[GRASS-SVN] r74264 - grass/trunk/scripts/i.pansharpen
svn_grass at osgeo.org
Fri Mar 15 08:31:28 PDT 2019
Author: cmbarton
Date: 2019-03-15 08:31:28 -0700 (Fri, 15 Mar 2019)
New Revision: 74264
grass/trunk/scripts/i.pansharpen/i.pansharpen.py
updated i.pansharpen to handle pixel depths from 2-30 bits, and quashed some bugs
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2019-03-15 12:42:48 UTC (rev 74263)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2019-03-15 15:31:28 UTC (rev 74264)
@@ -2,7 +2,7 @@
-# MODULE: i.panmethod
+# MODULE: i.pansharpen
# AUTHOR(S): Overall script by Michael Barton (ASU)
# Brovey transformation in i.fusion.brovey by Markus Neteler <<neteler at osgeo org>>
@@ -14,7 +14,7 @@
# PURPOSE: Sharpening of 3 RGB channels using a high-resolution panchromatic channel
-# COPYRIGHT: (C) 2002-2012 by the GRASS Development Team
+# COPYRIGHT: (C) 2002-2019 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -71,6 +71,14 @@
#% answer: ihs
#% required: yes
#%end
+#%option
+#% key: bitdepth
+#% type: integer
+#% description: Bit depth of image (must be in range of 2-30)
+#% options: 2-32
+#% answer: 8
+#% required: yes
+#%end
#%flag
#% key: s
#% description: Serial processing rather than parallel processing
@@ -89,26 +97,39 @@
hasNumPy = False
import grass.script as grass
-from grass.script.utils import decode
# i18N
-import gettext
-gettext.install('grassmods', os.path.join(os.getenv("GISBASE"), 'locale'))
+try:
+ import gettext
+ hasGetText = True
+ gettext.install('grassmods', os.path.join(os.getenv("GISBASE"), 'locale'))
+except ImportError:
+ hasGetText = False
def main():
if not hasNumPy:
grass.fatal(_("Required dependency NumPy not found. Exiting."))
- sharpen = options['method'] # sharpening algorithm
- ms1 = options['blue'] # blue channel
- ms2 = options['green'] # green channel
- ms3 = options['red'] # red channel
- pan = options['pan'] # high res pan channel
- out = options['output'] # prefix for output RGB maps
- bladjust = flags['l'] # adjust blue channel
- sproc = flags['s'] # serial processing
+ sharpen = options['method'] # sharpening algorithm
+ ms1_orig = options['blue'] # blue channel
+ ms2_orig = options['green'] # green channel
+ ms3_orig = options['red'] # red channel
+ pan_orig = options['pan'] # high res pan channel
+ out = options['output'] # prefix for output RGB maps
+ bits = options['bitdepth'] # bit depth of image channels
+ bladjust = flags['l'] # adjust blue channel
+ sproc = flags['s'] # serial processing
+ # Internationalization
+ if not hasGetText:
+ grass.warning(_("No gettext international language support"))
+ # Checking bit depth
+ bits = float(bits)
+ if bits < 2 or bits > 30:
+ grass.warning(_("Bit depth is outside acceptable range"))
+ return
outb = grass.core.find_file('%s_blue' % out)
outg = grass.core.find_file('%s_green' % out)
outr = grass.core.find_file('%s_red' % out)
@@ -120,205 +141,94 @@
pid = str(os.getpid())
- # get PAN resolution:
- kv = grass.raster_info(map=pan)
- nsres = kv['nsres']
- ewres = kv['ewres']
- panres = (nsres + ewres) / 2
+ # convert input image channels to 8 bit for processing
+ ms1 = 'tmp%s_ms1' % pid
+ ms2 = 'tmp%s_ms2' % pid
+ ms3 = 'tmp%s_ms3' % pid
+ pan = 'tmp%s_pan' % pid
- # clone current region
- grass.use_temp_region()
- grass.run_command('g.region', res=panres, align=pan)
- grass.message(_("Performing pan sharpening with hi res pan image: %f" % panres))
- if sharpen == "brovey":
- grass.verbose(_("Using Brovey algorithm"))
- # pan/intensity histogram matching using linear regression
- outname = 'tmp%s_pan1' % pid
- panmatch1 = matchhist(pan, ms1, outname)
- outname = 'tmp%s_pan2' % pid
- panmatch2 = matchhist(pan, ms2, outname)
- outname = 'tmp%s_pan3' % pid
- panmatch3 = matchhist(pan, ms3, outname)
- outr = '%s_red' % out
- outg = '%s_green' % out
- outb = '%s_blue' % out
- # calculate brovey transformation
- grass.message(_("Calculating Brovey transformation..."))
