9600,13 @@
-echo "configure:9643: checking for glBegin in -lGL" >&5
+echo "configure:9604: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9649 "configure"
+#line 9610 "configure"
@@ -9656,7 +9617,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9675,13 +9636,13 @@
-echo "configure:9679: checking for glBegin in -lGL" >&5
+echo "configure:9640: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9685 "configure"
+#line 9646 "configure"
@@ -9692,7 +9653,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9657: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9711,13 +9672,13 @@
-echo "configure:9715: checking for glBegin in -lGL" >&5
+echo "configure:9676: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9721 "configure"
+#line 9682 "configure"
@@ -9728,7 +9689,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9790,13 +9751,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9794: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9755: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9800 "configure"
+#line 9761 "configure"
@@ -9807,7 +9768,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9826,13 +9787,13 @@
-echo "configure:9830: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9791: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9836 "configure"
+#line 9797 "configure"
@@ -9843,7 +9804,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9808: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9890,10 +9851,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9894: checking for glXCreatePbuffer" >&5
+echo "configure:9855: checking for glXCreatePbuffer" >&5
-#line 9897 "configure"
+#line 9858 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9916,7 +9877,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9920: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9953,10 +9914,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9957: checking for glXCreateGLXPixmap" >&5
+echo "configure:9918: checking for glXCreateGLXPixmap" >&5
-#line 9960 "configure"
+#line 9921 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9979,7 +9940,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -10022,7 +9983,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:10026: checking for location of OpenGL framework" >&5
+echo "configure:9987: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -10046,15 +10007,15 @@
 do
-echo "configure:10050: checking for $ac_hdr" >&5
+echo "configure:10011: checking for $ac_hdr" >&5
-#line 10053 "configure"
+#line 10014 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10058: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10090,10 +10051,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:10094: checking for glBegin" >&5
+echo "configure:10055: checking for glBegin" >&5
-#line 10097 "configure"
+#line 10058 "configure"
     which can conflict with char glBegin(); below.  */
@@ -10116,7 +10077,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10120: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -10153,10 +10114,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:10157: checking for gluBeginCurve" >&5
+echo "configure:10118: checking for gluBeginCurve" >&5
-#line 10160 "configure"
+#line 10121 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -10179,7 +10140,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -10227,7 +10188,7 @@
-echo "configure:10231: checking for location of OpenGL includes" >&5
+echo "configure:10192: checking for location of OpenGL includes" >&5
@@ -10253,15 +10214,15 @@
 do
-echo "configure:10257: checking for $ac_hdr" >&5
+echo "configure:10218: checking for $ac_hdr" >&5
-#line 10260 "configure"
+#line 10221 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10265: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10226: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10295,7 +10256,7 @@
-echo "configure:10299: checking for location of OpenGL library" >&5
+echo "configure:10260: checking for location of OpenGL library" >&5
@@ -10320,11 +10281,11 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:10324: checking for OpenGL library" >&5
+echo "configure:10285: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 10328 "configure"
+#line 10289 "configure"
 #include <GL/gl.h>
 int main() {
@@ -10331,7 +10292,7 @@
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:10335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10296: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10355,11 +10316,11 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10359: checking for GLU library" >&5
+echo "configure:10320: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10363 "configure"
+#line 10324 "configure"
 #include <GL/glu.h>
 int main() {
@@ -10366,7 +10327,7 @@
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10415,7 +10376,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10419: checking whether to use ODBC" >&5
+echo "configure:10380: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -10434,7 +10395,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10438: checking for location of ODBC includes" >&5
+echo "configure:10399: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10460,15 +10421,15 @@
 do
-echo "configure:10464: checking for $ac_hdr" >&5
+echo "configure:10425: checking for $ac_hdr" >&5
-#line 10467 "configure"
+#line 10428 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10472: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10433: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10502,7 +10463,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10506: checking for location of ODBC library" >&5
+echo "configure:10467: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10527,13 +10488,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10531: checking for SQLConnect in -lodbc" >&5
+echo "configure:10492: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10537 "configure"
+#line 10498 "configure"
@@ -10544,7 +10505,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10569,13 +10530,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10573: checking for SQLConnect in -liodbc" >&5
+echo "configure:10534: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10579 "configure"
+#line 10540 "configure"
@@ -10586,7 +10547,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10551: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10611,11 +10572,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10615: checking for ODBC library" >&5
+echo "configure:10576: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10619 "configure"
+#line 10580 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10623,7 +10584,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10672,7 +10633,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10676: checking whether to use FFTW" >&5
