[GRASS-SVN] r74251 - in grass/trunk/scripts/r.rgb: . testsuite
svn_grass at osgeo.org
Wed Mar 13 12:47:24 PDT 2019
Author: lucadelu
Date: 2019-03-13 12:47:24 -0700 (Wed, 13 Mar 2019)
New Revision: 74251
Added:
grass/trunk/scripts/r.rgb/testsuite/
grass/trunk/scripts/r.rgb/testsuite/test_r_rgb.py
r.rgb: added test, thanks to Sanjeet Bhatti
Added: grass/trunk/scripts/r.rgb/testsuite/test_r_rgb.py
--- grass/trunk/scripts/r.rgb/testsuite/test_r_rgb.py (rev 0)
+++ grass/trunk/scripts/r.rgb/testsuite/test_r_rgb.py 2019-03-13 19:47:24 UTC (rev 74251)
@@ -0,0 +1,44 @@
+Created on Sun Jun 08 13:20:31 2018
+ at author: Sanjeet Bhatti
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.gunittest.gmodules import SimpleModule
+class TestRRGB(TestCase):
+ """Test r.rgb script"""
+ mapName = 'elevation'
+ red = 'elevation.r'
+ green = 'elevation.g'
+ blue = 'elevation.b'
+ @classmethod
+ def setUpClass(cls):
+ """Create maps in a small region."""
+ cls.use_temp_region()
+ cls.runModule('g.region', raster=cls.mapName, flags='p')
+ @classmethod
+ def tearDownClass(cls):
+ """Remove temporary region"""
+ cls.runModule('g.remove', flags='f', type='raster',
+ name=(cls.red, cls.green, cls.blue))
+ cls.del_temp_region()
+ def test_rgb_maps(self):
+ """Generates rgb maps from a raster map test"""
+ module = SimpleModule('r.rgb', input=self.mapName, red=self.red,
+ green=self.green, blue=self.blue)
+ self.assertModule(module)
+ self.assertRasterExists(self.red)
+ self.assertRasterExists(self.green)
+ self.assertRasterExists(self.blue)
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/scripts/r.rgb/testsuite/test_r_rgb.py
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+text/x-python
\ No newline at end of property
Added: svn:eol-style
## -0,0 +1 ##
+native
