[GRASS-SVN] r74232 - in grass/trunk/scripts/v.what.vect: . testsuite
Wed Mar 13 00:16:16 PDT 2019
Author: lucadelu
Date: 2019-03-13 00:16:16 -0700 (Wed, 13 Mar 2019)
New Revision: 74232
Added:
   grass/trunk/scripts/v.what.vect/testsuite/
   grass/trunk/scripts/v.what.vect/testsuite/test_v_what_vect.py
v.what.vect: added tests from GCI 2018
Added: grass/trunk/scripts/v.what.vect/testsuite/test_v_what_vect.py
--- grass/trunk/scripts/v.what.vect/testsuite/test_v_what_vect.py	                        (rev 0)
+++ grass/trunk/scripts/v.what.vect/testsuite/test_v_what_vect.py	2019-03-13 07:16:16 UTC (rev 74232)
@@ -0,0 +1,45 @@
+Created on Sun Jun 09 11:42:54 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+from grass.script.utils import decode
+class TestVWhatVect(TestCase):
+    """Test v.what.vect script"""
+    mapName = 'myhospitals'
+    @classmethod
+    def setUpClass(cls):
+        """setup"""
+        run_command('g.copy', vector='hospitals,myhospitals')
+    @classmethod
+    def tearDownClass(cls):
+        """Remove created vector"""
+        cls.runModule('g.remove', type='vector', name=cls.mapName, flags='f')
+    def test_what_vect(self):
+        """Uploads vector values"""
+        run_command('v.db.addcolumn', map=self.mapName,
+                    columns="urb_name varchar(25)")
+        module = SimpleModule('v.what.vect', map=self.mapName,
+                              query_map='urbanarea', column='urb_name',
+                              query_column='NAME')
+        self.assertModule(module)
+        m = SimpleModule('v.db.select', map=self.mapName)
+        self.assertModule(m)
+        self.assertRegexpMatches(decode(m.outputs.stdout), 'urb_name')
+if __name__ == '__main__':
+    test()