+echo "configure:10637: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10691,7 +10652,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10695: checking for location of FFTW includes" >&5
+echo "configure:10656: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10717,15 +10678,15 @@
 do
-echo "configure:10721: checking for $ac_hdr" >&5
+echo "configure:10682: checking for $ac_hdr" >&5
-#line 10724 "configure"
+#line 10685 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10729: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10690: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10753,15 +10714,15 @@
 do
-echo "configure:10757: checking for $ac_hdr" >&5
+echo "configure:10718: checking for $ac_hdr" >&5
-#line 10760 "configure"
+#line 10721 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10765: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10726: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10789,15 +10750,15 @@
 do
-echo "configure:10793: checking for $ac_hdr" >&5
+echo "configure:10754: checking for $ac_hdr" >&5
-#line 10796 "configure"
+#line 10757 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10801: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10762: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10843,7 +10804,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10847: checking for location of FFTW library" >&5
+echo "configure:10808: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10868,13 +10829,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10872: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10833: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10878 "configure"
+#line 10839 "configure"
@@ -10885,7 +10846,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10850: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10910,13 +10871,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10914: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10875: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10920 "configure"
+#line 10881 "configure"
@@ -10927,7 +10888,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10931: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10892: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10952,13 +10913,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10956: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10917: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10962 "configure"
+#line 10923 "configure"
@@ -10969,7 +10930,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11026,7 +10987,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:11030: checking whether to use BLAS" >&5
+echo "configure:10991: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -11047,7 +11008,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:11051: checking for location of BLAS includes" >&5
+echo "configure:11012: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -11067,7 +11028,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:11071: checking for location of BLAS library" >&5
+echo "configure:11032: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -11093,15 +11054,15 @@
 do
-echo "configure:11097: checking for $ac_hdr" >&5
+echo "configure:11058: checking for $ac_hdr" >&5
-#line 11100 "configure"
+#line 11061 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11105: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11066: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11136,13 +11097,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:11140: checking for dnrm2_ in -lblas" >&5
+echo "configure:11101: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 11146 "configure"
+#line 11107 "configure"
@@ -11153,7 +11114,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11172,13 +11133,13 @@
-echo "configure:11176: checking for dnrm2_ in -lblas" >&5
+echo "configure:11137: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 11182 "configure"
+#line 11143 "configure"
@@ -11189,7 +11150,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:11193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11154: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11233,13 +11194,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:11237: checking for ATL_xerbla in -latlas" >&5
+echo "configure:11198: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 11243 "configure"
+#line 11204 "configure"
@@ -11250,7 +11211,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11215: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11265,13 +11226,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:11269: checking for sgemm_ in -lf77blas" >&5
+echo "configure:11230: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 11275 "configure"
+#line 11236 "configure"
@@ -11282,7 +11243,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11297,13 +11258,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:11301: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:11262: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 11307 "configure"
+#line 11268 "configure"
@@ -11314,7 +11275,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:11318: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11360,9 +11321,9 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11364: checking for sgemm in $vlib_flags" >&5
+echo "configure:11325: checking for sgemm in $vlib_flags" >&5
-#line 11366 "configure"
+#line 11327 "configure"
 int main() {
@@ -11369,7 +11330,7 @@
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -11387,13 +11348,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11391: checking for sgemm_ in -lblas" >&5
+echo "configure:11352: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 11397 "configure"
+#line 11358 "configure"
@@ -11404,7 +11365,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11419,13 +11380,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11423: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11384: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 11429 "configure"
+#line 11390 "configure"
@@ -11436,7 +11397,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11451,13 +11412,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11455: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11416: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 11461 "configure"
+#line 11422 "configure"
 #include "confdefs.h"
@@ -11468,7 +11429,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11502,13 +11463,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11506: checking for acosp in -lsunmath" >&5
+echo "configure:11467: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11512 "configure"
+#line 11473 "configure"
