[GRASS-SVN] r74447 - grass/branches/releasebranch_7_6/lib/vector/Vlib
svn_grass at osgeo.org
Wed May 1 13:46:57 PDT 2019
Author: mmetz
Date: 2019-05-01 13:46:57 -0700 (Wed, 01 May 2019)
New Revision: 74447
grass/branches/releasebranch_7_6/lib/vector/Vlib/cindex.c
vectorlib: Vect_cidx_find_all() should not allow mixing GV_AREA with other geometries, fixes #3235 (backport trunk r74446)
Modified: grass/branches/releasebranch_7_6/lib/vector/Vlib/cindex.c
--- grass/branches/releasebranch_7_6/lib/vector/Vlib/cindex.c 2019-05-01 20:46:24 UTC (rev 74446)
+++ grass/branches/releasebranch_7_6/lib/vector/Vlib/cindex.c 2019-05-01 20:46:57 UTC (rev 74447)
@@ -54,7 +54,7 @@
hi = ci->n_cats - 1;
if (first > hi)
return -1;
/* deferred test for equality */
while (lo < hi) {
mid = (lo + hi) >> 1;
@@ -385,6 +385,9 @@
ci = &(Map->plus.cidx[field_index]);
+ if ((type_mask & GV_AREA) && type_mask != GV_AREA)
+ G_fatal_error(_("Mixing IDs of areas and primitives"));
idx = Vect_cidx_find_next(Map, field_index, cat,
type_mask, 0, &type, &line);
