[GRASS-SVN] r74210 - grass/trunk/tools
Sat Mar 9 11:02:45 PST 2019
Author: mmetz
Date: 2019-03-09 11:02:45 -0800 (Sat, 09 Mar 2019)
New Revision: 74210
   grass/trunk/tools/thumbnails.py
thumbnails for color rules: prettify special cases
Modified: grass/trunk/tools/thumbnails.py
--- grass/trunk/tools/thumbnails.py	2019-03-09 18:59:56 UTC (rev 74209)
+++ grass/trunk/tools/thumbnails.py	2019-03-09 19:02:45 UTC (rev 74210)
@@ -74,6 +74,19 @@
                 minval += abs(minval / 100)
             maxval = float(records[-1][0])
             maxval = min(maxval, 2500000)
+        if os.path.basename(path) in ('ndvi', 'ndwi', 'ndwi2'):
+            minval = -1.0
+            maxval = 1.0
+        if os.path.basename(path) == 'ndvi_MODIS':
+            minval = -10000.0
+            maxval = 10000.0
+        if os.path.basename(path) == 'population_dens':
+            maxval = 1000.0
+        if os.path.basename(path) == 'precipitation':
+            maxval = 2000.0
+        if os.path.basename(path) in ('terrain', 'srtm', 'srtm_plus'):
+            minval = -500.0
+            maxval = 3000.0
         grad = tmp_grad_abs
         grass.mapcalc("$grad = "
                       " float($min) + (col() - 1) * "
@@ -149,6 +162,8 @@
         if var in os.environ:
             del os.environ[var]
+    os.environ['GRASS_ANTIALIAS'] = 'none'
     grass.use_temp_region()
     grass.run_command('g.region', s=0, w=0, n=height, e=width,
                       rows=height, cols=width, res=1, flags='a')