@@ -11519,7 +11480,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11534,13 +11495,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11538: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11499: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11544 "configure"
+#line 11505 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -11551,7 +11512,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11516: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -11581,13 +11542,13 @@
 # Generic BLAS library
-echo "configure:11585: checking for sgemm_ in -lblas" >&5
+echo "configure:11546: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11591 "configure"
+#line 11552 "configure"
@@ -11598,7 +11559,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11637,7 +11598,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11641: checking whether to use LAPACK" >&5
+echo "configure:11602: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11662,7 +11623,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11666: checking for location of LAPACK includes" >&5
+echo "configure:11627: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11682,7 +11643,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11686: checking for location of LAPACK library" >&5
+echo "configure:11647: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11708,15 +11669,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:11712: checking for $ac_hdr" >&5
+echo "configure:11673: checking for $ac_hdr" >&5
-#line 11715 "configure"
+#line 11676 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:11720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -11748,10 +11709,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11752: checking for dsegv_" >&5
+echo "configure:11713: checking for dsegv_" >&5
-#line 11755 "configure"
+#line 11716 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char dsegv_(); below.  */
@@ -11774,7 +11735,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11801,13 +11762,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11805: checking for desgv_ in -llapack" >&5
+echo "configure:11766: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11811 "configure"
+#line 11772 "configure"
@@ -11818,7 +11779,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11850,13 +11811,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11854: checking for dgesv_ in -llapack" >&5
+echo "configure:11815: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11860 "configure"
+#line 11821 "configure"
@@ -11867,7 +11828,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11832: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11886,13 +11847,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:11890: checking for dgesv_ in -llapack" >&5
+echo "configure:11851: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11896 "configure"
+#line 11857 "configure"
@@ -11903,7 +11864,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11959,7 +11920,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11963: checking whether to use Cairo" >&5
+echo "configure:11924: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11991,7 +11952,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11995: checking for location of cairo includes" >&5
+echo "configure:11956: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -12017,15 +11978,15 @@
 do
-echo "configure:12021: checking for $ac_hdr" >&5
+echo "configure:11982: checking for $ac_hdr" >&5
-#line 12024 "configure"
+#line 11985 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12029: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11990: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12061,7 +12022,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:12065: checking for location of cairo library" >&5
+echo "configure:12026: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -12081,7 +12042,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:12085: checking for cairo linking flags" >&5
+echo "configure:12046: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -12097,10 +12058,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:12101: checking for cairo_create" >&5
+echo "configure:12062: checking for cairo_create" >&5
-#line 12104 "configure"
+#line 12065 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -12123,7 +12084,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12127: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -12157,10 +12118,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:12161: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:12122: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 12164 "configure"
+#line 12125 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -12183,7 +12144,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -12216,10 +12177,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:12220: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:12181: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 12223 "configure"
+#line 12184 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -12242,7 +12203,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12246: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -12284,7 +12245,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:12288: checking whether to use FreeType" >&5
+echo "configure:12249: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -12303,7 +12264,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:12307: checking for location of FreeType includes" >&5
+echo "configure:12268: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -12329,15 +12290,15 @@
 do
-echo "configure:12333: checking for $ac_hdr" >&5
+echo "configure:12294: checking for $ac_hdr" >&5
-#line 12336 "configure"
+#line 12297 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12341: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12302: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12371,7 +12332,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12375: checking for location of FreeType library" >&5
+echo "configure:12336: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12396,13 +12357,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12400: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:12361: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 12406 "configure"
+#line 12367 "configure"
@@ -12413,7 +12374,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12454,7 +12415,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12458: checking whether to use NLS" >&5
+echo "configure:12419: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12474,10 +12435,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12478: checking for gettext" >&5
+echo "configure:12439: checking for gettext" >&5
-#line 12481 "configure"
