[GRASS-SVN] r74274 - grass/trunk/scripts/v.rast.stats/testsuite
Fri Mar 15 14:46:56 PDT 2019
Author: sbl
Date: 2019-03-15 14:46:56 -0700 (Fri, 15 Mar 2019)
New Revision: 74274
   grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
fix v.rast.stats test
Modified: grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py
--- grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py	2019-03-15 21:33:44 UTC (rev 74273)
+++ grass/trunk/scripts/v.rast.stats/testsuite/test_v_rast_stats.py	2019-03-15 21:46:56 UTC (rev 74274)
@@ -61,7 +61,7 @@
         v_db_select = SimpleModule("v.db.select", map="zone_map")
         self.runModule(v_db_select)
-        self.assertLooksLike(univar_string, v_db_select.outputs.stdout)
+        self.assertLooksLike(univar_string, v_db_select.outputs.stdout.encode('utf-8'))
     def test_line_d(self):
@@ -75,7 +75,7 @@
         v_db_select = SimpleModule("v.db.select", map="test_line")
-        self.assertLooksLike(output_str, v_db_select.outputs.stdout)
+        self.assertLooksLike(output_str, v_db_select.outputs.stdout.encode('utf-8'))
     def test_line(self):
@@ -90,7 +90,7 @@
 class TestRastStatsFails(TestCase):
