[GRASS-SVN] r74218 - grass/trunk/include/iostream
Sat Mar 9 12:27:08 PST 2019
Author: mmetz
Date: 2019-03-09 12:27:08 -0800 (Sat, 09 Mar 2019)
New Revision: 74218
   grass/trunk/include/iostream/ami_sort_impl.h
   grass/trunk/include/iostream/ami_stream.h
   grass/trunk/include/iostream/embuffer.h
   grass/trunk/include/iostream/empq_adaptive_impl.h
   grass/trunk/include/iostream/empq_impl.h
   grass/trunk/include/iostream/mem_stream.h
iostream: reduce compiler warnings
Modified: grass/trunk/include/iostream/ami_sort_impl.h
--- grass/trunk/include/iostream/ami_sort_impl.h	2019-03-09 20:19:25 UTC (rev 74217)
+++ grass/trunk/include/iostream/ami_sort_impl.h	2019-03-09 20:27:08 UTC (rev 74218)
@@ -101,7 +101,7 @@
 size_t makeRun_Block(AMI_STREAM<T> *instream, T* data,
 		   unsigned int run_size, Compare *cmp) {
   AMI_err err;
-  off_t new_run_size;
+  off_t new_run_size = 0;
   //read next run from input stream
   err = instream->read_array(data, run_size, &new_run_size);
@@ -256,7 +256,7 @@
       delete str;
   SDEBUG MM_manager.print();
   //release the run memory!
   delete [] data;
@@ -265,7 +265,7 @@
   return runList;
Modified: grass/trunk/include/iostream/ami_stream.h
--- grass/trunk/include/iostream/ami_stream.h	2019-03-09 20:19:25 UTC (rev 74217)
+++ grass/trunk/include/iostream/ami_stream.h	2019-03-09 20:27:08 UTC (rev 74218)
@@ -315,7 +315,7 @@
   //size_t usage;
   //main_memory_usage(&usage,  MM_STREAM_USAGE_CURRENT);
   //MM_manager.register_allocation(usage);
@@ -378,7 +378,7 @@
   //*sub_stream = (AMI_base_stream < T > *)substr;
   *sub_stream = substr;
   return  AMI_ERROR_NO_ERROR;
@@ -417,8 +417,8 @@
   return (st_size / sizeof(T));
 #else
-  struct stat buf;
-  if (stat(path, &buf) == -1) {
+  struct stat statbuf;
+  if (stat(path, &statbuf) == -1) {
     perror("AMI_STREAM::stream_len(): fstat failed ");
     DEBUG_ASSERT assert(0);
     exit(1);
@@ -426,11 +426,11 @@
   //debug stream_len:
   DEBUG_STREAM_LEN fprintf(stderr, "%s: length = %lld   sizeof(T)=%lud\n",
-	  path, (long long int)buf.st_size, sizeof(T));
+	  path, (long long int)statbuf.st_size, sizeof(T));
-  return (buf.st_size / sizeof(T));
+  return (statbuf.st_size / sizeof(T));
 #endif
@@ -443,7 +443,7 @@
   strcpy(*stream_name, path);
 // Return the path name of this stream.
 template<class T>
@@ -450,7 +450,7 @@
 const char *
 AMI_STREAM<T>::name() const {
   return path;
@@ -508,7 +508,7 @@
      break;
@@ -534,7 +534,7 @@
   //size_t usage;
   //MM_manager.register_deallocation(usage);
@@ -563,7 +563,7 @@
     *elt = &read_tmp;
@@ -596,7 +596,7 @@
     if(lenp) *lenp = nobj;
@@ -623,7 +623,7 @@
@@ -649,7 +649,7 @@
@@ -656,7 +656,7 @@
 template<class T>
 void AMI_STREAM<T>::persist(persistence p)  {
   per = p;
@@ -669,16 +669,16 @@
 // if you are careful.
