[GRASS-SVN] r74244 - in grass/trunk/scripts/r.blend: . testsuite
svn_grass at osgeo.org
Wed Mar 13 11:39:02 PDT 2019
Author: lucadelu
Date: 2019-03-13 11:39:02 -0700 (Wed, 13 Mar 2019)
New Revision: 74244
Added:
grass/trunk/scripts/r.blend/testsuite/
grass/trunk/scripts/r.blend/testsuite/test_r_blend.py
r.blend: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/r.blend/testsuite/test_r_blend.py
--- grass/trunk/scripts/r.blend/testsuite/test_r_blend.py (rev 0)
+++ grass/trunk/scripts/r.blend/testsuite/test_r_blend.py 2019-03-13 18:39:02 UTC (rev 74244)
@@ -0,0 +1,47 @@
+Created on Sun Jun 07 21:42:39 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+from grass.script.core import run_command
+class TestRBlend(TestCase):
+ """Test r.blend script"""
+ map1 = 'aspect'
+ map2 = 'elevation'
+ temp1 = 'elev_shade_blend.r'
+ temp2 = 'elev_shade_blend.g'
+ temp3 = 'elev_shade_blend.b'
+ @classmethod
+ def setUpClass(cls):
+ """Create maps in a small region."""
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.map1, flags='p')
+ run_command('d.mon', start='wx0')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=(cls.temp1, cls.temp2, cls.temp3))
+ cls.del_temp_region()
+ run_command('d.mon', stop='wx0')
+ def test_blend(self):
+ """blends color test"""
+ module = SimpleModule('r.blend', first=self.map1, second=self.map2,
+ output='elev_shade_blend')
+ self.assertModule(module)
+ run_command('d.rgb', red=self.temp1, green=self.temp2,
+ blue=self.temp3)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/r.blend/testsuite/test_r_blend.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
