[GRASS-SVN] r74316 - grass/trunk/testsuite/examples
svn_grass at osgeo.org
Wed Mar 27 05:36:30 PDT 2019
Author: neteler
Date: 2019-03-27 05:36:30 -0700 (Wed, 27 Mar 2019)
New Revision: 74316
grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf
grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
testsuite: update to use new sample dataset 'nc_spm_full_v2alpha' (trac #3783) (contributed by pmav99)
Modified: grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf
--- grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf 2019-03-27 12:31:12 UTC (rev 74315)
+++ grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.conf 2019-03-27 12:36:30 UTC (rev 74316)
@@ -5,7 +5,7 @@
# source code directory as full path:
GRASSSRC="$(realpath ../../)"
# temporary grassdata directory
-GRASSDATA="$HOME/grassdata/tests-grassdata"
+GRASSDATA="$HOME/grassdata"
# leave 1 or more CPU free for other usage than testing
FREECPU=1
Modified: grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh
--- grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh 2019-03-27 12:31:12 UTC (rev 74315)
+++ grass/trunk/testsuite/examples/test_framework_GRASS_GIS_with_NC.sh 2019-03-27 12:36:30 UTC (rev 74316)
@@ -9,8 +9,7 @@
# https://grass.osgeo.org/grass76/manuals/libpython/gunittest_running_tests.html#example-bash-script-to-run-be-used-as-a-cron-job
# Data:
-# Since we use the full NC dataset (nc_spm_08_grass7.tar.gz) here, we need to generate
-# some simplified names as used in NC basic for some test cases. This happens automatically below.
+# We use the full NC dataset (nc_spm_full_v2_alpha.tar.gz)
# COPYRIGHT: (C) 2019 by Markus Neteler, and the GRASS Development Team
@@ -102,27 +101,12 @@
mkdir -p $GRASSDATA
# fetch sample data
-SAMPLEDATA=nc_spm_08_grass7.tar.gz
-(cd $GRASSDATA ; wget -c https://grass.osgeo.org/sampledata/north_carolina/$SAMPLEDATA ; tar xfz $SAMPLEDATA )
+SAMPLEDATA=nc_spm_full_v2alpha
+(cd $GRASSDATA ; wget -c http://fatra.cnr.ncsu.edu/data/$SAMPLEDATA.tar.gz ; tar xfz $SAMPLEDATA.tar.gz --strip-components 2)
-echo "Nightly GRASS GIS test started: $NOW" >> ${LOGFILE}
+set -x
-# Preparation: Since we use the full NC dataset, we need to generate some simplified names as used in NC basic for some test cases
-echo "
-g.copy raster=basin_50K,basin
-g.copy raster=boundary_county_500m,boundary
-g.copy raster=landcover_1m,landcover
-g.copy raster=geology_30m,geology
-g.copy raster=landuse96_28m,landuse
-g.copy raster=soilsID,soils
-g.copy vector=census_wake2000,census
-g.copy vector=elev_lid792_bepts,elev_points
-g.copy vector=zipcodes_wake,zipcodes
-g.copy vector=schools_wake,schools
-g.copy vector=streets_wake,streets
-" > $GRASSDATA/tmp_rename.sh
-$GRASSBIN $GRASSDATA/nc_spm_08_grass7/PERMANENT --exec sh $GRASSDATA/tmp_rename.sh
-rm -f $GRASSDATA/tmp_rename.sh
+echo "Testing of GRASS GIS started: $NOW" >> ${LOGFILE}
if [ "$COMPILE" = "yes" ] ; then
## compile current source code from scratch
@@ -139,7 +123,7 @@
--grassbin $GRASSBIN \
--grasssrc $GRASSSRC \
--grassdata $GRASSDATA \
- --location nc_spm_08_grass7 --location-type nc \
+ --location $SAMPLEDATA --location-type nc \
--location other_location --location-type other_type
# create overall report of all so far executed tests