 template<class T>
 char *AMI_STREAM<T>::sprint()  {
-  static char buf[BUFSIZ];
-  sprintf(buf, "[AMI_STREAM %s %ld]", path, (long)stream_len());
-  return buf;
+  static char desc[BUFSIZ];
+  sprintf(desc, "[AMI_STREAM %s %ld]", path, (long)stream_len());
+  return desc;
 template<class T>
 int AMI_STREAM<T>::eof()  {
   return eof_reached;
 #endif // _AMI_STREAM_H
Modified: grass/trunk/include/iostream/embuffer.h
--- grass/trunk/include/iostream/embuffer.h	2019-03-09 20:19:25 UTC (rev 74217)
+++ grass/trunk/include/iostream/embuffer.h	2019-03-09 20:27:08 UTC (rev 74218)
@@ -487,12 +487,12 @@
   //initialize the <arity> streams to NULL, deleted[], streamsize[]
   //and name[]
-  for (unsigned int i=0; i< arity; i++) {
-    data[i] = NULL;
-    deleted[i] = 0;
-    streamsize[i] = 0;
+  for (unsigned int ui=0; ui< arity; ui++) {
+    data[ui] = NULL;
+    deleted[ui] = 0;
+    streamsize[ui] = 0;
 #ifdef SAVE_MEMORY
-    name[i] = NULL;
+    name[ui] = NULL;
 #endif
   //set index
Modified: grass/trunk/include/iostream/empq_adaptive_impl.h
--- grass/trunk/include/iostream/empq_adaptive_impl.h	2019-03-09 20:19:25 UTC (rev 74217)
+++ grass/trunk/include/iostream/empq_adaptive_impl.h	2019-03-09 20:27:08 UTC (rev 74218)
@@ -75,7 +75,7 @@
 		    << ( (float)inMem/ (1<< 20)) << "MB" << endl;
   initPQ(inMem);
@@ -97,7 +97,7 @@
   initPQ(mm_avail);
@@ -160,7 +160,7 @@
   im = new MinMaxHeap<T>(pqsize);
   assert(im);
   em = NULL;
 template<class T, class Key>
@@ -177,7 +177,7 @@
 	delete em;
 	break;
@@ -200,7 +200,7 @@
 	break;
   return m;
@@ -225,7 +225,7 @@
 	break;
   return v;
 //return true if full
@@ -273,7 +273,7 @@
 	break;
   return v;
 /* switch over to using an external priority queue */
@@ -332,7 +332,7 @@
 	break;
   return v;
 //return the nb of elements in the structure
@@ -384,7 +384,7 @@
 	  break;
 	return v;
@@ -418,7 +418,7 @@
 	break;
   return v;
 void
@@ -507,6 +507,6 @@
 #ifndef NDEBUG
   assert(sizeCheck == size());
 #endif
 #endif
Modified: grass/trunk/include/iostream/empq_impl.h
--- grass/trunk/include/iostream/empq_impl.h	2019-03-09 20:19:25 UTC (rev 74217)
+++ grass/trunk/include/iostream/empq_impl.h	2019-03-09 20:27:08 UTC (rev 74218)
@@ -1009,7 +1009,7 @@
   if (!pq->empty()) {
     T pqmax;
-    bool ok;
     ok = pq->max(pqmax);
     assert(ok);
     // cout << "insert " << x << " max: " << pqmax << "\n";
Modified: grass/trunk/include/iostream/mem_stream.h
--- grass/trunk/include/iostream/mem_stream.h	2019-03-09 20:19:25 UTC (rev 74217)
+++ grass/trunk/include/iostream/mem_stream.h	2019-03-09 20:27:08 UTC (rev 74218)
@@ -83,7 +83,7 @@
   curr = datap;
   len = lenv;
@@ -93,7 +93,7 @@
   return len;
@@ -108,7 +108,7 @@
@@ -128,7 +128,7 @@
 template<class T>
 MEM_STREAM<T>::~MEM_STREAM(void)  {
@@ -144,7 +144,7 @@
   *elt = curr;
   curr++;
@@ -162,7 +162,7 @@
   *curr = elt;
   curr++;
@@ -177,6 +177,6 @@
   sprintf(buf, "[MEM_STREAM %d]", stream_len());
   return buf;
 #endif // _MEM_STREAM_H