+ if bits == 8:
+ grass.message(_("Using 8bit image channels"))
if sproc:
# serial processing
- e = '''eval(k = "$ms1" + "$ms2" + "$ms3")
- "$outr" = 1.0 * "$ms3" * "$panmatch3" / k
- "$outg" = 1.0 * "$ms2" * "$panmatch2" / k
- "$outb" = 1.0 * "$ms1" * "$panmatch1" / k'''
- grass.mapcalc(e, outr=outr, outg=outg, outb=outb,
- panmatch1=panmatch1, panmatch2=panmatch2,
- panmatch3=panmatch3, ms1=ms1, ms2=ms2, ms3=ms3,
- overwrite=True)
+ grass.run_command('g.copy', raster='%s,%s' % (ms1_orig, ms1),
+ quiet=True, overwrite=True)
+ grass.run_command('g.copy', raster='%s,%s' % (ms2_orig, ms2),
+ grass.run_command('g.copy', raster='%s,%s' % (ms3_orig, ms3),
+ grass.run_command('g.copy', raster='%s,%s' % (pan_orig, pan),
else:
# parallel processing
- pb = grass.mapcalc_start('%s_blue = (1.0 * %s * %s) / (%s + %s + %s)' %
- (out, ms1, panmatch1, ms1, ms2, ms3),
- overwrite=True)
- pg = grass.mapcalc_start('%s_green = (1.0 * %s * %s) / (%s + %s + %s)' %
- (out, ms2, panmatch2, ms1, ms2, ms3),
- overwrite=True)
- pr = grass.mapcalc_start('%s_red = (1.0 * %s * %s) / (%s + %s + %s)' %
- (out, ms3, panmatch3, ms1, ms2, ms3),
- overwrite=True)
+ pb = grass.start_command('g.copy', raster='%s,%s' % (ms1_orig, ms1),
+ pg = grass.start_command('g.copy', raster='%s,%s' % (ms2_orig, ms2),
+ pr = grass.start_command('g.copy', raster='%s,%s' % (ms3_orig, ms3),
+ pp = grass.start_command('g.copy', raster='%s,%s' % (pan_orig, pan),
pb.wait()
pg.wait()
pr.wait()
+ pp.wait()
- # Cleanup
- grass.run_command('g.remove', flags='f', quiet=True, type='raster',
- name='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
- elif sharpen == "ihs":
- grass.verbose(_("Using IHS<->RGB algorithm"))
- # transform RGB channels into IHS color space
- grass.message(_("Transforming to IHS color space..."))
- grass.run_command('i.rgb.his', overwrite=True,
- red=ms3,
- green=ms2,
- blue=ms1,
- hue="tmp%s_hue" % pid,
- intensity="tmp%s_int" % pid,
- saturation="tmp%s_sat" % pid)
- target = "tmp%s_int" % pid
- outname = "tmp%s_pan_int" % pid
- panmatch = matchhist(pan, target, outname)
- # substitute pan for intensity channel and transform back to RGB color space
- grass.message(_("Transforming back to RGB color space and sharpening..."))
- grass.run_command('i.his.rgb', overwrite=True,
- intensity="%s" % panmatch,
- saturation="tmp%s_sat" % pid,
- red="%s_red" % out,
- green="%s_green" % out,
- blue="%s_blue" % out)
- # Cleanup
- name=panmatch)
- elif sharpen == "pca":
- grass.verbose(_("Using PCA/inverse PCA algorithm"))
- grass.message(_("Creating PCA images and calculating eigenvectors..."))
