[GRASS-SVN] r74262 - grass/branches/releasebranch_7_6/lib/vector/Vlib
svn_grass at osgeo.org
Thu Mar 14 13:41:01 PDT 2019
Author: mmetz
Date: 2019-03-14 13:41:01 -0700 (Thu, 14 Mar 2019)
New Revision: 74262
grass/branches/releasebranch_7_6/lib/vector/Vlib/field.c
Vlib: add fn to launder new table name (backport trunk r74261)
Modified: grass/branches/releasebranch_7_6/lib/vector/Vlib/field.c
--- grass/branches/releasebranch_7_6/lib/vector/Vlib/field.c 2019-03-14 20:38:50 UTC (rev 74261)
+++ grass/branches/releasebranch_7_6/lib/vector/Vlib/field.c 2019-03-14 20:41:01 UTC (rev 74262)
@@ -57,6 +57,35 @@
return p;
+static int name2sql(char *name)
+ char *s = name;
+ int ret;
+ if (!s)
+ return 0;
+ /* sql-compliant name must start with letter */
+ if (!((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z'))) {
+ G_warning(_("Name <%s> is not SQL compliant. Must start with a letter."),
+ name);
+ return 0;
+ ret = 1;
+ /* convert illegal characters to underscore */
+ for (s++; *s; s++) {
+ if (!((*s >= 'A' && *s <= 'Z') || (*s >= 'a' && *s <= 'z') ||
+ (*s >= '0' && *s <= '9') || *s == '_')) {
+ G_debug(2, "Character '%c' not allowed.", *s);
+ *s = '_';
+ ret++;
+ return ret;
\brief Reset dblinks structure (number of fields)
@@ -275,7 +304,11 @@
if (name != NULL) {
p->field[p->n_fields].name = G_store(name);
/* replace all spaces with underscore, otherwise dbln can't be read */
- G_strchg(p->field[p->n_fields].name, ' ', '_');
+ /* G_strchg(p->field[p->n_fields].name, ' ', '_'); */
+ if (!name2sql(p->field[p->n_fields].name)) {
+ G_free(p->field[p->n_fields].name);
+ p->field[p->n_fields].name = NULL;
else
@@ -359,13 +392,27 @@
fi->number = field;
+ /* Field name */
+ fi->name = NULL;
+ if (field_name && *field_name) {
+ fi->name = G_store(field_name);
+ if (!name2sql(fi->name)) {
+ G_free(fi->name);
+ fi->name = NULL;
/* Table name */
if (type == GV_1TABLE) {
sprintf(buf, "%s", Map->name);
else {
- if (field_name != NULL && strlen(field_name) > 0)
- sprintf(buf, "%s_%s", Map->name, field_name);
+ if (fi->name != NULL && strlen(fi->name) > 0) {
+ sprintf(buf, "%s_%s", Map->name, fi->name);
+ if (!name2sql(buf)) {
+ sprintf(buf, "%s_%d", Map->name, field);
else
@@ -378,10 +425,8 @@
fi->table = G_store(buf);
- /* Field name */
- if (field_name)
- fi->name = G_store(field_name);
- else
+ /* Field name still empty */
+ if (!fi->name)
fi->name = G_store(buf);
fi->key = G_store(GV_KEY_COLUMN); /* Should be: id/fid/gfid/... ? */
