[GRASS-SVN] r74297 - grass-addons/grass7/raster/r.landscape.evol
svn_grass at osgeo.org
Wed Mar 20 19:03:54 PDT 2019
Author: annakrat
Date: 2019-03-20 19:03:54 -0700 (Wed, 20 Mar 2019)
New Revision: 74297
grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py
r.landscape.evol: no need for temp files
Modified: grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py
--- grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py 2019-03-20 21:56:38 UTC (rev 74296)
+++ grass-addons/grass7/raster/r.landscape.evol/r.landscape.evol.py 2019-03-21 02:03:54 UTC (rev 74297)
@@ -349,15 +349,9 @@
tmperosion = '%sTEMPORARY_erosion%04d' % (pid, o)
tmpdep = '%sTEMPORARY_deposition%04d' % (pid, o)
# Make color rules for netchange maps
- nccolors = grass.tempfile()
- colors = open(nccolors, 'w')
- colors.write('100% 0 0 100\n1 blue\n0.5 indigo\n0.01 green\n0 white\n-0.01 yellow\n-0.5 orange\n-1 red\n0% 150 0 50\n')
- colors.close()
+ nccolors = '100% 0 0 100\n1 blue\n0.5 indigo\n0.01 green\n0 white\n-0.01 yellow\n-0.5 orange\n-1 red\n0% 150 0 50'
# Make color rules for soil depth maps
- sdcolors = grass.tempfile()
- colors = open(sdcolors, 'w')
- colors.write('100% 0:249:47\n20% 78:151:211\n6% 194:84:171\n0% 227:174:217\n')
- colors.close()
+ sdcolors = '100% 0:249:47\n20% 78:151:211\n6% 194:84:171\n0% 227:174:217'
# If first iteration, use input maps. Otherwise, use maps generated from previous iterations
if ( o == 1 ):
old_dem = '%s' % options["elev"]
@@ -508,7 +502,7 @@
grass.message('There was a problem reading the median-smoothing variable, so maps will not be median-smoothed.')
grass.run_command('g.rename', quiet = "True", rast = tempnetchange2 + ',' + netchange)
#Set the netchange map colors to the rules we've provided above
- grass.run_command('r.colors', quiet = "True", map = netchange, rules = nccolors)
+ grass.write_command('r.colors', quiet=True, map=netchange, rules='-', stdin=nccolors)
#Grab the stats from these new smoothed netchange maps and save them to dictionaries (Note that the temporary erosion and deposition maps made in this step are overwriting the two temporary maps made for gathering the stats for the soft-knee limiting filter)
grass.mapcalc('${tmperosion}=if(${netchange} < -0, ${netchange}, null())', quiet = "True", overwrite = "True", tmperosion = tmperosion, netchange = netchange)
grass.mapcalc('${tmpdep}=if(${netchange} > 0, ${netchange}, null())', quiet = "True", overwrite = "True", tmpdep = tmpdep, netchange = netchange)
@@ -521,7 +515,7 @@
#Set colors for elevation map to match other dems
grass.run_command('r.colors', quiet = "True", map = new_dem, rast = options["elev"])
grass.mapcalc('${new_soil}=if ((${new_dem} - ${initbdrk}) < 0, 0, (${new_dem} - ${initbdrk}))', quiet = "True", new_soil = new_soil, new_dem = new_dem, initbdrk = initbdrk)
- grass.run_command('r.colors', quiet = "True", map = new_soil, rules = sdcolors)
+ grass.write_command('r.colors', quiet=True, map=new_soil, rules='-', stdin=sdcolors)
grass.message('\n*************************\n Iteration %s -- ' % o + 'step 6: writing stats to output file\n *************************\n\n')
#Finish gathering stats (just need the soil depth stats now)
soilstats = grass.parse_command('r.univar', flags = 'ge', map = new_soil, percentile = '99')
@@ -572,8 +566,7 @@
pass
else:
grass.run_command('g.remove', quiet = "True", flags = 'f', type = "rast", name = ','.join(mapstoremove))
- #sdcolors.close()
- #nccolors.close()
grass.message('\n*************************\nDone with Iteration %s ' % o + '\n*************************\n')
return(0)
