[GRASS-SVN] r74228 - in grass/trunk/raster/r.contour: . testsuite
svn_grass at osgeo.org
Wed Mar 13 00:11:02 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:11:02 -0700 (Wed, 13 Mar 2019)
New Revision: 74228
Added:
grass/trunk/raster/r.contour/testsuite/
grass/trunk/raster/r.contour/testsuite/test_r_contour.py
grass/trunk/raster/r.contour/testsuite/testrc.py
r.contour: added tests from GCI 2018
Added: grass/trunk/raster/r.contour/testsuite/test_r_contour.py
--- grass/trunk/raster/r.contour/testsuite/test_r_contour.py (rev 0)
+++ grass/trunk/raster/r.contour/testsuite/test_r_contour.py 2019-03-13 07:11:02 UTC (rev 74228)
@@ -0,0 +1,83 @@
+Name: r.contour test
+Purpose: Tests r.contour module and its options.
+Author: Shubham Sharma, Google Code-in 2018
+Copyright: (C) 2018 by Shubham Sharma and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+import os
+class TestRasterWhat(TestCase):
+ input = 'elevation'
+ output = 'elevationVector'
+ step = 100
+ levels = (60, 90, 120, 150)
+ minlevel = 1000
+ maxlevel = 2000
+ cut = 200
+ test_ref_str = "cat|level\n1|60\n2|90\n3|120\n4|150\n"
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.input)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ cls.runModule('g.remove', type='vector', flags='f', name=cls.output)
+ cls.runModule('g.remove', type='vector', flags='f', name=cls.output+"_cut")
+ cls.runModule('g.remove', type='vector', flags='f', name=cls.output+"_cut_flag_t")
+ if os.path.isfile('testReport'):
+ os.remove('testReport')
+ if os.path.isfile('testReportCut'):
+ os.remove('testReportCut')
+ if os.path.isfile('testReportCutFlagT'):
+ os.remove('testReportCutFlagT')
+ def test_raster_contour(self):
+ """Testing r.contour runs successfully with input steps,levels, minlevel, maxlevel"""
+ self.assertModule('r.contour', input=self.input, output=self.output, step=self.step, levels=self.levels, minlevel=self.minlevel, maxlevel=self.maxlevel)
+ self.assertVectorExists(name=self.output, msg=self.output+" was not created.")
+ # Check the attribute values of contours with v.db.select
+ self.assertModule('v.db.select', map=self.output, file='testReport')
+ self.assertFileExists('testReport', msg='testReport file was not created')
+ file = open("testReport", "r")
+ fileData = file.read()
+ self.assertMultiLineEqual(fileData, self.test_ref_str)
+ file.close()
+ def test_raster_contour_cut(self):
+ """Testing r.contour runs successfully with input steps,levels, minlevel, maxlevel and cut=100"""
+ self.assertModule('r.contour', input=self.input, output=self.output+"_cut", step=self.step, levels=self.levels, minlevel=self.minlevel, maxlevel=self.maxlevel,cut=self.cut)
+ self.assertVectorExists(name=self.output+"_cut", msg=self.output+" was not created.")
+ self.assertModule('v.db.select', map=self.output+"_cut", file='testReportCut')
+ self.assertFileExists('testReportCut', msg='testReportCut file was not created')
+ file = open("testReportCut", "r")
+ file.close()
+ def test_raster_contour_flag_t(self):
+ """Testing r.contour runs successfully with input steps,levels, minlevel, maxlevel ,cut=100 and flag t"""
+ self.assertModule('r.contour', input=self.input, output=self.output+"_cut_flag_t", flags='t', step=self.step, levels=self.levels, minlevel=self.minlevel, maxlevel=self.maxlevel, cut=self.cut)
+ self.assertVectorExists(name=self.output+"_cut_flag_t", msg=self.output+" was not created.")
+ # No need to check the attribute values of contours because attribute table was not created
+if __name__ == '__main__':
+ from grass.gunittest.main import test
+ test()
Added: grass/trunk/raster/r.contour/testsuite/testrc.py
--- grass/trunk/raster/r.contour/testsuite/testrc.py (rev 0)
+++ grass/trunk/raster/r.contour/testsuite/testrc.py 2019-03-13 07:11:02 UTC (rev 74228)
@@ -0,0 +1,113 @@
+Purpose: Tests r.contour and its flags/options.
+Author: Sunveer Singh, Google Code-in 2018
+Copyright: (C) 2018 by Sunveer Singh and the GRASS Development Team
+ for details.
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+out_where = """cat|level
+1|56
+2|58
+3|60
+4|62
+5|64
+6|66
+7|68
+8|70
+9|72
+10|74
+11|76
+12|78
+13|80
+14|82
+15|84
+16|86
+17|88
+18|90
+19|92
+20|94
+21|96
+22|98
+23|100
+24|102
+25|104
+26|106
+27|108
+28|110
+29|112
+30|114
+31|116
+32|118
+33|120
+34|122
+35|124
+36|126
+37|128
+38|130
+39|132
+40|134
+41|136
+42|138
+43|140
+44|142
+45|144
+46|146
+47|148
+48|150
+49|152
+50|154
+51|156
+class Testrr(TestCase):
+ input='elevation'
+ output='towns'
+ @classmethod
+ @classmethod
+ def tearDown(cls):
+ def test_flag_t(self):
+ """Testing flag t"""
+ string="""min=1
+ max=6"""
+ self.assertModule('r.contour', input=self.input, output=self.output, levels=1, step=1, flags='t')
+ self.assertRasterFitsUnivar(self.output,
+ reference=string, precision=2)
+ def test_vector(self):
+ """Testing vector output"""
+ self.assertModule('r.contour', input=self.input, output=self.output, step=5, flags='t')
+ self.assertModule('v.info', map=self.output, flags='t')
+ topology = dict(points=0, lines=2222, areas=0)
+ self.assertVectorFitsTopoInfo(self.output, topology)
+ def test_v_db_select(self):
+ """Testing attribute values of contours with v.db.select """
+ self.assertModule('r.contour', input=self.input, output=self.output, step=2)
+ v_db_select = SimpleModule('v.db.select', map=self.output)
+ v_db_select.run()
+ self.assertLooksLike(reference=out_where, actual=v_db_select.outputs.stdout)
+ test()