- # initial PCA with RGB channels
- pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0',
- input='%s,%s,%s' % (ms1, ms2, ms3),
- output='tmp%s.pca' % pid)
- if len(pca_out) < 1:
- grass.fatal(_("Input has no data. Check region settings."))
- b1evect = []
- b2evect = []
- b3evect = []
- for l in pca_out.replace('(', ',').replace(')', ',').splitlines():
- b1evect.append(float(l.split(',')[1]))
- b2evect.append(float(l.split(',')[2]))
- b3evect.append(float(l.split(',')[3]))
- # inverse PCA with hi res pan channel substituted for principal component 1
- pca1 = 'tmp%s.pca.1' % pid
- pca2 = 'tmp%s.pca.2' % pid
- pca3 = 'tmp%s.pca.3' % pid
- b1evect1 = b1evect[0]
- b1evect2 = b1evect[1]
- b1evect3 = b1evect[2]
- b2evect1 = b2evect[0]
- b2evect2 = b2evect[1]
- b2evect3 = b2evect[2]
- b3evect1 = b3evect[0]
- b3evect2 = b3evect[1]
- b3evect3 = b3evect[2]
- outname = 'tmp%s_pan' % pid
- panmatch = matchhist(pan, ms1, outname)
- grass.message(_("Performing inverse PCA ..."))
- stats1 = grass.parse_command("r.univar", map=ms1, flags='g',
- parse=(grass.parse_key_val,
- {'sep': '='}))
- stats2 = grass.parse_command("r.univar", map=ms2, flags='g',
- {'sep': '='}))
- stats3 = grass.parse_command("r.univar", map=ms3, flags='g',
- {'sep': '='}))
- b1mean = float(stats1['mean'])
- b2mean = float(stats2['mean'])
- b3mean = float(stats3['mean'])
+ else:
+ grass.message(_("Converting image chanels to 8bit for processing"))
+ maxval = pow(2, bits) - 1
if sproc:
# serial processing
- "$outb" = 1.0* "$ms1" * "$panmatch1" / k'''
+ grass.run_command('r.rescale', input=ms1_orig, from_='0,%f' % maxval,
+ output=ms1, to='0,255', quiet=True, overwrite=True)
+ grass.run_command('r.rescale', input=ms2_orig, from_='0,%f' % maxval,
+ output=ms2, to='0,255', quiet=True, overwrite=True)
+ grass.run_command('r.rescale', input=ms3_orig, from_='0,%f' % maxval,
+ output=ms3, to='0,255', quiet=True, overwrite=True)
+ grass.run_command('r.rescale', input=pan_orig, from_='0,%f' % maxval,
+ output=pan, to='0,255', quiet=True, overwrite=True)
- cmd1 = "$outb = (1.0 * $panmatch * $b1evect1) + ($pca2 * $b2evect1) + ($pca3 * $b3evect1) + $b1mean"
- cmd2 = "$outg = (1.0 * $panmatch * $b1evect2) + ($pca2 * $b2evect1) + ($pca3 * $b3evect2) + $b2mean"
- cmd3 = "$outr = (1.0 * $panmatch * $b1evect3) + ($pca2 * $b2evect3) + ($pca3 * $b3evect3) + $b3mean"
- cmd = '\n'.join([cmd1, cmd2, cmd3])
- grass.mapcalc(cmd, outb=outb, outg=outg, outr=outr,
- panmatch=panmatch, pca2=pca2, pca3=pca3,
- b1evect1=b1evect1, b2evect1=b2evect1, b3evect1=b3evect1,
- b1evect2=b1evect2, b2evect2=b2evect2, b3evect2=b3evect2,
- b1evect3=b1evect3, b2evect3=b2evect3, b3evect3=b3evect3,
- b1mean=b1mean, b2mean=b2mean, b3mean=b3mean,
- overwrite=True)
else:
- pb = grass.mapcalc_start('%s_blue = (%s * %f) + (%s * %f) + (%s * %f) + %f'
- % (out, panmatch, b1evect1, pca2,
- b2evect1, pca3, b3evect1, b1mean),
- overwrite=True)
+ pb = grass.start_command('r.rescale', input=ms1_orig, from_='0,%f' % maxval,
+ pg = grass.start_command('r.rescale', input=ms2_orig, from_='0,%f' % maxval,
