[GRASS-SVN] r74321 - grass/trunk/lib/python/gunittest
svn_grass at osgeo.org
Wed Mar 27 14:38:46 PDT 2019
Author: sbl
Date: 2019-03-27 14:38:46 -0700 (Wed, 27 Mar 2019)
New Revision: 74321
grass/trunk/lib/python/gunittest/case.py
fix StrinIO imports Python 2 vs 3
Modified: grass/trunk/lib/python/gunittest/case.py
--- grass/trunk/lib/python/gunittest/case.py 2019-03-27 21:10:19 UTC (rev 74320)
+++ grass/trunk/lib/python/gunittest/case.py 2019-03-27 21:38:46 UTC (rev 74321)
@@ -31,9 +31,10 @@
if sys.version_info[0] == 2:
- import StringIO
+ from StringIO import StringIO
else:
from io import StringIO
+ unicode = str
class TestCase(unittest.TestCase):
@@ -1024,7 +1025,7 @@
stdmsg = ("There is a difference between vectors when compared as"
" ASCII files.\n")
- output = StringIO.StringIO()
+ output = StringIO()
# TODO: there is a diff size constant which we can use
# we are setting it unlimited but we can just set it large
maxlines = 100