+#line 12442 "configure"
     which can conflict with char gettext(); below.  */
@@ -12500,7 +12461,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12518,13 +12479,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12522: checking for gettext in -lintl" >&5
+echo "configure:12483: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12528 "configure"
+#line 12489 "configure"
@@ -12535,7 +12496,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12500: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12570,7 +12531,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12574: checking whether to use C++" >&5
+echo "configure:12535: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12586,7 +12547,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:12590: checking for $ac_word" >&5
+echo "configure:12551: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12615,7 +12576,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12619: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12580: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12626,12 +12587,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12630 "configure"
+#line 12591 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12596: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12657,12 +12618,12 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12661: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12622: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12666: checking whether we are using GNU C++" >&5
+echo "configure:12627: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
@@ -12669,7 +12630,7 @@
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12634: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12687,7 +12648,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12691: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12652: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12715,7 +12676,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 12690 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12698: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 12708 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:12715: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -12728,7 +12740,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12732: checking whether to use openDWG" >&5
+echo "configure:12744: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12748,7 +12760,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12752: checking for location of openDGW includes" >&5
+echo "configure:12764: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12774,15 +12786,15 @@
 do
-echo "configure:12778: checking for $ac_hdr" >&5
+echo "configure:12790: checking for $ac_hdr" >&5
-#line 12781 "configure"
+#line 12793 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12786: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12798: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12816,7 +12828,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12820: checking for location of openDWG library" >&5
+echo "configure:12832: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12857,7 +12869,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12861: checking whether to use POSIX threads" >&5
+echo "configure:12873: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12877,7 +12889,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12881: checking for location of POSIX threads includes" >&5
+echo "configure:12893: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12903,15 +12915,15 @@
 do
-echo "configure:12907: checking for $ac_hdr" >&5
+echo "configure:12919: checking for $ac_hdr" >&5
-#line 12910 "configure"
+#line 12922 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12915: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12927: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12945,7 +12957,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12949: checking for location of POSIX threads library" >&5
+echo "configure:12961: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12970,10 +12982,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12974: checking for pthread_create" >&5
+echo "configure:12986: checking for pthread_create" >&5
-#line 12977 "configure"
+#line 12989 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12996,7 +13008,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -13023,13 +13035,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:13027: checking for pthread_create in -lpthread" >&5
+echo "configure:13039: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 13033 "configure"
+#line 13045 "configure"
@@ -13040,7 +13052,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:13044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13090,7 +13102,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:13094: checking whether to use OpenMP" >&5
+echo "configure:13106: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -13111,7 +13123,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:13115: checking for location of OpenMP includes" >&5
+echo "configure:13127: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -13137,15 +13149,15 @@
 do
-echo "configure:13141: checking for $ac_hdr" >&5
+echo "configure:13153: checking for $ac_hdr" >&5
-#line 13144 "configure"
+#line 13156 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13183,7 +13195,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:13187: checking for location of OpenMP library" >&5
+echo "configure:13199: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -13208,10 +13220,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:13212: checking for GOMP_parallel_start" >&5
+echo "configure:13224: checking for GOMP_parallel_start" >&5
-#line 13215 "configure"
+#line 13227 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -13234,7 +13246,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -13261,13 +13273,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:13265: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:13277: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 13271 "configure"
+#line 13283 "configure"
@@ -13278,7 +13290,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13351,7 +13363,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13355: checking whether to use OpenCL" >&5
+echo "configure:13367: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -13371,7 +13383,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13375: checking for location of OpenCL includes" >&5
+echo "configure:13387: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13398,15 +13410,15 @@
 do
-echo "configure:13402: checking for $ac_hdr" >&5
+echo "configure:13414: checking for $ac_hdr" >&5
-#line 13405 "configure"