+ pr = grass.start_command('r.rescale', input=ms3_orig, from_='0,%f' % maxval,
+ pp = grass.start_command('r.rescale', input=pan_orig, from_='0,%f' % maxval,
- pg = grass.mapcalc_start('%s_green = (%s * %f) + (%s * %f) + (%s * %f) + %f'
- % (out, panmatch, b1evect2, pca2,
- b2evect2, pca3, b3evect2, b2mean),
- overwrite=True)
+ pb.wait()
+ pg.wait()
+ pr.wait()
+ pp.wait()
- pr = grass.mapcalc_start('%s_red = (%s * %f) + (%s * %f) + (%s * ''%f) + %f'
- % (out, panmatch, b1evect3, pca2,
- b2evect3, pca3, b3evect3, b3mean),
- overwrite=True)
+ # get PAN resolution:
+ kv = grass.raster_info(map=pan)
+ nsres = kv['nsres']
+ ewres = kv['ewres']
+ panres = (nsres + ewres) / 2
- pr.wait()
- pg.wait()
- pb.wait()
+ # clone current region
+ grass.use_temp_region()
+ grass.run_command('g.region', res=panres, align=pan)
- # Cleanup
- grass.run_command('g.remove', flags='f', quiet=True, type="raster",
- pattern='tmp%s*,%s' % (pid, panmatch))
+ # Select sharpening method
+ grass.message(_("Performing pan sharpening with hi res pan image: %f" % panres))
+ if sharpen == "brovey":
+ brovey(pan, ms1, ms2, ms3, out, pid, sproc)
+ elif sharpen == "ihs":
+ ihs(pan, ms1, ms2, ms3, out, pid, sproc)
+ elif sharpen == "pca":
+ pca(pan, ms1, ms2, ms3, out, pid, sproc)
# Could add other sharpening algorithms here, e.g. wavelet transformation
grass.message(_("Assigning grey equalized color tables to output images..."))
# equalized grey scales give best contrast
+ grass.message(_("setting pan-sharpened channels to equalized grey scale"))
for ch in ['red', 'green', 'blue']:
grass.run_command('r.colors', quiet=True, map="%s_%s" % (out, ch),
flags="e", color='grey')
@@ -332,7 +242,7 @@
colors.write('5 0 0 0\n20 200 200 200\n40 230 230 230\n67 255 255 255 \n')
colors.close()
- grass.run_command('r.colors', map="%s_blue" % out, rules=rules)
+ grass.run_command('r.colors', map="%s_blue" % out, rules=rules, quiet=True)
os.remove(rules)
# output notice
@@ -349,15 +259,235 @@
grass.raster_history("%s_%s" % (out, ch))
- # create a group with the three output
- grass.run_command('i.group', group=out,
- input="{n}_red,{n}_blue,{n}_green".format(n=out))
+ # create a group with the three outputs
+ #grass.run_command('i.group', group=out,
+ # input="{n}_red,{n}_blue,{n}_green".format(n=out))
# Cleanup
+ grass.message(_("cleaning up temp files"))
grass.run_command('g.remove', flags="f", type="raster",
- pattern="tmp%s*" % pid, quiet=True)
+ pattern="tmp%s*" % pid, quiet=True)
+def brovey(pan, ms1, ms2, ms3, out, pid, sproc):
+ grass.verbose(_("Using Brovey algorithm"))
+ # pan/intensity histogram matching using linear regression
+ grass.message(_("Pan channel/intensity histogram matching using linear regression"))
+ outname = 'tmp%s_pan1' % pid
+ panmatch1 = matchhist(pan, ms1, outname)
+ outname = 'tmp%s_pan2' % pid
+ panmatch2 = matchhist(pan, ms2, outname)
+ outname = 'tmp%s_pan3' % pid
+ panmatch3 = matchhist(pan, ms3, outname)
+ outr = '%s_red' % out
+ outg = '%s_green' % out
+ outb = '%s_blue' % out
+ # calculate brovey transformation
+ grass.message(_("Calculating Brovey transformation..."))
