[GRASS-SVN] r74192 - in grass/trunk: general/g.proj lib/gis
svn_grass at osgeo.org
Fri Mar 8 11:31:28 PST 2019
Author: mmetz
Date: 2019-03-08 11:31:28 -0800 (Fri, 08 Mar 2019)
New Revision: 74192
grass/trunk/general/g.proj/output.c
grass/trunk/lib/gis/get_projinfo.c
libgis: get srid for proj_create_crs_to_crs()
Modified: grass/trunk/general/g.proj/output.c
--- grass/trunk/general/g.proj/output.c 2019-03-08 19:29:27 UTC (rev 74191)
+++ grass/trunk/general/g.proj/output.c 2019-03-08 19:31:28 UTC (rev 74192)
@@ -39,6 +39,8 @@
fprintf(stdout,
"-PROJ_INFO-------------------------------------------------\n");
for (i = 0; i < projinfo->nitems; i++) {
+ if (strcmp(projinfo->key[i], "init") == 0)
+ continue;
if (shell)
fprintf(stdout, "%s=%s\n", projinfo->key[i], projinfo->value[i]);
else
Modified: grass/trunk/lib/gis/get_projinfo.c
--- grass/trunk/lib/gis/get_projinfo.c 2019-03-08 19:29:27 UTC (rev 74191)
+++ grass/trunk/lib/gis/get_projinfo.c 2019-03-08 19:31:28 UTC (rev 74192)
@@ -10,6 +10,7 @@
#include <unistd.h>
+#include <stdio.h>
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -57,7 +58,7 @@
struct Key_Value *G_get_projinfo(void)
- struct Key_Value *in_proj_keys;
+ struct Key_Value *in_proj_keys, *in_epsg_keys;
char path[GPATH_MAX];
G_file_name(path, "", PROJECTION_FILE, PERMANENT);
@@ -69,6 +70,16 @@
return NULL;
in_proj_keys = G_read_key_value_file(path);
+ /* TODO: do not restrict to EPSG as the only authority */
+ if ((in_epsg_keys = G_get_projepsg()) != NULL) {
+ const char *epsgstr = G_find_key_value("epsg", in_epsg_keys);
+ char buf[4096];
+ sprintf(buf, "EPSG:%s", epsgstr);
+ G_set_key_value("init", buf, in_proj_keys);
+ G_free_key_value(in_epsg_keys);
return in_proj_keys;
@@ -80,7 +91,7 @@
G_free_key_value().
\return pointer to Key_Value structure with key/value pairs
- \return NULL when EPSG code is defined for location
+ \return NULL when EPSG code is not defined for location
struct Key_Value *G_get_projepsg(void)
