[GRASS-SVN] r74269 - grass/trunk/raster/r.contour/testsuite
Fri Mar 15 13:48:57 PDT 2019
Author: sbl
Date: 2019-03-15 13:48:57 -0700 (Fri, 15 Mar 2019)
New Revision: 74269
   grass/trunk/raster/r.contour/testsuite/testrc.py
fix r.contour test
Modified: grass/trunk/raster/r.contour/testsuite/testrc.py
--- grass/trunk/raster/r.contour/testsuite/testrc.py	2019-03-15 20:46:23 UTC (rev 74268)
+++ grass/trunk/raster/r.contour/testsuite/testrc.py	2019-03-15 20:48:57 UTC (rev 74269)
@@ -105,7 +105,7 @@
         self.assertModule('r.contour', input=self.input, output=self.output, step=2)
         v_db_select = SimpleModule('v.db.select', map=self.output)
         v_db_select.run()
-        self.assertLooksLike(reference=out_where, actual=v_db_select.outputs.stdout)
+        self.assertLooksLike(reference=out_where, actual=v_db_select.outputs.stdout.encode('utf8'))
 if __name__ == '__main__':
     from grass.gunittest.main import test