+ if sproc:
+ # serial processing
+ e = '''eval(k = "$ms1" + "$ms2" + "$ms3")
+ "$outr" = 1.0 * "$ms3" * "$panmatch3" / k
+ "$outg" = 1.0 * "$ms2" * "$panmatch2" / k
+ "$outb" = 1.0 * "$ms1" * "$panmatch1" / k'''
+ grass.mapcalc(e, outr=outr, outg=outg, outb=outb,
+ panmatch1=panmatch1, panmatch2=panmatch2,
+ panmatch3=panmatch3, ms1=ms1, ms2=ms2, ms3=ms3,
+ overwrite=True)
+ else:
+ # parallel processing
+ pb = grass.mapcalc_start('%s_blue = (1.0 * %s * %s) / (%s + %s + %s)' %
+ (out, ms1, panmatch1, ms1, ms2, ms3),
+ overwrite=True)
+ pg = grass.mapcalc_start('%s_green = (1.0 * %s * %s) / (%s + %s + %s)' %
+ (out, ms2, panmatch2, ms1, ms2, ms3),
+ overwrite=True)
+ pr = grass.mapcalc_start('%s_red = (1.0 * %s * %s) / (%s + %s + %s)' %
+ (out, ms3, panmatch3, ms1, ms2, ms3),
+ overwrite=True)
+ pb.wait()
+ pg.wait()
+ pr.wait()
+ # Cleanup
+ grass.run_command('g.remove', flags='f', quiet=True, type='raster',
+ name='%s,%s,%s' % (panmatch1, panmatch2, panmatch3))
+def ihs(pan, ms1, ms2, ms3, out, pid, sproc):
+ grass.verbose(_("Using IHS<->RGB algorithm"))
+ # transform RGB channels into IHS color space
+ grass.message(_("Transforming to IHS color space..."))
+ grass.run_command('i.rgb.his', overwrite=True,
+ red=ms3,
+ green=ms2,
+ blue=ms1,
+ hue="tmp%s_hue" % pid,
+ intensity="tmp%s_int" % pid,
+ saturation="tmp%s_sat" % pid)
+ target = "tmp%s_int" % pid
+ outname = "tmp%s_pan_int" % pid
+ panmatch = matchhist(pan, target, outname)
+ # substitute pan for intensity channel and transform back to RGB color space
+ grass.message(_("Transforming back to RGB color space and sharpening..."))
+ grass.run_command('i.his.rgb', overwrite=True,
+ intensity="%s" % panmatch,
+ saturation="tmp%s_sat" % pid,
+ red="%s_red" % out,
+ green="%s_green" % out,
+ blue="%s_blue" % out)
+ # Cleanup
+ name=panmatch)
+def pca(pan, ms1, ms2, ms3, out, pid, sproc):
+ grass.verbose(_("Using PCA/inverse PCA algorithm"))
+ grass.message(_("Creating PCA images and calculating eigenvectors..."))
+ # initial PCA with RGB channels
+ pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0',
+ input='%s,%s,%s' % (ms1, ms2, ms3),
+ output='tmp%s.pca' % pid)
+ if len(pca_out) < 1:
+ grass.fatal(_("Input has no data. Check region settings."))
