[GRASS-SVN] r74230 - in grass/trunk/raster/r.tile: . testsuite
svn_grass at osgeo.org
Wed Mar 13 00:13:23 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:13:23 -0700 (Wed, 13 Mar 2019)
New Revision: 74230
Added:
grass/trunk/raster/r.tile/testsuite/
grass/trunk/raster/r.tile/testsuite/test_r_tile.py
grass/trunk/raster/r.tile/testsuite/testrt.py
r.tile: added tests from GCI 2018
Added: grass/trunk/raster/r.tile/testsuite/test_r_tile.py
--- grass/trunk/raster/r.tile/testsuite/test_r_tile.py (rev 0)
+++ grass/trunk/raster/r.tile/testsuite/test_r_tile.py 2019-03-13 07:13:23 UTC (rev 74230)
@@ -0,0 +1,65 @@
+Name: r.tile test
+Purpose: Tests r.tile module and the number of created tiles.
+Author: Shubham Sharma, Google Code-in 2018
+Copyright: (C) 2018 by Shubham Sharma and the GRASS Development Team
+Licence: This program is free software under the GNU General Public
+ License (>=v2). Read the file COPYING that comes with GRASS
+ for details.
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestRasterTile(TestCase):
+ input = 'lakes'
+ output_prefix = 'lakes_tile'
+ width = '1000'
+ height = '1000'
+ overlap = '10'
+ @classmethod
+ def setUpClass(cls):
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.input)
+ @classmethod
+ def tearDownClass(cls):
+ cls.del_temp_region()
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + '-000-000')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + '-000-001')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + '-001-000')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + '-001-001')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + 'overlap' + '-000-000')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + 'overlap' + '-000-001')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + 'overlap' + '-001-000')
+ cls.runModule('g.remove', type='raster', flags='f', name=cls.output_prefix + 'overlap' + '-001-001')
+ def test_raster_tile(self):
+ """Testing r.tile runs successfully"""
+ self.assertModule('r.tile', input=self.input, output=self.output_prefix, width=self.width, height=self.height)
+ # If the above statement executed successful then
+ # 4 rasters tiles with following details should exits
+ self.assertRasterExists(self.output_prefix+'-000-000', msg="lakes_tile-000-000 does not exits")
+ self.assertRasterExists(self.output_prefix+'-000-001', msg="lakes_tile-000-001 does not exits")
+ self.assertRasterExists(self.output_prefix+'-001-000', msg="lakes_tile-001-000 does not exits")
+ self.assertRasterExists(self.output_prefix+'-001-001', msg="lakes_tile-001-001 does not exits")
+ def test_raster_tile_overlap(self):
+ """Testing r.tile runs successfully with overlap option"""
+ self.assertModule('r.tile', input=self.input, output=self.output_prefix+'overlap', width=self.width, height=self.height, overlap=self.overlap)
+ self.assertRasterExists(self.output_prefix+'overlap'+'-000-000', msg="lakes_tile-000-000 does not exits")
+ self.assertRasterExists(self.output_prefix+'overlap'+'-000-001', msg="lakes_tile-000-001 does not exits")
+ self.assertRasterExists(self.output_prefix+'overlap'+'-001-000', msg="lakes_tile-001-000 does not exits")
+ self.assertRasterExists(self.output_prefix+'overlap'+'-001-001', msg="lakes_tile-001-001 does not exits")
+if __name__ == '__main__':
+ test()
Added: grass/trunk/raster/r.tile/testsuite/testrt.py
--- grass/trunk/raster/r.tile/testsuite/testrt.py (rev 0)
+++ grass/trunk/raster/r.tile/testsuite/testrt.py 2019-03-13 07:13:23 UTC (rev 74230)
@@ -0,0 +1,58 @@
+Name: r.tile test
+Purpose: Tests r.tile and its flags/options.
+Author: Sunveer Singh, Google Code-in 2018
+Copyright: (C) 2018 by Sunveer Singh and the GRASS Development Team
+ for details.
+class Testrr(TestCase):
+ input='elevation'
+ output='tile'
+ @classmethod
+ @classmethod
+ def test_basic(self):
+ """Running a basic test"""
+ self.assertModule('r.tile', input=self.input, output=self.output, width=1500/2, height=1350/2)
+ def test_univar(self):
+ """Testing the output map tile-001-002"""
+ string="""min=55.5787925720215
+ n=506250
+ max=144.267288208008"""
+ self.assertRasterFitsUnivar('tile-000-001',
+ reference=string, precision=2)
+ def test_overlap(self):
+ """Testing overlap parameter with output map tile-000-000"""
+ tile="tile-000-000"
+ self.assertModule('r.tile', input=self.input, output=self.output, width=1500/2, height=1350/2, overlap=250)
+ self.assertRasterMinMax(map=tile, refmin=74.75374, refmax=156.3299,
+ msg="tile-000-000 in degrees must be between 74.75374 and 156.3299")
+ def test_minmax(self):
+ """Testing output map tile-000-001"""
+ tile1="tile-000-001"
+ self.assertRasterMinMax(map=tile1, refmin=55.57879, refmax=144.2673,
+ msg="tile-000-001 in degrees must be between 55.57879 and 144.2673")
+ from grass.gunittest.main import test
+ test()