+#line 13417 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13410: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13422: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13446,10 +13458,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13450: checking for clGetPlatformInfo" >&5
+echo "configure:13462: checking for clGetPlatformInfo" >&5
-#line 13453 "configure"
+#line 13465 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -13472,7 +13484,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13511,15 +13523,15 @@
 do
-echo "configure:13515: checking for $ac_hdr" >&5
+echo "configure:13527: checking for $ac_hdr" >&5
-#line 13518 "configure"
+#line 13530 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13523: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13535: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13552,7 +13564,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13556: checking for location of OpenCL library" >&5
+echo "configure:13568: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13576,13 +13588,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13580: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:13592: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13586 "configure"
+#line 13598 "configure"
@@ -13593,7 +13605,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13609: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13653,7 +13665,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13657: checking for special C compiler options needed for large files" >&5
+echo "configure:13669: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13661,7 +13673,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13665 "configure"
+#line 13677 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13677,7 +13689,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13681: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13693: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13686,7 +13698,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13690 "configure"
+#line 13702 "configure"
@@ -13702,7 +13714,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13706: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13718: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13729,11 +13741,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13733: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13745: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13737 "configure"
+#line 13749 "configure"
@@ -13749,7 +13761,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13753: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13765: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13756,7 +13768,7 @@
   rm -rf conftest*
-#line 13760 "configure"
+#line 13772 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -13774,7 +13786,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13778: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13790: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13800,11 +13812,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13804: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13816: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13808 "configure"
+#line 13820 "configure"
@@ -13820,7 +13832,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13824: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13836: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13827,7 +13839,7 @@
   rm -rf conftest*
-#line 13831 "configure"
+#line 13843 "configure"
 #define _LARGE_FILES 1
@@ -13845,7 +13857,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13849: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13861: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13871,11 +13883,11 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13875: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13887: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13879 "configure"
+#line 13891 "configure"
 #include <stdio.h>
 int main() {
@@ -13882,7 +13894,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13886: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13898: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13889,7 +13901,7 @@
   rm -rf conftest*
-#line 13893 "configure"
+#line 13905 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13898,7 +13910,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13902: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13914: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13930,11 +13942,11 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13934: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13946: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13938 "configure"
+#line 13950 "configure"
 #include <stdio.h>
 int main() {
@@ -13941,7 +13953,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13945: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13948,7 +13960,7 @@
   rm -rf conftest*
-#line 13952 "configure"
+#line 13964 "configure"
 #include <stdio.h>
@@ -13957,7 +13969,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13961: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13973: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13987,11 +13999,11 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13991: checking for fseeko" >&5
+echo "configure:14003: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13995 "configure"
+#line 14007 "configure"
 #include <stdio.h>
 int main() {
@@ -13998,7 +14010,7 @@
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:14002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14014: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -14015,10 +14027,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14019: checking if system supports Large Files at all" >&5
+echo "configure:14031: checking if system supports Large Files at all" >&5
-#line 14022 "configure"
+#line 14034 "configure"
 #include <stdio.h>
@@ -14050,7 +14062,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14054: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14066: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14254,7 +14266,6 @@
 s%@PROJINC@%$PROJINC%g
 s%@PROJLIB@%$PROJLIB%g
 s%@PROJSHARE@%$PROJSHARE%g
-s%@NAD2BIN@%$NAD2BIN%g
 s%@REGEXINCPATH@%$REGEXINCPATH%g
 s%@REGEXLIBPATH@%$REGEXLIBPATH%g
 s%@REGEXLIB@%$REGEXLIB%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2019-03-07 17:44:52 UTC (rev 74178)
+++ grass/trunk/configure.in	2019-03-07 20:04:26 UTC (rev 74179)
@@ -751,13 +751,6 @@
 AC_SUBST(PROJLIB)
 AC_SUBST(PROJSHARE)
-# nad2bin needs to be in path for installing datum gridshift files
-AC_PATH_PROG(NAD2BIN, nad2bin, no)
-if test "$NAD2BIN" = "no"; then
-    AC_MSG_ERROR([*** Unable to locate nad2bin (needs to be in PATH).])
-fi
 # Done checking PROJ
 # Enable regex option