+ b1evect = []
+ b2evect = []
+ b3evect = []
+ for l in pca_out.replace('(', ',').replace(')', ',').splitlines():
+ b1evect.append(float(l.split(',')[1]))
+ b2evect.append(float(l.split(',')[2]))
+ b3evect.append(float(l.split(',')[3]))
+ # inverse PCA with hi res pan channel substituted for principal component 1
+ pca1 = 'tmp%s.pca.1' % pid
+ pca2 = 'tmp%s.pca.2' % pid
+ pca3 = 'tmp%s.pca.3' % pid
+ b1evect1 = b1evect[0]
+ b1evect2 = b1evect[1]
+ b1evect3 = b1evect[2]
+ b2evect1 = b2evect[0]
+ b2evect2 = b2evect[1]
+ b2evect3 = b2evect[2]
+ b3evect1 = b3evect[0]
+ b3evect2 = b3evect[1]
+ b3evect3 = b3evect[2]
+ # Histogram matching
+ grass.message(_("Performing inverse PCA ..."))
+ # Get mean value of each channel
+ stats1 = grass.parse_command("r.univar", map=ms1, flags='g',
+ parse=(grass.parse_key_val,
+ {'sep': '='}))
+ stats2 = grass.parse_command("r.univar", map=ms2, flags='g',
+ {'sep': '='}))
+ stats3 = grass.parse_command("r.univar", map=ms3, flags='g',
+ {'sep': '='}))
+ b1mean = float(stats1['mean'])
+ b2mean = float(stats2['mean'])
+ b3mean = float(stats3['mean'])
+ if sproc:
+ cmd1 = "$outb = (1.0 * $panmatch1 * $b1evect1) + ($pca2 * $b1evect2) + ($pca3 * $b1evect3) + $b1mean"
+ cmd2 = "$outg = (1.0 * $panmatch2 * $b2evect1) + ($pca2 * $b2evect2) + ($pca3 * $b2evect3) + $b2mean"
+ cmd3 = "$outr = (1.0 * $panmatch3 * $b3evect1) + ($pca2 * $b3evect2) + ($pca3 * $b3evect3) + $b3mean"
+ cmd = '\n'.join([cmd1, cmd2, cmd3])
+ grass.mapcalc(cmd, outb=outb, outg=outg, outr=outr,
+ panmatch2=panmatch2,
+ pca2=pca2,
+ pca3=pca3,
+ b1evect1=b1evect1,
+ b2evect1=b2evect1,
+ b3evect1=b3evect1,
+ b1evect2=b1evect2,
+ b2evect2=b2evect2,
+ b3evect2=b3evect2,
+ b1evect3=b1evect3,
+ b2evect3=b2evect3,
+ b3evect3=b3evect3,
+ b1mean=b1mean,
+ b2mean=b2mean,
+ b3mean=b3mean,
+ overwrite=True)
+ else:
+ pb = grass.mapcalc_start('%s_blue = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+ % (out,
+ panmatch1,
+ b1evect1,
+ pca2,
+ b1evect2,
+ pca3,
+ b1evect3,
+ b1mean),
+ overwrite=True)
+ pg = grass.mapcalc_start('%s_green = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+ % (out,
+ panmatch2,
+ b2evect1,
+ pca2,
+ b2evect2,
+ pca3,
+ b2evect3,
+ b2mean),
+ overwrite=True)
+ pr = grass.mapcalc_start('%s_red = (%s * %f) + (%s * %f) + (%s * ''%f) + %f'
+ % (out,
+ panmatch3,
+ b3evect1,
+ pca2,
+ b3evect2,
+ pca3,
+ b3evect3,
+ b3mean),
+ overwrite=True)
+ pb.wait()
+ pg.wait()
+ pr.wait()
+ # Cleanup
+ grass.run_command('g.remove', flags='f', quiet=True, type="raster",
+ pattern='tmp%s*' % pid)
def matchhist(original, target, matched):
# pan/intensity histogram matching using numpy arrays
grass.message(_("Histogram matching..."))
@@ -374,7 +504,7 @@
# calculate number of cells for each grey value for for each image
stats_out = grass.pipe_command('r.stats', flags='cin', input=i,
sep=':')
- stats = decode(stats_out.communicate()[0]).split('\n')[:-1]
+ stats = stats_out.communicate()[0].split('\n')[:-1]
stats_dict = dict(s.split(':', 1) for s in stats)
total_cells = 0 # total non-null cells
for j in stats_dict:
