[GRASS-SVN] r74208 - grass/trunk/vector/v.mkgrid
svn_grass at osgeo.org
Sat Mar 9 10:57:08 PST 2019
Author: mmetz
Date: 2019-03-09 10:57:08 -0800 (Sat, 09 Mar 2019)
New Revision: 74208
grass/trunk/vector/v.mkgrid/local_proto.h
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.mkgrid/write_grid.c
v.mkgrid: + -d flag to add diagonals to rectangular lines
Modified: grass/trunk/vector/v.mkgrid/local_proto.h
--- grass/trunk/vector/v.mkgrid/local_proto.h 2019-03-09 18:53:50 UTC (rev 74207)
+++ grass/trunk/vector/v.mkgrid/local_proto.h 2019-03-09 18:57:08 UTC (rev 74208)
@@ -3,7 +3,7 @@
void rotate(double *, double *, double, double, double);
/* write_grid.c */
-int write_grid(struct grid_description *, struct Map_info *, int, int);
+int write_grid(struct grid_description *, struct Map_info *, int, int, int);
/* hexgrid.c */
int hexgrid(struct grid_description *, struct Map_info *, int, int);
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2019-03-09 18:53:50 UTC (rev 74207)
+++ grass/trunk/vector/v.mkgrid/main.c 2019-03-09 18:57:08 UTC (rev 74208)
@@ -51,8 +51,8 @@
struct Option *vectname, *grid, *coord, *box, *angle, *position_opt,
*breaks, *type_opt;
struct GModule *module;
- struct Flag *hex_flag, *ha_flag;
- int otype, ptype, ltype;
+ struct Flag *hex_flag, *ha_flag, *diag_flag;
+ int otype, ptype, ltype, diag;
char *desc;
struct line_pnts *Points;
@@ -145,6 +145,13 @@
ha_flag->description =
_("Allow asymmetric hexagons");
+ diag_flag = G_define_flag();
+ diag_flag->key = 'd';
+ diag_flag->label =
+ _("EXPERIMENTAL: Add diagonals to rectangular lines");
+ diag_flag->description =
+ _("Applies only to lines for rectangles");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -164,8 +171,14 @@
ptype = (otype & GV_POINTS);
ltype = (otype & GV_LINES);
+ diag = (otype == GV_LINE && !hex_flag->answer && diag_flag->answer);
+ if (diag) {
+ ptype = 0;
+ ltype = GV_LINE;
+ hex_flag->answer = 0;
/* get the current window */
G_get_window(&window);
@@ -366,6 +379,7 @@
db_get_string(&sql));
+ db_commit_transaction(Driver);
else {
if (grid_info.width != grid_info.height) {
@@ -410,7 +424,7 @@
if (ltype) {
/* create areas */
- write_grid(&grid_info, &Map, nbreaks, ltype);
+ write_grid(&grid_info, &Map, nbreaks, ltype, diag);
/* Create a grid of label points at the centres of the grid cells */
@@ -466,10 +480,10 @@
attCount++;
G_percent(1, 1, 1);
- db_commit_transaction(Driver);
db_close_database_shutdown_driver(Driver);
Modified: grass/trunk/vector/v.mkgrid/write_grid.c
--- grass/trunk/vector/v.mkgrid/write_grid.c 2019-03-09 18:53:50 UTC (rev 74207)
+++ grass/trunk/vector/v.mkgrid/write_grid.c 2019-03-09 18:57:08 UTC (rev 74208)
@@ -31,7 +31,8 @@
return 0;
-int write_grid(struct grid_description *grid_info, struct Map_info *Map, int nbreaks, int out_type)
+int write_grid(struct grid_description *grid_info, struct Map_info *Map,
+ int nbreaks, int out_type, int diag)
int i, k, j;
@@ -42,6 +43,7 @@
double width, height;
double next_x, next_y;
double snext_x, snext_y;
+ double xdiag, ydiag;
double angle, dum;
@@ -61,8 +63,8 @@
* to make sure that each section of the grid
* line is less than half way around the globe
- x_len = width / (1. * nbreaks + 1);
- y_len = height / (1. * nbreaks + 1);
+ x_len = width / (1. * nbreaks + 1);
+ y_len = height / (1. * nbreaks + 1);
/* write out all the vector lengths (x vectors) of the entire grid */
G_message(_("Writing out vector rows..."));
@@ -92,7 +94,20 @@
rotate(&next_x, &dum, grid_info->xo, grid_info->yo,
angle);
write_vect(x, y, next_x, dum, Map, Points, out_type);
+ if (diag && i < num_v_rows - 1) {
+ xdiag = snext_x;
+ ydiag = sy + height;
+ rotate(&xdiag, &ydiag, grid_info->xo, grid_info->yo,
+ angle);
+ write_vect(x, y, xdiag, ydiag, Map, Points, out_type);
+ xdiag = sx;
+ angle);
+ write_vect(xdiag, ydiag, next_x, dum, Map, Points, out_type);
y = sy;
x = next_x = snext_x;
j++;
@@ -112,30 +127,30 @@
G_percent(i, num_v_cols, 2);
for (k = 0; k < rows; k++) {
- y = starty;
- j = 0;
- do {
- if (j < nbreaks)
- next_y = y + y_len;
- else
- next_y = starty + height;
+ y = starty;
+ j = 0;
+ do {
+ if (j < nbreaks)
+ next_y = y + y_len;
+ else
+ next_y = starty + height;
- sx = x;
- sy = y;
- snext_y = next_y;
- dum = x;
- rotate(&x, &y, grid_info->xo, grid_info->yo, angle);
- rotate(&dum, &next_y, grid_info->xo, grid_info->yo,
+ sx = x;
+ sy = y;
+ snext_y = next_y;
+ dum = x;
+ rotate(&x, &y, grid_info->xo, grid_info->yo, angle);
+ rotate(&dum, &next_y, grid_info->xo, grid_info->yo,
angle);
- write_vect(x, y, dum, next_y, Map, Points, out_type);
+ write_vect(x, y, dum, next_y, Map, Points, out_type);
- x = sx;
- y = next_y = snext_y;
- j++;
- } while (j <= nbreaks);
- /* To get exactly the same coordinates as above, y+=width is wrong */
- starty += height;
+ x = sx;
+ y = next_y = snext_y;
+ j++;
+ } while (j <= nbreaks);
+ /* To get exactly the same coordinates as above, y+=width is wrong */
+ starty += height;
x += width;
