[GRASS-SVN] r74476 - grass/branches/releasebranch_7_4
svn_grass at osgeo.org
Fri May 10 03:26:43 PDT 2019
Author: neteler
Date: 2019-05-10 03:26:42 -0700 (Fri, 10 May 2019)
New Revision: 74476
grass/branches/releasebranch_7_4/Dockerfile
gcc flag -march=native is evil in Dockerfile
Modified: grass/branches/releasebranch_7_4/Dockerfile
--- grass/branches/releasebranch_7_4/Dockerfile 2019-05-09 10:04:24 UTC (rev 74475)
+++ grass/branches/releasebranch_7_4/Dockerfile 2019-05-10 10:26:42 UTC (rev 74476)
@@ -73,8 +73,8 @@
WORKDIR /code/grass
-# Set gcc/g++ environmental variables for GRASS GIS compilation, without debug symbols
-ENV MYCFLAGS "-O2 -march=native -std=gnu99 -m64"
+# Set gcc/g++ environment variables for GRASS GIS compilation, without debug symbols
+ENV MYCFLAGS "-O2 -std=gnu99 -m64"
ENV MYLDFLAGS "-s"
# CXX stuff:
ENV LD_LIBRARY_PATH "/usr/local/lib"
@@ -103,8 +103,12 @@
&& make -j $NUMTHREADS && make install && ldconfig
# enable simple grass command regardless of version number
-RUN ln -s /usr/local/bin/grass* /usr/local/bin/grass
+# Create generic GRASS GIS binary name regardless of version number
+RUN ln -sf `find /usr/local/bin -name "grass??" | sort | tail -n 1` /usr/local/bin/grass
+# Create a generic link to GRASS GIS libs
+RUN ln -s `grass --config path` /usr/local/grass7
# Reduce the image size
RUN apt-get autoremove -y
RUN apt-get clean -y
